Question about Whirlpool ED2GHEXN Side by Side Refrigerator
My fridge is warm while the freezer is working OK. I defrosted the vent at the bottom of the freezer by blowing warm air from a hair dryer. Air start to blow through from the top into the fridge section but the draft is not powerful. What is wrong and what should the temp. be in the fridge section?
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 08, 2010
I have a maytag fridge (freezer on bottom) the fridge is not very cold. freezer has started to get ice near the door opening in the last week.
if you see ice near the door the door muat not be closing all the way or the gasket could be ripped,ice will form where warm and cold air are mixing together,did you remove any of the shelves or baskets in the freezer or in the fridge?i've seen people clean out the fridge and the shelves weren't put back in correctly keeping the door open,check that or food packages that might be hitting the door,when the warm air gets in it usually freezes the air ducts,this is why the fridge is warm,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer into the fridge section and then it returns through other air ducts so if warm air is getting in it will freeze up the air ducts,you can try shutting down the machine or unplug it,remove the food from the freezer and with a hair dryer hit the back inside wall of the freezer,blow the air up into the vent holes in the back wall,if you see water dripping down through the slots you have ice up in there,keep blowing the hot air up into the holes until you don't see any more water dripping,if you can remove the ice maker and remove the back inside wall of the freezer would be better.first check the freezer back wall to see if there's any frost or like snow on it,if so you could have a defrost problem,bad jazz board,this is the computer board that's behind your digital controls in the fridge section,bad defrost thermostat or heater,also do you mean the floor of the freezer has ice on it,you could have a blocked drain in the freezer.write back with more info and let me know what you find and hopefully i can help you better.
Sep 05, 2012 | Refrigerators
Side by side fridge freezer
That sounds like one of your cooling tubes is frosted up IF your fan is working. Pull the read freezer shield off and check for an ice buildup around the evaporator coil. If so, defrost circuit problems. If not, use a hair dryer and blow air down the cooling tubes to defrost the tubes.
Jan 23, 2012 | Refrigerators
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent holes.so let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
Jun 12, 2011 | Maytag Refrigerators
Refrigerator portion on top does have cooling but freezer on bottom works fine. I have read that the cooling all happens in the bottom and a fan transfers cool air to the the top.
if the fridge part is cool and freezer is fine what problem are you having?is the fridge not cold enough? a common problem with bottom mount freezers is the freezer door doesn't get closed all the way,warm air enters the freezer mixes with the zero degree air and freezes up the air ducts,when you open the freezer door you should hear the fan blowing,if it is check the ceiling in the freezer to see if ice is on it,check the packages for frozen water droplets and stick your hand in the fridge where the air ducts are to see if you can feel cold air blowing into the fridge,if you can't feel air blowing into the fridge,unplug it,open the freezer door,remove the top basket and remove all the food out of the bottom basket,with a hair dryer blow into the back wall into the vent holes and melt out all the ice in the ducts,you'll see water dripping down through the vent holes,when the water stops dripping plug it back in and see if the fan is blowing the air into the fridge.also you can remove the bottom kickplate and you should see a tech sheet in it,read it and it will tell you how to put the machine into defrost,it will stay in defrost for like 20 minutes,you can do this instead of unplugging it, there's a heater that comes on behind the back panel in the freezer,this can help you melt out the ice but if it seems to hard to do just unplug it.
May 25, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
I have a Whirlpool Gold refrigerator, model GB9SHDXP, about 2 and a half years old. It has a bottom freezer. Yesterday I noticed that the food in the top part were not as cold as usual. I came back...
ok,when you open the freezer door do you hear the fan blowing?all that happens is the freezer gets cold,a fan in the back wall of the freezer turns on and blows cold air up into the fridge section,a thermostat tells it when it's cold enough or it's getting warm then it will blow more air up top,if the freezer is working correctly then either the fan isn't working or the bottom freezer door was left open,warm air got sucked up into the air vents causing water droplets to be formed,then they freeze blocking the air vents with ice and now the cold air can't go into the fridge section.is there any ice on the ceiling of the freezer or frozen water droplets on the bags in the freezer?if so the door was left open.unplug the maction,and with a hair dryer blow the hot air into the holes on the back panel,keep doing this until you don't see any more water draining through the holes,turn it back on and see if the cold air is blowing up into the fridge.if the evap fan motor is bad the part number is W10128551 and it's around 25 to 30 dollars.you must of got the model number off of the book,it's not the full model number,check in the fridge section on the right hand wall near the ceiling and you should see a tag with the number on it.also down at the bottom kickplate,you can remove the kickplate and there should be a tech sheet tucked away in it,read it and it will tell you how to put the machine into defrost mode,if you can do this,instead of unplugging it if you have to melt it out with the hair dryer you can put it into defrost so the heater will come on and this will help you to defrost the vents quicker.let me know what you find and if you need any more help.good luck with your machine
Apr 12, 2011 | Whirlpool Gold GB9SHDXP
Hi - My refrigerator has begun making a very loud noise - like an airplane engine - when it kicks on. After a few minutes the sound recedes but is still louder than normal. The bottom freezer is way too...
