Question about Eureka 2991AVZ Bagless Upright Cyclonic Vacuum
How can I disassemble the Eureka Altima Brush Roll (#60844-7) for cleaning? Thank you, Jerry in Irving, TX
    Problem Solver:
  • 18 Answers
You can remove the two screws in the top cover above the roller. Then lift off the top cover exposing the roller. You can then pull the roller out, and clean out the cradles that hold the end caps. The square end caps can also be pulled off the bearings at the ends of the rollers. I had a lot of stuff wrapped around mine creating a lot of drag, but the bearings were just fine once everything got cleaned out. Just remember which end cap is which, cause they're different for each end.
Posted on Dec 24, 2010
Eureka model 71 how to clean the brush roll
Turn the head over and remove the cover screws to access the roller.Unplug the machine before doing this and remember how you took it apart
Jan 27, 2018 | Eureka Vacuums
I have a Ultima 12 amp e10071, The brush is not turning, there is tension on the brush as if the belt is connected but still there is no rotation. The motor does run. How cani open the vac to take a...
You get to the belt & brush roll area from the top. On the hood of the vacuum, right behind the word Altima, to the right & left sides, you will see a screw. Remove them, lift off plastic hood. Check belt if broken or just stretched too big to catch brush to turn it. Check ends of brushroll for any hair, thread buildup & clean it. See if end caps turn easily. If one or both ends do not turn easily, the brush roll would need to be replaced.
Eureka Brush roll part # 62365-3
Eureka U belt part # 61120D
Sep 01, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
When i vacuum it smells and so i turn it off. the
The belt is probably worn and slipping, that is why it smells. Here is a link to the owners manual which has instructions and a link to the belt you need.
Eureka Altima Owner's Guide
Eureka Altima Replacement Belts
Nov 17, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
I have a Eureka Altima and not sure how to change the belt?
1) Use handle release to lower handle
flat onto floor
2) Remove 2 screws from the front side of
brush roll cover
3) Lift and remove brush roll cover .
4) Remove brush roll and belt. Thread
new belt around motor shaft and
brush roll
5) Insert left end of brush roll first. Make
sure square on brush roll cap is in
place. Pull right side of brush roll to
stretch belt. Secure right end cap into
base.
6) Rotate brush roll 2 turns to center belt.
7) Replace brush roll cover
8) Replace 2 screws
And you can get the maual here.
http://www.eureka.com/service/manuals/80244.pdf
Good luck
Sep 27, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
I would like to disassemble my eureka altima to clean brushes
The Altima line has 2 screws on the hood (part where the knob is that says high carpet and low carpet) that you remove with a philips head screwdriver then you just lift the hood of the vacuum
Mar 08, 2009 | Eureka 402A Bagless Upright Vacuum
Eureka boss 5893A brush roll does not work
you have to prss the pedal and lean it back the brush roll wil enguage
Jan 11, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
The brush roll on my Eureka Bagless The Boss 4 dimension cleaning vaccum itsn't working. How do I fix it?
Take either the plate over the brush roll off, if it doesn't come off, then the top cover comes off, should be 2 or 3 screws on the top to remove. Then you can get to the belt and brush roll. Check the brush roll, make sure the ends turn freely, if not replace it. The belt is either broke or stretched to the point that it won't turn the roll, replace it.
Jul 13, 2008 | Eureka Vacuums
Belts
There should be 2 or 3 screws on the top cover, then you can remove the cover and the brush roll and belt are in the open. Put the belt around the motor shaft, then around the brush roll and stretch it until it goes into the place for the brush roll. While out, check the brush roll ends, make sure they turn freely, if not, then replace it.
Mar 11, 2008 | Vacuums
Broken piece
You will have to replace the brush roll, part #60844-5, belt # 61120B. You should be able to get them from a repair shop, get the right one or it won't work right. You maybe able to go eureka.com and order direct.
Mar 01, 2008 | Eureka 4700A Maxima Bagless Upright Vacuum
Eureka 2991AVZ Bagless Upright Cyclonic Vacuum Logo
239 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
