Question about Maytag Neptune MCG8000AW Gas Dryer
My Maytag dryer wont heat. I pulled of the panel and checked my glow ignitor and it works. we have gas to the unit what type of sensor would it be?
  • Maytag Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
My Maytag Neptune dryer model mdg5500aww has no heat when running . ignitor never gets red. there's gas to the unit and 110 volts. there really not much lint in there. is the problem the flame sensor?
heatman101
Dec 15, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer won't ignite. ignitor pulls 3.8amps. thermal fuse has continuity. flame sensor is working. jumped sensor no resultbesides checking outgas valve coil for ohms what other possibilities could...
heatman101
Aug 31, 2010 | Maytag Dryers
I have maytag dryer and it is blowing cold air. Everything else is working.
If there is no heat then the thermostat or heating element (for an electric dryer) is not working.
If a gas dryer with no heat: Check the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Nov 24, 2009 | Office Equipment & Supplies
Dryer does not heat
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Nov 04, 2009 | Video Cameras
My Maytag model # mdg6000bww doesn't heat up?
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Jul 18, 2009 | Maytag MDG2600BWW Gas Dryer
Maytag gas dryer runs but does not heat
If yo smelled gas then the ignitor may not be working.
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor does not glow then the thermostat is bad.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.   If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
May 30, 2009 | Maytag MDG2600BWW Gas Dryer
Dryer does not heat up
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.  If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
May 29, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag gas dryer, no heat, ignitor wont glow
The machine will check all safety features first. check the overlimit by the burner. It may have a reset. If not, turn power off and check continuity (ohms). Good luck.
Apr 17, 2009 | Dryers
My Maytag Atlantis MDG6400AWW will not heat up. The drum spins but the clothes don't dry!
my dryer timer is not turning off and it does not get hot,I check glow coil.its working but it does not fire up.I smell gas some time
Apr 16, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Dryer will not get hot duct was clogged cleaned it but still won't work is there a fuse?
Check the Glow ignitor. Also there is a sensor on the machine, in the back after the panel is removed that Will not let there have any heat until it has been reset or replaced. Trying unplugging the unit for 30 minutes then plug it back it. But I recommened that you at least check out the glow ignitor before anything else
Apr 08, 2009 | Maytag HYG2460AWW Gas Dryer
Maytag Neptune MCG8000AW Gas Dryer Logo
172 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
