Question about Honeywell HZ-709 Oil Filled Radiator Heater
Does not turn on when you hit the on button - Honeywell HZ-709 Oil Filled Radiator Heater
    Problem Solver:
  • 5 Answers
It may be a faulty switch, or an open-circuit heating element. To check this you need a voltmeter/multimeter and some tools to access the switch panel. Unless you know what you are doing and are reasonably competent around electricity I sugeest you take it to a service technician.
You need to check that a voltage exists on both sides of the switch. If is not so, the switch is faulty. If it is present on both sides of the switch, you need to check circuit of heater using the resistance measuring section of the multimeter.
Posted on Oct 06, 2010
Testimonial: "it was helpful except how to gain acces to the switch to check it. No obvious screws on panel"
  • 1 more comment
  • Susan Stambaugh
    Susan Stambaugh Dec 22, 2010
    You nailed it drv51 ... how to gain access to the switch to check it out. The only "screws" are rivits on the bottom of the panel.
  • Mike619sd Mar 10, 2011
    On the top lift plastic cover two screws
  • Arnold Goldman Dec 18, 2014
    If the access to the switch terminals is not obvious look for small plastic plugs that are used to cover screws and prevent easy access. These may be removed with a small screwdriver. It usually end up with the plastic plugs unusable. Sometimes the switch is a push fit into the panel and will need careful use of a fine screwdriver to lift it from the panel.
I do not have a manual and need to know how to set it up and the code for a vizio tv.
On your remote you will find a setup botton and what i want you to do is hit set up then hit the tv botton and hit channal up and do that untell it turns off your tv are the channal if that works it tv botton again and your remote will work other wise in the back of your remote it well tell you a code number and go on line to philips and they will give your your codes for you.
Dec 09, 2009 | Philips Magnavox Learning Universal Remote
Chance time in cherokee 2005 with navigasion is no time botton
If you have a VIC (Vehicle Information Control), hold the set button down until the hours start flashing. Once the hours are flashing, hit the set button to change the hours until you've got the hours correct. Then hit the Select button and the minutes will start to flash. Hit the Set button until your minutes are correct and then hit the Select button again whereby the AM/PM button will flash, hit the Set button until your time's correct, then hit select to move to the day, date and year and when you're finally done, (after all the hitting of the SET & Select buttons, just hit the Select button and nothing will flash and your time is set. Should you have a radio that displays the time, push down and hold the TIME button until the hours begin to flash (with the radio turned off), then turn the volume wheel until the correct hour is displayed. To adjust the minutes, turn the Tuning knob until the minutes are correct. Once you're done, don't touch any of the buttons and the clock will display the correct time on it's own...when you've released all the buttons and dials.
"00 Buck"
Nov 06, 2009 | 2005 Jeep Grand Cherokee
Need instructions to program Living Solutions Speakerphone ATC-355
living solutions desktop phone (model unk) programing.
turn on with speakerphone button
hit store button once
enter phone #
hit memory button ( where number is to be stored) once
hit auto button once
to dial stored #'s
kift reciever or turn speakerphone on
hit auto once
hit memory button (where # is stores) once
wait for completion of call
Sep 19, 2009 | Lands Phones
How do i search for an unlisted code for my universal remote?
This is the web site where I found the codes for mine, http://www.remote-codes.com/universalcodes.htm
Hope this helps, if not, let me knoe the model # and I can assist further...
Sep 17, 2009 | Philips Universal PH301S Remote Control
I need to program my dish network remote to my Polaroid 4011-TLXB is there a code?
you can auto search with your cable remote
turn on your tv point the remote at it
press io and tv at the same time hold down for about 3 secounds the io button will flash or turn on then while io button is on you hit the channel button up or down till the tv turns off. when you hit the tv button again it will blink twice meaning the code is store, then hit the tv button it should turn on, if it misses the code try again it should work remeber to go slow till the tv goes off..
hope this helps..
Dec 13, 2008 | Televison & Video
Setting time and date on Samsung BL 103 digital camera
1. Turn It On (lol)
2. Hit the menu button. ( the Middle One)
3. Go over to the display option ( Third One Over)
4. Go Down To date and time
5.hit the right button
6.hit the right button again
7. when you get to the date and time just hit the up and down button to change it
8. and finally hit the ok button ( same as the menu button)
Dec 06, 2008 | Cameras
Setting date and time
Turn the calculator on.
Hit the "C/CE" button and 0. will display.
Hit the "TIME" button so that the date displays.
Hit and hold "=" button until the month flashes. Now put in your date such as 11182008.
Hit the "TIME" button again so that the time displays.
Hit and hold "=" button until the time flashes. Now put in your time such as 1254. (12:54pm)
Hit "=" button to end.
Oct 14, 2008 | Victor 1212-2 Calculator
Turning off PIP on KP-61v45
I had this problem with a universal remote.I tried everything you can think of.Finally I got it.I hit the setup button on top of tv and the volue down button to start the demo.I dont know exactly how long it ran but after awhile I hit a button and screen was normal...Yeah
Mar 10, 2007 | Sony KP-61V45 61" Rear Projection...
Honeywell HZ-709 Oil Filled Radiator Heater Logo
1,651 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