it sounds like ice built up arounnd the fan blade probably from leaving the bottom freezer door open and warm air got in and froze up the air ducts or you have a defrost problem but if you hear a cracking sound it sounds like the heater is coming on but can't melt out all the ice.try this,take out all the food out of the freezer,unplug it,get a hair dryer and blow the hot air at the back wall where the vent holes are and melt out all the ice,when you look into the vent holes and don't see anymore water dripping down you can plug it back in and with your hand feel to see if you can feel the air blowing into the fridge section,if you feel the air then you melted out the ice and if the noise is gone then the evap fan motor is still good,if there's alot of ice and snow on the back wall you should remove the panel and then melt out all the ice with the hair dryer.also if you have another fridge you can unplug the fridge and let it melt out on it's own for like a day
Feb 10, 2011 | Refrigerators
No air blowing into fridge, although we can hear blower. Freezer is working
if you can hear the fan still blowing but no cold air coming up to fridge section a common problem with bottom mount freezers is the door gets left open and the air ducts freeze up and the air can't blow up to the top.turn the control off in the freezer.remove the top shelf and the door,check to see if there are any screws one on each side of the slide arms,if there are remove them and lift the door up and out,with a hair dryer melt out the ice by blowing the hot air up each side of the back wall,also if the back inside wall of the freezer is covered with ice or like snow then you have a defrost problem but if there's no ice on back wall do what i said and blow the air up the sides of the back wall through the vents until no more water is seen dripping through the vent holes,then turn the freezer back on and check to see if you feel cold air blowing in through the vents in the fridge section,if you feel cold air then you're all set,if not keep blowing the hot air up the sides until it's melted out.let me know what you find,you'll know if the door was left open,ice will be on the ceiling near the light switch and sometimes on the top of the freezer door
Oct 25, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer cold fridge warm
sounds like the evaporator in the freezer section is iced up and you need to see if the defrost section is working correctly,then as for the warm refrige side,it sound as if the vent damper door is frozen shut or the cold control in the refrige isn't opening it to let cold air into the refrige from the freezer,if its frozen take a hand held hair dryer and remove the vent grille over it and defrost it and then check to make sure the control opens and closes it as you adjust its control in the refrige
Apr 26, 2010 | Hoover HCA391FFK Bottom Freezer...
Refrigerator not cool freezer working
Rick,
This is the generic answer. Use the hair dryer (below) and reset the defrost (look for instructions from Sea Breeze)
Most of these units work with the freezer providing all of the cooling and a thermostat in the refrigerator section controlling a fan in the freezer (where the fan directs cold air from the freezer section to the refrigerator section via a duct in the back).
Look at the rear area of the refirgerator and locate a vent. This vent receives cold air from the freezer to the refirgerator. If you feel cold air coming out of this vent, then there may be no problem, just wait a few hours and recheck the refrigerator temperature.
Look at the rear area of the freezer and locate a vent. This vent provides cold air from the freezer to the refirgerator. Shine a bright light into this vent. You should see fan blades (possibly black plastic). If there is ice on the blades, then you have a defrost problem, and look to other posts on this site for how to manually defrost (or reset the automatic defrost). If the fan blades are rotating, then there is probably a blockage in the duct. Direct a hair dryer (warm setting) through the rear freezer vent and check to see if there is very warm air flowing out of the refrigerator vent (which indicates that the duct is not blocked). While using the hair dryer, you may be able to see the fan blades rotating.
If you do not feel warm air flowing out of the refrigerator vent, then run the hair dryer for a few minutes. (this was my problem, I saw no moisture drip from the vent, which led me to believe that it was more of a dry ice buildup, or that the ice was evaporated (desublimed to be technical).
If there is air flow and no ice buildup on the fan, then reset the automatic defrost. If this is not your solution, either the thermostat or the fan motor is the problem.
KWJ
Jun 22, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Frigadaire freezer cold but fridge compartment is warm
i need the complete model number to narrow it down they still make the frs20zrg to this day the last two numbers like frs20zrgwo or frs20zrgw9 is what will tell me what kind of defrost system it has the serial plate is in the fridge side up by the light bulb or on the left hand side or right hand side of the fridge compartment up near the top sorry to be a bother but its necessary
Mar 30, 2008 | Frigidaire FRS26ZSG
Whirlpool ED2GHEXN Side by Side Refrigerator Logo
266 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
