Question about Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System
No power to wall mounted door switch need wiring diagram
    Problem Solver:
  • 15 Answers
Wall mounted door opener remote should get power from the main console once that is powered up. If you have wired correctly onto to the wall mounted unite and onto the main console and upon powering up the main console there is still no "life" on the wall mounted unit, I would check if there is actually any current coming it. You can easily do it with volt meter (Harbor Freight tools have a very good one for $7 or so). If no active current, call Chamberlain.
Posted on Nov 01, 2010
The garage door will go up automatically and the wall mount loses power.
shorted out wires to the wall mount by a staple or something
Apr 27, 2015 | Building Materials
Kelvinator wiring diagram for wall mount air conditioner model ewh09hra
Good Morning Friend,
I understand that you are looking for the wiring diagram for your Kelvinator air conditioner, model# EWH09HRA. Typically, the wiring diagrams are not readily available. I suggest contacting the manufacturer, and have your model number available for them. They might be able to locate a copy of the wiring diagram of your air conditioner for you. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Electrolux Heating & Cooling
Replacing a switch on a ceiling fan
Wall mount. Cut the power to the switch by tripping the breaker at the "fuse box". You will need help to see what breaker controls that lighting circuit.
Get new switch,remove old switch from wall mount and note the color coding of the wires.
There will be screws that attach the power wires to the switch and
wires that go to the fan.Power wires are one black and one white. The other wire is a green ground wire.
Remove the wires,one at a time and connect to the switch,IF there is enough wire length to do so.You will need pliers to yank the wires out.
The stripped,bare wire at the end should go on the new fan switch so when you tighten the wire end,the wire end tightens onto the terminal clockwise.
If the stripped end is broken off,strip another 3/4" of wire and wrap the wire around the terminal,clockwise.
You MAY test the switch B-4 you put it back into the wall.Be careful of the "hot" black wire.
Click the circuit breaker back off and install into the wall box.
Jan 18, 2013 | Hunter 52" Ceiling Fan With Light And...
How do I remove the mounted garage door button to check the wires
remove the square white pad from the wall staion and you will find a screw. remove screw and lift up on entire wall station, it will come off the wall, wires are in the back
Sep 16, 2010 | liftmaster Chamberlain Garage Door Opener...
Wiring diagram for Dimplex wall heater Model 6100770000
installing a wall mount heater not sure on the wiring .heater has 3 wire black red and blue sources has white and black what wires go together
Jul 16, 2010 | Heating & Cooling
Maytag performa dryer quit while drying lost all power light will not even come on?
Below is a checklist provided by; www.repairclinic.com. They also offer disassembly diagrams and repair parts.
If your dryer doesn't work at all, it could be because of problems with:
Power from the house
Door switch
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Jul 07, 2009 | Maytag Dryers
Wall mount not opening door. Looks like its not getting power.
You may have disturbed the wiring leading to the wall control. It connects to terminals 1 and 2 on the rear of the motor unit. The wires are color coded and must be connected correctly. The solid white wire goes to terminal 2 and the white wire with red tracing goes to terminal 1.
Jun 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door opener will not opern
2 flashes indicate safety eye issue. Check you wiring and make sure it is wired correctly and check to make sure the eyes are properly aligned.
Jan 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need a wiring diagram for installing a EJ500C in place of a 3-way
Locate the COMMON wire
connected to first old switch.
It might be attached to a different
colored screw, or find
markings on old switch.
Connect BLACK wire from
switch timer to COMMON
wire, using a twist connector.
Connect the other two wires from the old switch to either the
BLUE and RED wires from the switch timer.
Connect the ground wire from the box to the BARE COPPER
wire on the switch timer. If there is no ground wire, ground the
switch timer to the box. If the box is plastic, connect the bare
copper wire to ground as supplied or contact an electrician.
Locate the COMMON on the second old switch of the 3-way pair.
Connect jumper wire (supplied) from the COMMON terminal
to either of the other terminals on the remote 3-way switch.
Make sure all twist connectors are tight.
Tuck wires into wall boxes leaving room for the devices.
Mount the devices into the wall boxes, then install the wall plates.
Turn power back on at the service panel.
Make sure the switch timer displays “MAN” mode. Do the following
test with the remote switch in each of its 2 positions:
Press the NEXT ON/OFF button on the switch timer several
times. Each time that you push the
NEXT ON/OFF button, the
switch controlled light or device (the “load”) should turn on
or off. If so, proceed to Section 3.
If the timer display changes between ON and OFF but the
load does not operate, re-check your wiring and make sure
the load is functional.
load only operates when the
remote switch is in one of
its 2 positions, you need to
turn off the power at the service panel, change the jumper
wire to the other terminal. Then turn power back on at the
service panel and repeat. good luck
Jan 20, 2009 | Intermatic Inc. EJ500C Digital Wall Switch...
Microwave removal
Actually, you shouldn't need to remove it from the wall to change the door switches or latch head.
We have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We have a partial service manual for that unit at our site, and it has the wiring diagram (helpful to be sure it all gets back right).
The manual is at http://www.microwavedisplay.com/r1380_r1381_sm.pdf
Feel free to contact me directly if you have other questions.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 31, 2008 | Microwave Ovens
Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System Logo
231 people viewed this question
Top Chamberlain Building Materials Experts
Terry Smith
Level 1 Expert
Joseph Hoffmann
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
