Question about Sony KP-57WS510 57" Rear Projection HDTV
Screen has changed to look like you should be wearing 3D glasses - blue/reds showing and out of focus. Is it a new bulb? Thanks!
  • 321 Answers
Thats come from your convergence module board whers is two ic
they probly defective and the tansistor for the 40 volt regulation
they need to be replace plus a verification of the circuitry arround
it, you will need a technician to do so...
hope that will help
regards alan
PS ; i for got if its a dlp tv for got that and look for the color wheel
and the lamp,,, soory Alan
Posted on Oct 05, 2010
Turned on tv and it looked like 3d. Found red horizontal convergence lines extremely bowed. Cannot correct with magic focus either in auto or manual. What is the fix and what is more cost effective ......
TAKE OFF THE FRONT PANEL AND FIND THE FOCAS ELECTRONIC FOCAS CONTROLS. USUALY BETWEEN THE LEFT SPEAKER AND THE FIRST CRT GUN. PAUSE A DVD WHEN THE CREDITS GOING. OR USE A MENU IN YOUR SAT RECEIVER TO LOOK AT. USEING THE GRID IN THE TV SOMTIMES IS NOT ACCURATE. YOU WILL SEE 6 SMALL KNOBS (RED,GREEN,BLUE)FOCUS AND(RED,GREEN,BLUE)SCREEN DRIVE .FOLLOW THESE STEPS 1 TURNDOWN RED AND BLUE SCREENDRIVE 2 FOCUS THE GREEN (YOU SHOULD SEE SCANLINES) 3 TURN DOWN THE GREEN SCREENDRIVE 4 TURN UP THE RED SD UNTILL YOU SEE RETRACE LINES THEN BACK IT OFF TILL THEY ARE GONE. 5 FOCUS RED (UNTILL YOU SEE SCANLINES) 6 TURN RED DOWN AND TURN UP BLUE 7 FOCUS BLUE (BLUE WILL NOT BE AS GOOD AS RED+GREEN NOW YOU ARE IN FOCUS, NOW YOU NEED TO GET SCREENDRIVE BACK THE BEST WAY IS TO, PAUSE A DVD ON A BLACK SCREEN SELECT PLAY MOVIE AND HIT PAUSE RIGHT AFTER . TURN ALL THE LIGHTS OFF IN THE ROOM AND USE A SMALL FLASHLIGHT TO ADJUST SCREENDRIVE SO YOU DONT MOVE FOCAS BY MISTAKE. THE TRICK IS TO END UP WITH A VERY FAINT GRAY SCREEN WITH EACH COLOR UP AS FAR AS YOU CAN WITHOUT SEEING ANY COLOR ON THE TV. WHEN YOU GET THIS TRY PLAYING THE MOVIE. MAKE SURE THE BRIGHTNESS AND CONTRAST IN THE TV ARE AT A NORMAL LEVEL BEFORE YOU START . COLOR,BRIGHTNESS,AND FOCUS IS NOW SET TO YOUR DVD PLAYER.DO A FINAL CONVERGANCE AND YOU ARE DONE!
IF YOU CAN'T GET A COLOR TO FOCUS YOU MAY HAVE TO DO THIS MANUALY. SOME TV'S YOU CAN LOOSEN THE NUT ON THE CRT LENS AND MANUALY FOCUS IT. (LIKE AN OLD CAMERA). IF YOU GET THIS FAR YOU MIGHT AS WELL CLEAN THE LENS WITH A VINEGER BASED GLASS CLEANER (SPRAY THE RAG NOT THE TV) TAKE A LOOK AT THE MIROR, CLEAN IF NEEDED. IF THE MIRROR IS REAL DIRTY THEN THE SCREEN MUST BE BAD TOO.TAKE THE SCREEN OFF AND CLEAN THE BACK SIDE IF NEEDED. LOOK INTO THE LENS AT THE PICTURE TUBE YOU SHOULD SEE A NICE BRIGHT CLEAN PICTURE IF IT LOOKS CLOUDY YOU NEED TO CHANGE THE LIQUID IN THE CRT GUNS.I DON,T THINK YOU WAN'T TO TRY THIS YOURSELF. TIP(I USE A LITTLE ARMOR ALL WHEN I CLEAN LENES, THIS REPELS DUST LIKE IN YOUR CAR) IF YOU CHANGE YOUR FLUID AND WANT TO KNOW WHERE TO GET NEW FLUID I PUT CLEAR ANTIFREEZE IN MY PIONEER TV 3YEARS AGO AND STILL LOOKS GREAT "NOT KIDING" HOPE ALL THIS YOU. IF YOU ARE NOT COMFORTABLE TO DO IT. HAVE IR SERVICE. REPAIRING THIS WILL BE YOUR BEST OPTION>THANKS
Jan 09, 2011 | Hitachi 51SWX20B 51" Rear Projection...
My rca projection tv has blue and green images like a 3D picture would without your 3D glasses, a double vision image and no other colors
sounds like the sensors are out of focus and your red sensor isnt turning on. look in the back of the tv for a master reset button or in your menu screen some sort of "Flash focus" or "convergence". They will realign the 3 sensors.
Dec 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
Poss. convergence problem with Hitachi 53UDX10B Ultravision
You have convergence problem. Either bad connections on ics, ics are bad or voltages to convergence circuit are missing. There are no bulbs in this set. 3 picture tubes,red,green and blue produce a picture than when alighned(converged) correctly on top of each other gives you a color picture.When not you get the effect you are describing. Frst you can try the magic focus in the menu.
Apr 20, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Pictures look like they are in 3D
it sounds like your convergence is off.
you have Red, Greed & Blue projection guns
through your menu's you will find adjustments for them ...
set your green first then align then red and then blue to the green..
when making this adjustment the tv should put up a caliration signal called a crosshatch
a matrix of H and V lines to align
Apr 15, 2009 | RCA HD52W56 52" Rear Projection HDTV
RED TINT
yOUR CRTS ARE SHOWING THE SIGHNS OF WEAR. ON THE FRONT OF THE SET BEHIND THE SPEAKER GRILL OR FRONT FACIAL. THERE ARE 6 CONTROLS 3 FOR SCREEN RED GREEN AND BLUE AND 3 FOR FOCUS RED GREEN AND BLUE. YOU CAN TRY TURNING THE RED SCREEN DRIVE CONTRIL COUNTER CLOCK WISE. JUST A VERY LITTLE BIT.
Jan 22, 2009 | Televison & Video
Picture in 3d without the 3d glasses
Replace 2 convergence chips, will start with stk ###-###
Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toshiba 43A10 projection television
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 04, 2007 | Toshiba 43A10 43" Rear Projection...
Red green and blue lines
Most projection TVs have an option to refocus. For example, my Sony rear projection TV has a button on the front for focusing the lamps. Try finding this button or option in the menus with your remote. Projection TVs actually use three lamps, one red, one green and one blue. These need to line up exactly in order to form a good picture, and when they come out of focus, you see the edges which sometimes has the effect of a 3D image when you aren't wearing 3D glasses. Hope this helps!
Sep 07, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Blue and red lines..
alignment of the covergence board ,you must enter the servicemode to adjust.set on psess mute 1-8-3 .press enter to save your settings.
Aug 18, 2007 | Samsung PCN5425R 54" Rear Projection...
Sony KP-57WS510 57" Rear Projection HDTV Logo
77 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
