Question about Sony CASSETTE DECK Single Dual Cassette Deck
I am looking for drive belts for Sony Model TC-WR801ES stereo casette deck
  • Sony Master
  • 5,259 Answers
All you need to do is measure the diameter of each belt in MM. Then put "Cassette drive belt ??mm" into Google and you should find a supplier. Belts are not generally specific to any maker. Also you don't need to be precise on the MM. If you are removing them to measure, make a note of how they fit first.
Posted on Oct 07, 2010
Sony stereo casette deck TC-wr531, tape is stuck
The mechanism can not complete a cycle due to dried out lub and maybe a stretched belt- do not think like a lot of people do that the belt is the only answer as this will lead to a still broken deck.
Feb 17, 2014 | Audio Players & Recorders
I have a duel cassette player sony model # TC-WR 565. The doors will not open and both casettes cannot be removed even after prying the door open.
Mine did that - you will have to patiently keep pressing the clear / stop / pause / etc and even power cycle a few (or many) times and finally you will hear the mechanism release the cassette. Once you hear that - you will be able to eject the cassette. After that go replace the belts.
Dec 29, 2010 | Sony TC WE435 Stereo Dual Cassette Deck...
Tape slots won't open and nothing is functioning.
you need to replace your belts, go to partstore.com, punch in your model number and it will give you the correct belt's that you needed
Jun 06, 2010 | Sony TC WE435 Stereo Dual Cassette Deck...
NEED THE PART NUMBER FOR SONY TC-WE435 DUEL CASSETTE PLAYER BELTS
Flat belt part number is..
301657001.. BELT (CAPSTAN)
and square belt part number is...
302440501.. BELT (FR2)
Above said info are taken from TC-WE435 cassette player s/m.
Thanks.
Dec 25, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
Belt replacement in a sony tc-wr645s tape deck
I have just spent half a day trying to replace the drive belts in my sony twin deck unit , in the end it still didnt work as the the old rubber belt did some damage to the unit , anyway shops like **** smith or tandy stock the drive belts , take the front of the unit away from the main case there will be a plastic casing that surrounds the belts there are at least two belts, there should only be two small screws undo these and move the plastic unit forward on the plastic mounting brackets then you will see the metal wheel and the plastic wheel that you fit the belt around , its a bit fiddly but i can do it in my sleep now even though the motor died it was a good experience
May 21, 2009 | Sony TC WE435 Stereo Dual Cassette Deck...
TC-WA7 es DUAL DECK
you have a mechanilca failure and the casette mechanism timing got messed up. maybe bacause of faulty belts. the mechanism has to be removed and manually rotate the capstan to get it back in the right position to eject. do not force it or you damage the plastic parts. you better get it to a repair shop dear
May 03, 2008 | Sony TC-WA7ESA Single Cassette Deck
Sony Stereo Cassette Deck TC-WR550Z
Drives belt has become too slack to drive mechanism properly or the drive motor is bad. Have unit serviced for new belt(s)
Apr 29, 2008 | Sony TC-WR565RM Single Cassette Deck
Cassette Tape stuck
Try pushing the eject button while pusshing the power button. Mine was doing the same and that is how I was able to eject the tape.
Good luck
sam
Jan 01, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
296 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
