Hannspree HW194DJB (Black) Monitor Logo
Posted on Oct 05, 2010
How do I do a factory reset on a hanns g hw194d?
1helpful
Resetting hanspree tablet
1. Power off the device. (Make sure to plug in AC power.)
2. Press and hold Volume Up(+) button and Power button at the same time for 5 seconds, and release both buttons to enter system recovery utility.
3. Press Volume button to select " wipe data / factory reset " and press Power button to execute
4. Press Volume button to select " Reboot System Now "and press Power button to execute
Hannspree Customer Service at:888 808 6789 (1-909-992-5025 outside of the US); Mon - Fri: 6am - 6pm PST / PDT.
How to get rid of main menu on my hanns-g hw173d that keeps on popping. help me to solve this please
It's not a very good solution, but you can open the monitor and disconnect the button-panels plug on the mainboard. Afterwards the buttons don't work any more (surprise) but the control panel disappears.
1helpful
3answers
Flashing green led on my hanns-g HX191D
Try it on another PC fIrst.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
1helpful
2answers
Blue amber flashing no picture
Very common problem with these monitors after 2-3 years. The power supplies have died. Go to our web site and we have repair guides for Hanns-G monitors. The problem is the heat buildup in the case has caused the capacitors in the power supply to blow. If you can solder you can fix your monitors. Go to our web site at: www.ccl-la.com/badcaps.htm check out the pictures of what to look for in your monitor. Open the back and replace any that look like the pictures. Be sure to use high temp caps (105c) not like you would find at Radio Shack or you will have to do it again in a month or two. We carry the caps in stock or they can be ordered from several places. Just install the new caps with the polarity strip going the same way as the old one came out and solder them in. You should be back going in no time. If you don't want to do the repair yourself we do offer a repair service for $35 + return shipping. Let me know if you have any questions.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
1helpful
Help make speakers work
raggedyan184 -
You can find the driver for your monitor here:
http://www.howtodrivers.com/model501390.html
(You will have to enter in the numbers shown above the "Download" button in order to download, security measure for the site)
The following instructions (from the site) are also listed for installation:
Step-by-step guide for install HANNS.G HU171D driver.
1. Download file for HANNS.G HU171D from our site, save it on your computer and unzip.
2. Connect your HANNS.G HU171D to computer.
3. Right click on My computer and click Properties. Go to Hardware tab. Click to Device Manager button.
4. Find your new HANNS.G HU171D on Lcd monitors category double click on device and press Reinstall Driver button.
5. Select Install from specific location, check Include this location and click Browse button to select the Hanns.gdriver click Next button to continue and click Finish button to finish installation.
6. After this procedure you should see new HANNS.G HU171D in Lcd monitors inside device manager.
Hope this helps!
-- RT
PS - If this was useful, don't forget to vote!
My hanspree hf289h monitor has recently started to flash its menu on the screen times between the flashing menu and the time it stays on the screen vary. I tis about 3 yrs old
The older Hanns G monitors had there flukes, contact Hanns G about the issue, there is no physical fix. They will be able to help you. The new Hanns G screens are amazing, i had 3 of the 28" screens off newegg! :)
Top Hannspree Computers & Internet Experts
ADMIN Eric
ADMIN Eric
Larry Ng
Larry Ng
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
