Question about Maytag MSD2756G Side by Side Refrigerator
Fan clatter When starting and stopping I hear just a little fan clatter as though its hitting fan housing or side.
  • 828 Answers
Check the fan motor mounting screws in the back, they may be loose. The fan motor is located behind a removable panel in the back. Also with the power off spin the fan blade and look to see if one is bent a little. While you are at it clean the condenser area.
Posted on May 28, 2008
My blower motor works intermttently. If it stops i hit the motor and it usualy starts again. Can anyone help?
Had same thing, dealer replaced motor, started same thing. I took motor out cleaned, put 3 small washer between motor & housing. Bolted up, fan was hitting housing & stopping or rubbing. Just needed space between motor & housing. That was 2 yrs ago.
Jan 03, 2013 | 2004 Dodge Ram 1500
I have cleaned the drain holes, filter, coils, etc; however, water is building up in the front of the unit and the fan starts making a loud clattering noise. There is no water built up in the back;...
If your a/c have a housing, set the upper front side 1/2" away from the wall and the lower front side 1 1/2" away from the wall. Some units with plastic base pan should be inclined more defending on the height of the drain line fitted in each model.
Sep 02, 2011 | LG Electronic Window Air Conditioner
I have a 1994 honda accord lx..heater fan was makin funny noises for a while..then stopped working..started working and stopped again..Is it hard to replace..could it be a fuse..I;m a girl..could I do it...
The heater fan is on the right side floor board under the dash. It is a little tough to do but not extremely hard. If the blower was making noise, it could be something in the heater housing. If it is starting and stopping it is probably the blower motor. When replacing the blower motor you may have to remove the fan from the motor depending on where you buy a new one. The fans (usually made of plastic) break very easy. If you attempt this, be very careful in removing the fan.
Under the dash on the right side you will have to lay on the floor and look up. There may be a lower dash panel to remove. The motor is just below the glovebox. Removed the wire, remove the bolts/screws attaching the blower to the housing. Remove the blower.
Dec 29, 2010 | 1994 Honda Accord
Engine knocks when cold
is this even in summer time, or has this just started occuring since winter got here... if its since winter got here, its perfectly normal to hear the valves clatter when the engine is cold.... if it knocks in summer time also, you have something a little more serious goin on, could be rods, could be the mains, could be both rod and main bearings, lifters, scarred cam... but being this new of a vehicle, id say its just a clatter from the lifters being in cold weather.. hope this eases your mind a little
Dec 07, 2010 | 2010 Nissan Rogue
Fan stopped working. Could it be the relay. If
I remember those winters living North of you in MB.-50 some days...Winterpeg...
I will ask my tech about the relay but I would suspect the blower motor brushes. Check your power on several speed settings. My Camry had a resistor set up on the fan housing where one speed stopped working one one speed. Upon dismantling under dash I discovered one of several resistors on the fan housing was shot which caused that speed setting alone to fail. I couldn't buy it separately at the time so I found one in a wrecker. If all speeds are dead check your fuse and suspect worn brushes on the motor.
If you can bump the housing and hear the fan start and stop that's another indication that its likely brushes.If your bearing is worn and you can hear the fan start and stop and wobble when you hit a bump, again a symptom of motor problem versus switch or relay. Not sure if you can buy brushes only, but if you are really handy you can sometimes rebuild the blower if the brushes are failed. Given your prolonged used in winter your blower likely has more wear than one in a more moderate climate so I would look there first, under dash, knee level near the glove box.Post back and I'll talk with my tech today.
Dec 27, 2009 | 1999 Lexus RX 300
The thing that resembles a plastic fan blade is
This normally means it is hitting the housing around the blade probably because it has become warped (due to heat) or has a crack in it. It generally start to break away from the motor spindle within in weeks of the sound you're hearing. You need to replace it at some point.
Dec 24, 2009 | Dryers
Whole house Fan Stops running after 10 minutes
Tightened the belt, lubed the fan and it seemed to work intermitantly.... Still ahving ussues..
aaaarg!
Jun 20, 2009 | Ventamatic Direct Drive Whole House Fan...
Fan in freezer under ice maker won't stop running.
Hi yes the fan blade could be hitting the shield or ice, remove the fan cover & check
Dec 23, 2008 | GE Profile PSW26P Stainless Steel Side by...
Samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Feb 12, 2008 | Refrigerators
Rs2360ww hot to the touch
yellow pine ..when your compressor is running the condenser fan should also be running. located next to compressor. clean coils and replace condenser fan.
Feb 07, 2008 | Samsung RS2630SH Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
52 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
