Question about Kenmore HE2 Plus Front Load Washer
F-35 flashes on board panel and wont work - Kenmore HE2 Plus Front Load Washer
    President:
  • 1,430 Answers
If too much detergent was used, run the unit through a Rinse/ Spin cycle then a Normal cycle without adding any detergent. This should clear the unit of the excess detergent.
Check the drain hose and make sure it is not plugged or kinked
Check the drain pump filter for debris
If all the above checks out good . This would indicate that the pressure switch or also called the analog pressure sensor has failed. First you will need to remove the top lid. Usually 2 or 3 screws on the back and the top comes right off. The pressure switch has a clear hose and a clump of wires going to it. Then unplug the hose and blow thru it it should be clear. Check the hose for leaks or obstructions. Also in the back of the washer on the left hand side is a air dome this is where it gets it pressure reading from, make sure it is not obstructed. If all is clear the pressure switch will need to be replaced. Here is a link to help with accessing the pressure switch also if you need diagrams or illustrations of your particular model.
Posted on Oct 05, 2010
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
When i power up the tv 1 light flashes 1 green flashes but screen wont come on and after 35 seconds all three lights flash and then back to 1 light flashes but no screen
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 24, 2015 | Samsung HL67A750 67 in. TV
3 flashes
Over Voltage Protection. Check its main power regulator board for fault. It will be best to replace this board as card basis. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 20, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sansui LCD TV STY0332Flat cable connecting Ti-con board to LCD panel. 35mm x 80mm.
hey i have a sansui sty 0330
hi, the screen is flashing 1 second flash, 1 second good, then 1 second flash, 1 second good is going like this contineously
Jul 18, 2013 | Televison & Video
Replaced the whole top panel. now start lights only flash wont start washer
You might have blown a fuse on the circuit board or fried a transistor on the board
Oct 07, 2012 | Whirlpool Duet GHW9150P Front Load Washer
When the Panasonic TH-50PX60U is turned on, the button beside the power switch flashes 10 times, stops and repeats the flashing. The tv will not actually turn on.
10 times red light blinking shows problem with PA board and/or H board, both boards are available in shopjimmy.com for $35 and $45
Replace required board to solve this issue.
Hope this info will help you.
Thanks.
Jan 21, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Xbox wont open all the time and wont read all the time?
Replace the dvd drive. they're about $35 from pc direct or you can find one on ebay. open the console and remove the dvd drive, buy the exact same one. you can avoid having to flash the drive by taking apart the old drive and removing the com board inside and putting it in the new one.The com board(communiaction board) has a special key inside that makes the dvd drive communicate with the mother board. This is required for the drive to play games. If you are not experienced and attempt to flash the drive yourself, which requires you to take the side panel off of your desk top computer and hook up a sata cable to a chipset, download software to flash it and is an all around hassle you can brick your console. Swapping the com board is the fastest, cheapest, and by far the easiest way to fix this. I have done this to one of my 360s last week and would not tell you to do something that would harm your console. I've also fixed the e74/RROD error has well. There is a link on how to open the xbox and fix the dvd drive. Thanks and please vote
Oct 20, 2010 | Microsoft Xbox 360 Console
I have a KDF-E50A10...its 4-5 years old, never been a problem....Tonite it has started playing for 35 seconds, and it cuts itself off for 35 seconds, I timed it. While it has itself cut off, the green...
The power supply board is dead.That the board where the power a/c cord plug into it.Replaced the power supply board will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jun 16, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Why wont my tv turn on? a red light just flashes
Right now, your TV is in " Protection Mode". A damaged part has occurred inside on one of the power supply boards. The red flashing light is a trouble code for a tech to trace the trouble circuit path.
If you have electronic experience with circuit boards, you can find a Service Manual for the TV on the internet for less than $20. This Service manual will have the schematics, red light codes, circuit diagram, and part number list you need to fix the board.
Oct 11, 2009 | Philips 42PF9631D 42 in. Plasma Television
My Vinotemp VT-12TEDS has no front panel lights or temperature reading. The unit flashes the red and green LEDs and clicks in sync with the flashes. The external cooling fans attempts to move, but does...
I also have the same problem and am looking for a solution short of buying a $35 replacement board with $10 shipping for a fridge that costs $60 new.
Oct 04, 2009 | Refrigerators
Kenmore HE2 Plus Front Load Washer Logo
50 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
