Question about Keurig B60 Coffee Maker
We purchased our second Keurig coffee maker as our first one stopped working after a period of time. Our new coffee maker is not very old and is now doing the same thing. I've tried descaling as the machine indicated but it is still not putting out the coffee. It appears to be plugged as it will not feed the water into the machine because it's likely still full. I'm becoming extremely frustrated and since my son is getting married Saturday, will have a full house and no way to have coffee. Help please!
  • 2,299 Answers
The problem is due to the check valve located in the base of the unit just below the reservoir seats itself. However actually this small new pump cannot press hard enough to open the check valve so the water can easily flow. If there is air in the system or slightly scale this make it harder.
I have found out that that the problem occurs only just a few weeks after we use a brand new machine.
So one very good way to solve the problem is to turn the machine on and lift the water reservoir up just a couple of inches and then jam it back in place fast and hard. With this way is like it injects just enough pressure into the system to open the check valve and when the motor pump will run you will realize that immediately water will passing through from reservoir to brewer tank. This procedure has to be done often between cups.
Posted on Oct 05, 2010
I purchased a keurig 2.0 at Christmas and has stop brewing no coffee or plain water. What do indeed todo?
Call or email Keurig customer service, it is best to call to get an immediate determination on the phone, they have very good warranty. Make sure you jot down any item that occurred before it stopped. such as noises, display items ect. If the unit is determined defective at that time, they will ship a new one out at no charge. They don't repair, but may want you ship parts of the old machine back once you receive a replacement.
Jan 24, 2015 | Keurig 2.0 Brewer Water Filter Starter Kit
When I turn my keurig on, it comes on for a few seconds then turns off
Call Keurig customer service. They will walk you through some steps to try to reset it. We could not get my mothers to work and they just ended up sending me a new one out.
Aug 10, 2014 | Keurig Platinum B70 Coffee Maker
Coffee maker will not brew or it only works for a couple seconds and stops. I did everything that it says to do in the instruction booklet. We bought the coffee maker in July 2010.
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Sep 22, 2011 | Keurig B60 Coffee Maker
I have purchased two more Keurig coffee makers as Christmas gifts, but the one I purchased last year will not release water to make coffee. Is this a common problem? If so, I need to return the two new...
Sorry to read about your problem, I hope this helps you out.
no it is not a common problem, but if i am correct COSTCO, should take take it back, even after the 1 year factory warranty.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 20, 2010 | Keurig B60 Coffee Maker
Keurig B60 makes coffee at random all by itself
Try plugging it into another outlet, preferably one on a different circuit breaker. If this works call an electrician. I have seen electronic devices do all sorts of strange things when the power is bad.
Mar 02, 2017 | Keurig B60 Coffee Maker
Keurig B60 Coffee Maker Logo
159 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
