Back to:
Tags:
Compaq 250 GB Hard Drive
Hard Drive Problem
posted by chandrima on May 28, 2008
I have Windows Vista installed in my Notebook. I want to install the Windows XP in my Notebook, but whenever I run the CD, it is not able to detect the Hard Drive. In BIOS, no option for Hard-disk is found. Please suggest me what to do because I need it very urgently.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 28, 2008
Thanks for Trying (70)
cezirkle
Rank:Master Master
Rating: 86%, 30 votes
Greetings...
You have 3 paths to look at and you also need to think about the need to change out Vista for XP...
Vista has gotten a bad rap on being something that does not work... it works fine... unless you have some very old program that you have to have for your job, Vista will work just fine...
Now... 1. you can install a boot manager and have both Vista and XP on your computer... 2. you can reformate you HD and install XP, you have an XP disk and code??? 3. you can run Virtual PC on Vista and install XP, still need the disk and code...
Virtual PC will allow you to fire up XP and run it as a separate program on top of Vista... and it's a free download...
Still I would look at just why you need to change... I have been running Vista since before it came out and other than a couple of programs in the beginning were a problem, everything works just great...
Have a great day...
Ed
Rating Locked! (?) chandrima has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Hard Drive Problem:
I don't want to Accept this solution
Can you Help with these Hard Drives problems?
Hard Drives
i cant opnen da freeagent drive wem i click on it try to...
Hard Drives
my portable hard drive no longer is recognized in xp pro...
Hard Drives
i just purchased a maxtor basics portable hard drive so i...
Hard Drives
I plug my simpledrive into the wall and the usb port. It...
Compaq (349239B21) 250 GB Hard Drive
no sounds
Loading problems.
Repair Service
Find Hard Drive Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
