Question about HP Pavilion dv6000z Notebook
CD/DVD-ROM not detected - HP Pavilion dv6000z Notebook
  • HP Master
  • 3,051 Answers
Hello there:
This is a common problem with thee systems the best way to to troubleshoot this is to first go to my computer and right click then go down to properties then go to device manager once in that look for your cd/dvd and right click and select uninstall and it will ask you to confirm this say yes then once this exit out of all programs and restart the computer upon restart and once you are in windows it will recognise the drive and reinstall it for you ok now if it comes up with a error this means that the drive is faulty and needs to be replaced ok?
Hope this is very helpful for you
Best regards Mike
Posted on Oct 05, 2010
  • jim_sleeth Oct 30, 2010
    Is iTunes installe don this notebook? Roxio burning software?
    This is a common problem with a filter setting in the windows registry that causes the optical drive to "disappear" in your drives window. The oiptical drive will still show up in device manager, but will show an error on the drive. either run the microsoft fixit tool located athttp://support.microsoft.com/kb/929461 or remove the upper and lower filter keys located in the registry in the HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} hive.
    Thanks....Jim
Fix DVD/CD ROM to work Acer M1610, Computer not detecting DVD/CD ROM. No drive is seen how to fix this, what are my options. OS is Vista
Hi rossclark3,
Try to check the jumper settings of your DVD/CD ROM if it is properly assigned as Master or Slave.
Afterwards, also check the cable connecting the DVD/CD ROM to the motherboard.
Finally, restart your PC and check the BIOS Setup if it can already detect your DVD/CD ROM.
Hope this helps you a lot.
Thank you for using FixYa!
Oct 29, 2011 | Computers & Internet
Hi, i am using LG dvd rom HL-DT-ST_DVD-RAM_GSA-H55N on Windows XP platform. my dvd writer is detecting cd's but not detecting dvd's.i had flashed the dvd rom by LG firmware but that does not...
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom restart your computer then plug them back in this should activate the found new hardware wizard
hope this helps you
Sep 10, 2011 | LG GSA-H55N DVD-RAM Burner
MY dvd writer not detect dvd. but detect cd. this is dvd problem.
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
hope it helps
Aug 30, 2011 | LG (GCC4521BK) CD-RW/DVD-ROM (Combo)...
I cant play a disc or DVD
Please try to reboot your laptop then go to CMOS Settings and detect the CD/DVD Rom and try to see if it is detected by your system. If it is detect ted then exit CMOS Settings and then load the Operating system you have and ope the DVD/CD Rom you have. But if it does not detect the DVD/CD Rom then i advice you to find a computer technician to help you fix the problem cause hardware problem is the main reason why it does not detect the disk drive you have, its either the connection bus is not properly plug or the Disk drive is damage or not functioning well.
Thanks
Aug 04, 2009 | IBM ThinkPad T30 2366 Notebook
MY HP 840i dvd-rw can read CD but can't read DVD
if you have cd writer and dvd rom then change your cd drive with cd/dvd writer because in the case of cd writer and dvd rom it gives error but sometimes the dvd play also but computer freeze from sometime and when we copy data then give us error messages i give you suggest to buy new cd/dvd writer
Jun 29, 2009 | HP Computers & Internet
No detected Dvd ROM in PC
Greetings my friend, regarding on your problem try to check first the connection of your CD/DVD ROM. Make it sure that the connection is isntalled/Plug correctly then also try to see the jumper and change it to slave if you are using 1 IDE cable connector for your hard disk and your CD/DVD ROM. No need to installed drivers for this device folow the steps i write then after you done all the steps i have written then restart your computer
Jun 16, 2009 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
DVD/CD-rom 52X cd-rom unable to recognize DVD
the lens inside the cd rom wil hav to be cleaned
then it wil detect
if the problem still remains then u have to replace the lens inside the cd rom
Mar 07, 2009 | Sony (CDU5212) Internal 52x CD-ROM Drive
My lg dvd rom play cd doesnot play dvd
DVD NOT DETECT ONLY DETECT THE VCD
PLEASE GIVE THE SOLUTION
Dec 28, 2008 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
MY COMPUTER DOES NOT SEE THE CD-ROM
my cd and dvd not detect of my computer how cd and dvd detect tell me a solution
Dec 25, 2008 | Computers & Internet
DVD +R
Right Click My Computer
Click properties
Find and click the hardware Tab
Click The Device Manager Button
This will bring up the device manager in a new window , from here locate your DVD Drive under : DVD/CD ROM Drives
Click the plus sign next to it and the installed CD / DVD Devices will be shown
To uninstall the CD / DVD Rom Right click on it and choose uninstall
To Reinstall Reboot , and Windows Will Automatically Detect The CD-Rom Drive and install it for you
Aug 25, 2008 | Toshiba Satellite A135-S4527 Notebook
HP Pavilion dv6000z Notebook Logo
509 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
