Question about HP Photosmart 3210 Printer
The repair shop I took my HP Photsmart 3200 All-in-One to told me the print heads had been destroyed by using refilled ink cartridges from Office Max and that the print heads were NOT replaceable, that I had buy a new printer! Can that be true or can I have someone else replace the print heads?
    New Friend:
  • 42 Answers
The print heads are not replaceable unless you know what you're doing. Even if you did know what you're doing, you need another bad printer of that series to exchange the print heads. It is easier to just buy a new printer that uses the same 02 ink you're used to, especially if you have a CISS system.
Posted on Oct 06, 2010
I replaced my black ink cartridge with a refilled from office max and it will not print in black. Why?
Most HP cartridges have what's called an ACCUM chip, which doesn't care about the actual ink level, it counts how many milliliters (or droplets) have gone through the head to determine when it's "empty" and therefore refilling doesn't do anything, the accum still says the cartridge is empty.
Mar 05, 2011 | HP Photosmart 2610 All-In-One InkJet...
Installed Office Depot ink cartridges, BCI 6 C and Y in my MP780. Worked ok at first, but then started getting "wrong cartridge" msg, Per canon rep, turned off mach, disconnected power, took out...
This is an example of why 2nd class refills are junk. I would try to gently clean the printer out. While a lot of people disagree with this advice, a mixture of 90% alcohol in a tiny pipit works well. Then use some lint free q-tips. Most cartridges have electronic chips on them that report the status of the cartridge. Refilled ink cartridges may have bad or defect chips.
Jan 04, 2011 | Canon PIXMA MP780 All-In-One InkJet...
I added new office max brand ink cartridge to my hp psc 2210 printer and i keep getting a "remove and check cartridge". i took inkcartridges out and replace the ink cartridge a couple of time and still...
A lot of branded ink pots have chips in them some dont it sounds like your hp printer is not getting the correct response from these ink pots , you could try to override the report and tell it to print anyway
Sep 19, 2010 | HP PSC 2210 All-In-One InkJet Printer
Did a black print cartridge refill at Costco. It
You used one of the worst refill services available. There's a reason they have a flat rate for refills, they use non cartridge specific inks, don't clean out the cartridge, and have a machine not a person do the thinking and the work for them. You will have similar failure on cartridges refilled by Walgreens, Office Max, and cheap online refills. I suggest Cartridge World first then Office Depot for refills. They have high quality standards and recycle your cartridges by refilling them.
Dec 18, 2009 | HP Photosmart 2610 All-In-One InkJet...
In the middle of a print job, my cartridge refill stops feeding ink. Printer MN J4680. Does this printer hold the cartridge # in memory in order to stop one from refilling?
HP printers do not remember the cartridge serial number to reject refills (certain Canon printers do though). It sounds like you have an air bubble in the sponge that is inhibiting ink from reaching the print head. I would guess that either you or the store/internet seller that refilled this cartridge hand filled it. These cartridges should be filled under a vacuum to remove air bubbles from the sponge and allow you to fully fill the cartridge (an air bubble takes up space that your ink could be occupying). I recommend Cartridge World or Office Depot for refills. Avoid internet sellers and refill shops that have one giant all-in-one machine that does the filling for them.
Oct 09, 2009 | HP J4680 Office Jet All-In-One Printer
Overpriced cartridges
Lexmark printers are notorious for over-inking. Probably the most efficient inkjet printer I've owned is an HP (any HP inkjet model). What has become quite popular as of late are refill machines at the local office supply stores. I have my cartridges refilled for less than half the price of new cartridges. Staples and Office Max both have great refill machines, and often have a reserve of pre-refilled (recucled) cartridges that they sell. I do not know your region, but most of the larger office supply stores have these great machines.
Also, if you color print on regular paper a lot, the ink soaks (bleeds) into the paper fibre and tends to waste a lot of ink. If you do not have a largfe office supply store near you, you can purchase refill kits and refill them yourself.(which can be messy, but effective).
Hope this helps.
Jul 09, 2009 | Lexmark X3550 All-In-One Printer
Will not print black , HP PSC 1610 All-in-One
Is it a new genuine cart? If so, I have had this problem. Run multiple copies of black only text, Run 50 copies, will still spit out blank pages.Then head clean. If no black repeat. I did this for around 200-250 copies then Volia! black. Hope this helps
Apr 28, 2009 | HP PSC 1610 All-In-One InkJet Printer
I think my ink cartridges need re-filled or replaced. Are they refillable?
Yes they are refillable. All you need to do is buy some refilling kit and an ink bottle that is compatible with your printer.
Dec 18, 2008 | HP Photosmart C4280 Aio Printer
Replacement cartriges(Office Max) HP7350.
No.
There is no way the 7350 printer knows who manufactured the cartridges, or in this case remanufactured them. The printer does do an electrical check to make sure that the cartridge is the proper model and that it is electrically sound. The cartridges you are using are remanucactured, they have been used then refilled and repackaged for sale. Depending on the quality control of the remanufacturer the results can vary widely. See here for a study HP commisioned studying the reliability of remanufactured cartrdiges.
You may have success cleaning the cartridge contacts as shown here.
In your case I would suggest returning the cartrdiges to Office Max for a warranty replacement.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 15, 2008 | HP PhotoSmart 7350 InkJet Printer
Ink cartridge question
Try Soaking the print head in Warm water for about 3 minutes. Dry off the print head with a paper towel. If you don't see any ink on the paper towel, then the print head is clogged and it will be difficult to unclog the cartridge.
If the warm water doesnt work, then next try some Windex with amonia. Only soak the bottom of the cartridge where the ink comes out. Soak the printhead for about 3 minutes, and then try wiping off the bottom again. Press a dry paper towel on the bottom. If there is no ink then it is probably time to get a new cartridge. In the future, always try to refill your cartridge right away as soon as possible so that the ink in the cartridge/print head doesnt get a chance to dry out.
I hope this helped.
Please leave a rating if I have helped you with your question/problem.
Have a good day and good luck.
Mac =)
May 20, 2008 | HP Easy Refill Kit for (HP) Black Inkjet...
HP Photosmart 3210 Printer Logo
252 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
