Vcr lockout samsung vcr appears to have locked out after being turned off for a move
  • georgero5 May 29, 2008
    VCR was swithched of and moved out of the way to allow decorating.It was then put backwith the same tv.and switched back on. The indicator lights are on showing picture of a tape,with a V, a clock, Rec, on one side the other side showsIPC+,nicom.If a tape is inserted it can be fast forard,rewind play on the remote control only, No picture shows, and the controls on the machine do not opperate
  • 593 Answers
Use remote and go into record timer option, clear any timer that is active, that should clear up the "lock out".
Posted on May 29, 2008
    Novelist:
    Champion:
  • 211 Answers
HI George,
I'm not real clear as to what your problem is by what you wrote. Do you mean, you tuned the vcr off and then moved it to another location and nowit seems locked up? How does it act in a locked up position. Does the power light comes on, will it not take a tape, does it take a tape and kick the tape back out right away. With a more complete discription of the problem I may be able to better answer your questioon. Please write me or call me at my shop and I'll be glad to help any way I can. Thank you
Ed ( Radio Man )
NC Electronic
Mills, Wyoming
307-266-4675
  • Ed Meshechek
    Ed Meshechek May 30, 2008
    Hi George,
    I does, in fact, sound as though your machine is locked up. I don't know why that would happen by simply unplugging it and then replugging it in. I also think that maybe, there may be a loose connection on the main board ( called a cold solder joint ), or possibly a weak or bad filter capacitor on the main board. Either of these problems can show up when a unit is unplugged and cools the circuit board down ( the power is always on the main board even if the unit is off ). If you do, in fact have a cold solder joint, the unit would need to be opened and visually inspected to find the loose connection and the resoldered. If the filter capacitor is bad, it would be a bit harder to find and require a test instrument that could check for bad capacitors. And then of course, after finding the bad part, replace it with a good one. I would almost suggest replacing the unit with a new one if you can find a cheap one at , say Wal-Mart or Sams or one of the chain stores ( prices may be less). The cost of the repair may exceed the value of a new unit.
    I Hope this has in some way helped
    Ed (Radio Man)
    NC Electronic
    Mills, Wyoming
VCR is turning off within seconds of when it's turned on, there is a red rectangle on the screen which does not say anything like it being locked, & a wheel that is continuing to move while it's o
It looks like the red triangle might be an indication that there is a fault. It could be something to with the mechanism. I would take a look inside the unit by taking off the top cover. The unit shuts down to prevent further damage.
Feb 16, 2014 | Televison & Video
Once the VCR is turned on, it turns itself off.
If there is a mechanism fault on the VCR then the VCR will shut itself down. It sounds like the mechanism might be jammed, it's trying to move to the right position, when power is applied but can't so it stops. One thing that might be wrong is the mode switch might be faulty. This will cause all sorts of thing to happen, including putting on the timer record light even when none has been set.
Feb 16, 2014 | Panasonic PV-V4523S VHS VCR
Managemylife com
From the manual:
To turn the Cooktop Lockout Feature OFF:
1. Press and hold (_ until "CLO" appears (Figure 3). Continue holding
until a second beep sounds (after 3 seconds). I_1will disappear from
the display indicating the cooktop may be used normally (Figure 4).
Note: Starting a Self-Clean cycle will automatically turn ON the Cooktop
Lockout feature. The cooktop will remain locked until the Self-Clean cycle
has completed and the oven door has unlocked. If a power failure occurs
after the Cooktop Lockout has been activated, you must turn OFF the
Cooktop Lockout feature before being able to use the cooktop features
again.
Dec 14, 2013 | Stoves Kitchen Ranges
How do I unlock the OSD lockout on a Samsung B2430H monitor. I've unplugged the power and computer connection cable. Tried holding the menu and auto keys nothing seems to work. There is just the...
OSD LOCKED/UNLOCKED
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear.
Sep 09, 2013 | Samsung SyncMaster 753S 17" CRT Monitor
How do I unlock my scanner?
Channel Lockout You can lock out a channel so it is not scanned. Channel Lockout does not erase the frequency from the channel. You can lock out up to 50 channels, including the Priority channel.
