Question about Premier Watts Two-Chamber Tankless Electric Hot Water Heater #500514
I need the elements for the water heater premier model # pth28t2t 150psi max
I am also looking for replacement elements for a aquasota model PTH28T2T
Posted on Jan 22, 2011
Replace thermostat in heating element on 120v single hot water heater in still no hot water i check for power it has 120 on each side the make is ge 19.9 120 volt # ge20p6sag
  • There should be a temperature fuse look like in much case on the picture and this fuse element is in serial with the power from switch to the heating-element sometimes its hidden in an electrical heat shrink sleeve.or anywhere but is build in its to find before one of the 2 leads before the heating element, the thermostat is only to switch on an max temperature but the safety fuse is made , when the thermostat become defect it has a safety max temp before it becomes defect if it the temperature rises above to fire dangerous if the thermostat dont stop. some times max 120 degrees and more or less to choose the max temp is on the fuse to read.
  • By replace this fuse its importand to place a pliers the flat nose on the lead and right near the fuse element on the lead-site that is having to be soldering so the heat by soldering cannot get in the fuse because it would direct defekt by soldering heat
Feb 28, 2017 | Water Water Heaters
Why do I suddenly have no hot water in my electric Premier Plus water heater?
1st check the circuit breaker that supplies power to the water heater. If that is OK then check and see if you have power to the heating elements on the water heater. If not then check and see if the thermostat on the water heater has power to its connections and verify that it is calling for the water to be heated. Last if all these checks are OK then you must have a burnt out heating element. Some can be replaced but you will have to drain the water from the heater before replacing the elements.
Feb 22, 2015 | Water Water Heaters
Hot water recover time
No.
Fold-back elements are low-watt-density, so element does not burn out as easily since heating is spread across more surface area. But recovery remains 16 gallon per hour.
20 amp breaker and 12 gauge wire: max 3800 watts
30 amp breaker and 10 gauge wire: max 5800 watt.
4500 watt element heats 20 gallons per hour.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
http://waterheatertimer.org/Increase-amount-of-hot-water.html
Instead of changing elements: Set thermostats higher so more cold is added to hot water, and then you have more hot water available inside tank.
Gene
Jan 04, 2014 | Camco Copper And Zinc Standard Hwd Water...
I need to find the heater elements for a vanguard water heater 240v 36 kw model 6e746a
1) Buy 3600 watt element. Nothing special needed:
Copy following link to identify type of element:
2) March 2013: Add a comment and describe the water heater and the element.
Mar 12, 2013 | Water Heaters
What heating element do I need for a model 71-30s water heater?
Rheem 71V30 series water heaters use generic 4500 watt element from hardware store.
Look at label on side of tank for wattage.
Look for wattage and voltage printed on end of each element
http://waterheatertimer.org/How-to-test-water-heater-element.html
Aug 05, 2012 | Rheem Water Heaters
I have an eighty gallon tank and can only get two quick showers out of it. I pull the relief valve open and got hot water. then i opened the drain valve at the bottom and got cold water. does this mean the...
Suspects are lower element -or- either upper or lower thermostat.
If water heater has some hot water, then upper element is good, and electricity and circuit breaker to water heater are good.
Dual element tank is 240Volts.
Good news is tank-type electric water heater is fully repairable by homeowner using generic parts from hardware or home center:
Links below explain water heater repairs with step-by-step photos
http://waterheatertimer.org/How-to-replace-element-and-clean-sediment-out-of-electric-water-heater.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/How-water-heater-thermostat-works.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 09, 2011 | Premier Water Heaters
Water was much hotter this morning, actually steaming when faucet turned to max. I checked thermostat & reset button, seemed to be normal. I shut off power and pushed reset button, waiting for it to...
I would try it again and if water temp is still to high then I would adjust thermostat down to say 120 degrees and see what that does.If problem continues I would replace thermostat. Thank you
Dec 20, 2010 | Reliance & 50gal Electric Water Heater
Reliance electric water heater - A 95 [1995] Model 5 40 / 3500 W Max. - 240 AC Volts. Checked upper element and thermostat [fine]. Lower element and thermostat have lot of corrosion due to...
The salesman at the hardware store should be able to confirm my answer.
Match up the voltage, wattage and thread size and you should be good.
My element burned out two years ago and aside from draining the water, the job only took a few minutes and I was back in service.
Gary
Dec 15, 2010 | RELIANCE ELECTRIC WATER HEATER
I need the elements for water heaters premier
call the manufacter direct, they will usually have the part that you need. Be very careful of the plastic container hold the element inside. The break very easily, then you will have to replace the whole tank
Oct 05, 2010 | Premier Watts 500528 Four-Chamber...
Premier Watts  Two-Chamber Tankless Electric Hot Water Heater #500514 Logo
152 people viewed this question
Top Premier Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Premier Water Heater Expert? Answer questions, earn points and help others
