Question about Whirlpool GR460 Electric Kitchen Range
While cleaning the oven a flashing f1 and e1 came up and now i cant get anything to work
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error code F1-E1 means safety flip flop and to resolve this issue you'll have to replace the Electronic Range Control (ERC). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks Rylee
Posted on Oct 07, 2010
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
The oven does not work it says turn off when i turn it on and flashes F1 and E1 codes
The E1-F1 error code means per the service manual "safety flip flop" what that means that a internal component of the control board has failed and thusly the control board would need to be replaced
GENE
Oct 25, 2011 | Ovens
Oven flashing F and E1 codes when i turn oven on it ays to turn oven off and flashes F1 nd E1 codes
If this is a Kitchenaid, Roper or Whirlpool range, this error indicates an EEPROM error in the control board. Ifthe F1 E1 trouble code continues after you've disconnected the power for over 30 seconds, you need to replace the electronic control board (clock). You can often find parts online with the model number of the unit. (Try partselect.com or searspartsdirect.com (if Sears sold the model).)
I hope this helps.
Oct 25, 2011 | Kitchen Ranges
Oven keeps flashing E1-F3
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 22, 2010 | KitchenAid KERC607 Electric Kitchen Range
Can not start my oven after self cleaning proceture
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Apr 05, 2009 | KitchenAid KDRS807SSS Dual Fuel (Electric...
After a power outage oven will no longer work
Apr 02, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Came home from trip tp find oven display flashing E1-F1- Oven will not turn on and cannot clear display! Even tried turning breaker off and back on!!Please Help
the e1 f1 failure means an internal control failure. which means you will need to replace the control board.
usuallly it will cost about 125-150 bucks.
Feb 23, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven has error E1 F1 will not work
F1 - E1
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Jan 11, 2009 | Whirlpool RBS275PD Electric Single Oven
Whirlpool GR460 Electric Kitchen Range Logo
138 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
