Question about Princeton Digital VL1918 Monitor
What's sync rate of Princeton VL1918 monitor? Is Princeton VL1918 capable of 1280x1024 60~66MHz?
  • 11,361 Answers
You should set it to the native resolution of this monitor which is 1280 x 1024 @60Hz.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 05, 2010
The VL1918 recently started having a long period of on-off switching when started up. It eventually starts working properly.
It may have bad caps, see my pictures here:
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL1918W/
This model can have many failed parts as you can see.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Feb 02, 2011 | Princeton Digital VL1918 Monitor
Hello I can't get anything on my screen except
Your PC is putting too high resolution for he VL1918 to display.
You need to set your PC video out put to the native resolution of the VL1918, which is 1280x1024 @60Hz.
You will have to hook up your old monitor (crt type?) and set the new resolution.
Or boot up in safe mode (hit f8 during boot up), and set the resolution to 640 x 480, reboot into regular mode, then rest the resolution to 1280x1024 260Hz.
Also watch out for bad caps in this monitor: http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL1918W/
Apr 07, 2010 | Princeton Digital VL1918 Monitor
Need to download drivers for a princeton vl1918 HELP!
open the internet and open the link www.softwaredriverdownload.com/princeton_graphics_vl2018w_driver.html - United States and you can instantly download the drivers
Mar 28, 2010 | Princeton Digital VL1918 Monitor
My Princeton monitor VL1918 keeps blinking on and off. What is wrong
eben161, you might try replacing some "electrolytic filter capacitors" on the "switch-mode-power-supply" printed circuit board. Try to obtain new ones that have temp rating of 105 deg centegrade. remember to replace them + to + and - to - !!! don't screw it up!!! here are some of the values you will need to purchase. 470micro farad (uf) and 2200uf and all should have a voltage rating no lower than 35vdc please report back with the name of the manufacturer you find on the original "failed" ones you remove from the unit. even if they don't look bad (swollen, leaky) replace them all with new one's. If you won't do the work you can also check to see if Princeton can swap you a refurbished unit for your old+cash. But first you should read all the posts that have been written on this model lcd monitor and how they were fixed! I'm 12fixlouie If this response was helpful to you, please rate it on fixya. Bye for now.
Nov 09, 2009 | Princeton Digital VL1918 Monitor
Princeton vl1918 flashes on than off
See previous solution for Princton Monitor cycling on and off.
Solution: Change out 3 capacitors.
Jul 15, 2009 | Princeton Digital VL1918 Monitor
Same problem
Check the Inverter card Connector which goes to pannel,Next Panel to AD card signal Cabble,..
Jul 10, 2009 | Princeton Digital VL1918 Monitor
How is the cover removed from the Princeton VL1918
Theres sort of clips that clips to the side of the monitor's frame, use a flat screwdrive to care fully push through the sides of the LCD to unlock the clips.
Nov 15, 2008 | Princeton Digital VL1918 Monitor
Will Princeton monitor VL1918 support NVIDIA GeForce 6150 SE
Hi Alvie
I Just checked the specs on both the card and the monitor. It should work no problem. If for some reason you notice some lag or flicker in the monitor, go to this page and download the updated ForceWare graphics drivers.
http://www.nvidia.com/object/winxp_169.21_whql.html
Mar 27, 2008 | Princeton Digital VL1918 Monitor
Princeton monitor
check www.badcaps.net - they have a tutorial on their site for replacing caps, it's for motherboards- but the technique is the same.
I ordered caps for the Princeton Monitor VL1918 from Mouser.com and got their item # 647-UHE1E471MPD6
The 470uf 25v caps size- 10x16 mm
Mar 11, 2008 | Princeton Digital VL1918 Monitor
Princeton Digital VL1918 Monitor Logo
212 people viewed this question
Top Princeton Digital Computers & Internet Experts
Josh Whitehead
Josh Whitehead
William Ward
Level 1 Expert
Fishlung
Level 1 Expert
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
