My Tvonics DVR FP 150 won't allow me to reformat the hard drive, won't allow me to record, access the library etc. but will allow channel change,access teletext. Any quick fixes?
  • ldcorcy Oct 05, 2010
    It gives you the option to reformat, but when you try to do this it fails and says that recording and access to stored programmes is disabled
    President:
  • 2,777 Answers
It sounds like the hard drive itself has failed. Does it give you the option to format but just doesn't do it? What does it do instead?
Thanks
Tim
Posted on Oct 05, 2010
  • Tim Grayson
    Tim Grayson Oct 05, 2010
    Ok that confirms, the hard drive has failed in the device. It is replaceable, but if you've never done anything like that before it is not easy. If you want I can find a hard drive for you that will work. Let me know if you think you want to try and replace it.
    Thanks
    Tim
Bought a tvonics freeview dtr-hv250 digital tv recorder, keeps coming up but it wont allow me to record. keeps saying the hard drive is unformatted. done what it says on the on screen instructions but
Go to your on screen menu under dtr settings and format the hard drive. If you have been recording the hard drive may be full and some programs need to be deleted to allow more recording space. You may also unplug the unit for several minutes and use the reset box option.
Jul 28, 2016 | TVonics Televison & Video
Have a problem viewing recorded footage on all cameras on my 4 channel dvr
Is it recording? Check you video settings. You may need to reformat the hard drive.
Aug 27, 2014 | Samsung 4 Channel Dvr
How can i transfer programs from a dvr to my dvd recorder?
No, most DVRs do not allow copies to be made to disk, etc.. Some like Dish, do allow you copy to an external hard drive for back up storage and viewing through the DVR.
You need to check with the mfg. of your DVR or service provider.
Jun 11, 2014 | Magnavox ZV427MG9 DVD Recorder/ VCR
Need to recover data from DirecTV R15 DVR receiver hard drive
First, sorry for the delay in respoding to your post. I did notice that you had a prior question about the Power Supply on an R15 DVR. Does the unit have a manufacture code of 500(found on the right hand front Flip Door of the DVR)? If so, I might be able to help you in repairing the Power Supply. As far as I know, getting your DVR up and running again is the only way to watch your previously recorded programs. As far as retreiving programs from your old Hard Drive via other methods, I probably won't be able to help you there. When I had both of my identical DVR 15 500's apart for a parts swap to diagnos a failed Phototransistor(infra-red sensor for the remote control), I also tried to swap out the Hard Drives. This is what I found: When you swap a Hard Drive into another DVR, it won't play any of the programs previously recorded. However, if you record new programs on the swapped Hard Drive then they will be playable on this current setup. Now, if you swap the Hard Drive back to the original DVR it came out of, the programs will once again be accessible except for any that you might have recorded while the Hard Drive was in the other DVR. So, in conclusion, when programs are recorded on a particular DVR, it is encoded electronically to play back only in that DVR via communication from the Motherboard and the Hard Drive. I know, it sucks, but that is why I was asking if you are pretty sure the Power Supply is at fault. If so, I received info from this forum on how to fix the issue. Also, if the attempt fails, Ebay has some previously owned DVR's for sale and maybe you can get one for spare parts. Remember, the Power Board and Front Display Control Panel are the only interchangeable parts IF you want to view the programs on your DVR's Hard Drive. Let me know what your DVR does when you plug it in. That will go far in further diagnostics of your DVR.
Nov 28, 2011 | Directv Plus DVR DTV Receiver / 100-Hours...
ViP211-HD DVR button won't work.....can't record any channels.....also the 'record' button doesn't respond either......
Hello, my name is Matthew Gonzales with DISH Network. I'm sorry about any inconvenience, but the ViP211 is not a DVR receiver. If you have an external hard drive, you can activate the feature on the 211 to allow you to record movies to the external hard drive. It is a one time $40 to activate the external hard drive feature. Also, we can always look at getting a DVR receiver installed to replace the 211. If you have any other questions, feel free to email me at matthew.gonzales@dishnetwork.com.
Dec 02, 2010 | DISH Network ViP 211 DTV Receiver
Unable to record any BBC channels on tvonics dvr
I had this problem and did 'Menu' then 'Settings' and 'Reset set top box'. This will lose your channels and timers, but the recorded programs will still be there. After I did this I could record again on BBC!
Jan 07, 2010 | Televison & Video
Thomson dti6300-16
You can still record all the freeview channels. What has happened is you've run out of room on your hard drive. First you must deselect all the top up channels;
menu > 'Setup' > 'Customise TUTV', and un-ticking all boxes releases space and produces a report of '100%' free for recording. The time available for recording depends on the size of the hard drive and amount of data saved in each recording and 15% of disc space is not counted. This is for software or programme information etc. and, even when not subscribed, ads from TUTV are downloaded to library. However they are replaced or removed automatically, and messages are deleted after a week.
Also delete all the recordings in the library you don't need anymore.
Oct 02, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
TVonics DVR FP 250 hard drive fault
This is a indication of a hard drive failure you could run a program called spinright on this its a small investment of $50 bucks but does save hard drives and 9 times out of 10 puts them back in business. But when in doubt replace the hard drive as if trying the format it does not work its safe to assume that you need a new drive. Thanks please do rate.
Aug 31, 2009 | TVonics STB100 Freeview DTV Receiver
Tried installing hdd from cctv dvr to save it's contents.....
Most PVR's use a small linux micro operating system to run there menus and handle the drives, as such many of the drives used by them are formatted in Ext2/3. You will need to install a driver in windows that allows it to mount ext? drives and then you should have no problem accessing it. The link below will take you to a download site for a free driver, but they do ask you to donate. Please if it works throw them a bone as this is how they keep providing such useful software for all of us.
If this works, copy the files to your computer and then let the PVR reformat the drive, unfortunately when windows doesn't recognize the drive as being formatted, it marks it. That mark is messing with the PVR but after you add these drivers you should have no problem moving the drive back and fourth as it will recognize the drive and it's data in the future.
http://www.fs-driver.org/download.html
Hope this helps FixYa,
Chris
Jul 06, 2009 | Western Digital Passport WDXML800UE...
510 DVR has to reload sat signal when accessing recorded events.
There was not a software upgrade in the last month for the 510 according to Dish Network. With that being said the issue is more than likely a bad hard drive. If you have to replace the receiver ask about a non dvr model that supports an external hard drive. This will allow you to keep from paying the dvr fee every month and allow you to have better control of your recordings eg. more record time, saved recordings if receiver needs to be replaced etc. There is a 39.99 one time fee for Dish to enable this feature but it is well worth it in my opinion. You may also want to check out the line of Sling media they have available also if you are an avid TV fan.
Feb 20, 2009 | DISH Network DVR 510 DTV Receiver /...
Televison & Video Logo
192 people viewed this question
Top Televison & Video Experts
