Question about Wasp WLR 8900 (633808501020) Handheld
I have a Wasp WLR 8900 hand held wired scanner and it will no longer scan. I have tried the factory reset only to have it beep when scanning a bar code in the users manual but still will not scan my system generated bar code. I can set it so the scanner stays on but if I have it set for button use I have to hold the button in order for the light to show. is there a setting I am missing from the user manual or is it garbage?
5 Suggested Answers
  • 3 Answers
SOURCE: Scanner blocks when scanning a bar-code
the metrologic scanner you are talking about has a barcode in the maual under the keyboard wedge section it is called stand alone keyboard this will cure your problem when you scan it. the reason being it fools the scanner into thinking there is a keyboard connected. hope this helps Pete
Posted on Aug 23, 2007
Corster
  • 79 Answers
SOURCE: problem with scanner
Yeah, from the manual, scan the following settings:
Scan Suffix
7
0
0
9
Scan Options
<DATA> <SUFFIX>
Enter
It's best to copy the necessary barcodes from the manual at 200% zoom, into a Word document and print it out.
Posted on Jan 03, 2008
Yogger
  • 117 Answers
SOURCE: Symbol Model LS 9208, Bar
If the scanner is connected through USB connection, the barcode should appear in the Notepad. If you use the Serial connection RS232, the Barcode data are showed than in Hyperterminal or other application, which is interpreting data from Serial Port.
Please scan the barcode from Product Guide according to your connection. And check the scanned data in an application - Notepad for Keyboard Wedge or USB, Hyperterminal for RS232.
Posted on Nov 02, 2010
SOURCE: I was in the middle
Push and hold down the big button for a while until it beeps. This scanner has a feature to disable the confirm beep that gets activated if you hold down the scan button too long!
Regards, Alan
Posted on Aug 27, 2011
Metrologic ms9520 not scanning UPC's
Hello.
The issue is likely due to the programming (or the lack of) of the scan gun. It is entirely possible that the UPC bar code is not configured in your gun as a valid bar code.
You can remedy this by programming the scan gun to recognize the UPC bar code (and any other bar codes you may need to scan). Use the link below to download the programming guides for this scan gun.
http://www.honeywellaidc.com/en-US/Pages/Product.aspx?category=hand-held-barcode-scanner&cat=HSM&pid=9520/40
Hope this helps!
Dec 01, 2011 | Metrologic Instruments Voyager MS9520...
We are using a Metrologic MS9520 (keyboard wedge) with QuickBooks. It won't scan barcodes provided by Quickbooks, even though it's supposed to be compatible. We've downloaded about every driver, config,...
What I would first is to bring the barcode scanner back to factory defaults. To do this you will need the manual that came with the scanner, on the first page is a bar code that say "enter/exit configuration mode" scan that first and you will hear three beeps, then scan the bar code for "recall defaults" and rescan the bar code to "enter/exit configuration mode" then retry using your scanner, if this does not work bring up "notepad" on your computer and try to scan any bar code form any retail item. This should scan, if it does net then it could be a defective scanner. See page 2 on the manual link
http://www.posguys.com/download/voyagerprogramming.pdf
Nov 11, 2010 | Microsoft Metrologic MS9520 Voyager...
Dear Staff: I have a Pro. 97 hand held scanner. I
Hi, my name is John. Press the FUNC and hold down the L/O button until it beeps twice......hope this was helpful..Rate this solution on the four thumbs-up......John
Sep 08, 2010 | Radio Shack Pro-97 Handheld Scanner
Symbol Model LS 9208, Bar code Scanner loaded factory setting, its scans(beeps) but does not display /show in the notepad.
Aug 21, 2010 | Symbol LS9208 Hands Free Barcode Scanner
Symbol LS 9100 does not transmit data
after scanning the defaults barcode you just scan the "Enable LS 9100 Communication" on this manual on the link above.https://docs.symbol.com/manuals/1536503c.pdf
May 11, 2010 | Symbol LS9100 Hands Free
Double scans
Its your software, try to reset the PoS software you are using. you could also first test by using note pad or any text editor. with your barcode scanner connected, close all open applications, open a black note pad and scan to the note pad. check if it does double scan still to confirm.
Regards
Apr 01, 2010 | HHP Hand Held Products IT3800LR-12 Barcode...
I have lost my installation disk for my printer. How can I install my printer on my new computer with out it SCANER
Hi
Please try to download the printer and utility software from the site of your printer then install it
Thanks
Boopathy.t
Aug 23, 2008 | Computers & Internet
Beep Setting
On the left, at the rear of the scanner, there are three holes.
Place your finger...!
Print this message and scan one of the following barcodes:
Dec 05, 2007 | Wasp WWS800 Handheld
Wasp WLR 8900 (633808501020) Handheld Logo
Top Wasp Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Jude24
Andrew Taylor
Andrew Taylor
Are you a Wasp Computer and Internet Expert? Answer questions, earn points and help others
