Question about Franklin Chef FCR36OD Outdoor 4.8 cf Refrigerator, Stainless Steel
I need to order a control board for this refridgerator
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Oct 08, 2010
THE REFRIDGERATOR DOESN'T WORK ABOVE SETTING #3 AND GOES TO 10 DEGREES AT SETTING 3 OR BELOW
heck for good clean and tight fitting connection of thermistor to control board. If this is OK, then a diagnosis of the thermistor resistance to temperature is needed. If it is OK you could have a bad (stuck) relay on the control board.
Nov 22, 2012 | Dometic RM2652 Refrigerator
Freezer working but the refridgerator not cooling and the light is not working
If the freezer side is working fine and there is no cooling or lights on the refrigerator side, you will need to replace the control board. Here is the part to order.
Oct 28, 2012 | GE GSL25JFPBS Side by Side Refrigerator
To change main board
GE refridgerators have what they call a main dome control board. This is located on the back of the machine, usually closer to one side or the other and about halfway up the machine. This board really controls everything, even as far as the dispenser in the door. I personally think this is a poor design, even though they look awesome cosmetically. Locate your model number, usually in the refridgerator side somewhere, and go to www.repairclinic.com to order the part. This is becuase they have a return policy that no one can beat. If you install the part and it doesn't work they will take it back and refund you, where as any other part distributor have a no return policy on electronic parts. Good Luck, but you won't need it. This is an easy repair.
Removal of the board goes as follows:
1) Unplug the machine
2) Remove the control board cover by taking the screws that hold it in place.
3) Once the plate is off, locate the four plastic retaining pegs, and with a pair of needle nose pliers, squeeze the spurs together that are out on each one and lift that section of the board up.
4) With all parts of the board lifted, disconnect the wiring connections, noting each location, and remove board completly.
Jun 21, 2012 | Hotpoint Refrigerators
GSL25JFPE-BS Side by Side refrigerator compressor and condensor fan isn't coming on
May 29, 2012 | GE Refrigerators
Compressor and condensor fan isn't coming on.
May 29, 2012 | GE GSL25JFPBS Side by Side Refrigerator
ZIS480D not cooling
GE refridgerators have what they call a main dome control board. This is located on the back of the machine, usually closer to one side or the other and about halfway up the machine. This board really controls everything, even as far as the dispenser in the door. I personally think this is a poor design, even though they look awesome cosmetically. Locate your model number, usually in the refridgerator side somewhere, and go to www.repairclinic.com to order the part. This is becuase they have a return policy that no one can beat. If you install the part and it doesn't work they will take it back and refund you, where as any other part distributor have a no return policy on electronic parts. Good Luck, but you won't need it. This is an easy repair. these boards burn all the time.
May 28, 2012 | GE Refrigerators
GE profile fridge mod# PDS20SCRRSS is not cooling at all. Lights are on but no other units are powered. Pulled cover off board and fuse looks good. Smells burnt. Am I on right track?
May 08, 2012 | GE Refrigerators
Ice door started opening and closing at random. I took the solenoid out and it was very hot. I tested and there is 120 volts to the soenoid all the time. Is this a bad solenoid , or bad control board, or...
Apr 30, 2012 | GE Refrigerator Dispenser Control Board -...
Why does my freezer keep defrosting
Apr 29, 2012 | GE Refrigerators
Franklin Chef FCR36OD Outdoor 4.8 cf Refrigerator, Stainless Steel Logo
120 people viewed this question
Top Franklin Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Franklin Refrigerator Expert? Answer questions, earn points and help others