Lockout information is retained in the memory when the scanner is turned off.To Lock out a Channel
Example: Suppose you want to lock out Channel 2 because it stops on transmissions you don't want to hear.Press LOCKOUT when the scanner stops on Channel 2.The scanner locks out Channel 2, Then it immediately advances to the next channel that is not locked out, and resumes scanning.In the Manual mode, press LOCKOUT to lock out the displayed channel. Pressing LOCKOUT does not advance to the next channel in Manual mode.L/O appears in the display to indicate the displayed channel is locked out.Whenever you want to search for channels that are locked out, press MANUAL repeatedly to go through all 50 channels. If a channel is locked out, L/O
appears in the display.Restore a Locked Out Channel To unlock a channel so that it can be monitored during scanning:1. Press MANUAL repeatedly to find the locked out channel.2. Press LOCKOUT again to unlock the displayed channel. L/O no longer appears in the display.Restore All Locked Out Channel To unlock all channels, you must be in the Manual Mode.1. Press MANUAL.
2. Press and hold LOCKOUT to unlock all channels. The L/O indicator goes out on any channel previously locked out.
Sep 18, 2011 | Uniden BC248CLT Base Scanner
Keeps on locking out channels how do you un lock
Here it is, straight from the manual:
clearing a locked-out frequency
To clear a locked-out frequency, select that frequency (see
“Reviewing Locked-Out Frequencies”), then press CL.
If all locked-out frequencies are cleared within a bank, No
Lockout appears.
clearing all locked-out frequencies in a search bank
1. Press SRCH.
2. Select the search bank in which you want to clear all
locked-out frequencies.
3. Press FUNC then press L/OUT. Lockout list appears.
4. Press FUNC then 6. Clear entire list ? Press 1 to clear all, any
other key aborts appears. Press 1 to clear all locked-out
frequencies. List cleared. appears for about 2 seconds.
Press any key other than 1 to cancel clear.
I hope this helps. If it does, please take a moment to give me a rating. A rating of "very helpful" would be greatly appreciated.
Nov 23, 2009 | Radio Shack Pro-97 Handheld Scanner
Lockout
try to get a univeral remote and enter the sanyo DVD player code, then you should be able to work it.
Oct 30, 2008 | Sanyo DVW-7000 DVD Player/VCR
Proscan vcr plus gold stuck in lock
I just had the same problem and found a solution on the internet that worked. Hopefully you still have the VCR's remote control. Press and hold either the on/off, VCR1 or VCR2 button on the remote. I pressed the VCR1 button and held it for about 5-7 seconds. It released the lock and worked fine afterwards. The lock is some kind of childlock devise.
Mar 10, 2008 | Proscan PSVR73 VHS VCR
"SAFE"
Greetings Spock! Although I worked for an authorized rca service depot for 12 years, and worked on many, I can't remember the solution to your problem, and Thompson Consumer Electronics (RCA/GE) don't even accknowledge they ever sold vcr's..I went to RCA.com and your model comes up as "does not exist"...Anyway...I know I've worked on that model, and if you have the book, check the section about parental lock, or Key lock...your RCA could very well be Samsung inside, and if so press and hold the tv/vcr button for 5 seconds and that will release the key lock feature. It is there so if you set the timer, or just don't want the kids messing with it, you can lock all the key functions, and the unit will do nothing except display "safe" Hope this helps...Live long & prosper!
May 03, 2007 | RCA VR557 VHS VCR
Samsung vr3607 vcr is locked
following is pasted from SV-7000W manual: 1 To lock the VCR, hold down the P/STILL (II) button for approximately five seconds. Result: The lock indicator (LOCK) is displayed. If a cassette is in the VCR when you lock it, the cassette will first be ejected. 2 To unlock the VCR, hold down the P/STILL (II) button again for approximately five seconds. Result: The lock indicator (LOCK) is no longer displayed. If that fails, try the same thing using the play/stop button. Cheers
Nov 13, 2005 | Samsung VR3607 VHS VCR
Televison & Video Logo
135 people viewed this question
Top Televison & Video Experts
