Question about Sony Playstation 3 (PS3) Console
Playstation 3 model CECHH01 will not play have tried hard reset nothing worked lights come on
4 Suggested Answers
Nova_1
  • 196 Answers
SOURCE: buying bigger hard drive?
it is the difference in the consoles not the size of the hard drive.. the size of the hard drive is just an indicator between the different versions of the ps3
Posted on Oct 07, 2008
  • 17 Answers
SOURCE: My playstation 3 wont play my games. Nothing
i have same prob..!!! your lazer is gone and so is the warranity i bet.. there is a big prob with the 40g ps3s i live in ireland and mine is in for new lazer costing me €140. sony will replace it for €180 and give you a 80g refirbished one even if your warranity is out.....
Posted on Aug 17, 2009
  • 742 Answers
SOURCE: i have playstation 3 model # CECHH01, a game is
well sounds like your PS3 needs to be reflowed or reballed. I would highly recomend you have a professional do the repair. as fas as having a game stuck inside the machine you can get it out in under 10 seconds by doing this.<br /> <br /> 1) turn off power switch in back of ps3<br /> 2) place finger on eject button and hold there while ps3 is off ( no red light) <br /> 3) while holding finger on the eject button turn power switch on the back of ps3 on , hold finger on eject button untill the disk ejects.<br /> 4) turn power switch off and have unit repaired or replaced. <br /> <br /> if unit is covered by warranty and you send it to sony you must get your disk out of the system as you will NOT get it back if you send it to sony. Most reputable repair shops will return your disk with the system or give it to you before they take the system in for repairs. I ALWAYS give the game disks back before a customer leaves my shop as it leaves me with less to keep track of.
Posted on Aug 23, 2010
Sony ps3 with kes-410aca laser not spinning
seems like u have a bad ribbon cable.. that can cause the problem.. i had the same problem with many consoles,
before u buy a new ribbon cable, try to clean all ribbon's connectors with a connector cleaner spray.
Feb 14, 2013 | Sony Playstation 3 Blu Ray Laser Drive...
Why does my playstation 3 keep turning off and the red light keeps flashing?
This can can be any one of numerous issues. The first step toward setting everything to rights is to discover what the light is trying to communicate, outside of the obvious fact that your system is not working. First, disconnect everything from the unit, power cable, HDMI, component cables, controller-charging cables or anything else you may have connected.
Allow the unit to sit and cool off for a few minutes before re-attaching all the component wires. It is a good idea to begin with just the connection to the television. You can also try a manual reset of the system if the above steps do not work, simply press and hold the power button for ten seconds.
If none of the above works, you are dealing with a serious PS3 flashing red light issue. This could be a faulty power supply, dead hard drive or malfunctioning CPU just to name a few. You will need to check all these components out and determine if they are still functioning correctly. Screwdrivers and a few other common household tools may be required.
How old is your playstation?
Also try this link if you playstation is outside of waranty
Jan 14, 2011 | Sony Playstation 3 (PS3) Console
If I try putting a movie into the system it comes up and starts playing. But the games wont even recognize as being inserted.
Does the disc spin? Put a mark on the disc then insert it. If it does not spin then It is probably the laser that needs to be replaced. It an easy fix. Go to ebay and and search for the laser. On the bottom left hand corner there is a upc code. should say something like:CECHH01. Use that to search into ebay and you should find a new blu ray laser or drive
Mar 18, 2010 | Sony Playstation 3 (PS3) Console
A blank screen
You probably need to reset the video. Here's what you do: Turn the PS3 off from ther back switch and then back on so that the light on the front is red. Then press down on the power button and DO NOT let go. Wait for it to turn green then beep and then go back to a red light. Then press the power button again. After you have tried that, either tell me it didn't work so I can offer more advice or tell me it worked. Thanks. :)
Sep 25, 2009 | Sony Playstation 3 (PS3) Console
Will not play games
Hi mate it seems to me you have a lazer problem it is not reading through the dvd layers, its a shame you already broke through the warrenty seals you should have taken it back to the shop
But good news for you, you can buy the whole lazer and tray assembly hear is the part number when you order and it is not very expensive
KES-400AAA fits PS3s with the serial numbers CECHE01, CECHA01, CECHG01, CECHB01
KES-400ACA fits PS3s with the serial numbers CECHP01, CECHL01, CECHK01, CECHH01
Sep 21, 2009 | Sony Playstation 3 (PS3) Console
┬┤play statio 3 does not eject
Most probably you should try hard resetting ur PS3. Like keep that power button pressed for about 10 seconds, try again later.
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Hard disk's file system is corrupted
Hi if you have the ps3 with the model # cechh01 or cechk01 or cechl01 this happen a lot you need to install the new update in a usb memory card and follow the instructions on the ps3 go to sony for instructions on how to download the update in a removable usb if you have the older models you need to format the hard drive or install another one and format the old drive in another ps3 and this can fix your problem
Mar 13, 2009 | Sony Playstation 3 (PS3) Console
Buying bigger hard drive?
Oct 07, 2008 | Sony Playstation 3 (PS3) Console
PS2 games not working on 80G Platstation 3
Though the ps3 80g is backwards compatible,it does not play back all ps2 games. go to sony's website,i believe they have a list of games that are,and are not compatible.also make sure your ps3 has all the latest software updates.if you have it hooked to the internet im sure it does
Feb 03, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
178 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
