Question about Home
Hi I bought a CITIZ machine from nespresso 110VW, but my husband turned into a 220VW and of course it is not working anymore. What parts should I change ? Can I take it to fix somewhere in Orlando, FL ?
  • patricia_552 Oct 06, 2010
    Hi
    thanks a lot, so they fix nespresso machines ? Can you confirm to me if this problem can be fixed ?
    Tim Thanks thanks !!!! This site is unbelievable, 10 ! I recommend to everybody ! best regards Patricia
    President:
  • 2,777 Answers
I see, that is a major problem for sure. The main problem is the manufacturer is in Switzerland. You are going to want to go to the following place close to you for help:
Southern Electric Co
510 N Parramore Ave, Orlando, FL (407) 841-8824
Posted on Oct 05, 2010
  • Tim Grayson
    Tim Grayson Oct 06, 2010
    Yes they fix them and yes this problem can definitely be fixed.
    Thanks
    Tim
Can't remove water tank krups nespresso citiz
Open led and pul tank out if not try doing descale it may have got stuck from solts
Jan 03, 2014 | Nespresso Citiz D110
CitiZ swap outside casing
I've stripped the casing from this model and it isn't difficult, though you do have to be careful. You should check out the Service Manual for the machine to first to decide if you're up to the job. The service manual is readily available online, just Google, 'Nespresso Citiz Service Manual' and you should get it in PDF format. The manual explains the process for dismantling and re-assempling. It also conatins wiring diagrams for all versions. It looks like the casing is the same, regardless of country. When I stripped mine, I didn't have the specialist Nespresso tools for the job, but carefully inprovised using small pliers instead of the special oval screw driver. BEWARE...any remaining warranty will be invalid if you carry out any work on the units!
Jul 23, 2013 | Nespresso Citiz C110
Won't turn on
Nespresso machine won't turn on
May 12, 2012 | Nespresso Citiz D110
No water, flickering lights
might have a lose wire inside the unit, do the wiggle test, take the unit apart and wiggle the wires they should all be attached firmly if you find one that is lose that's the one and he needs to be tightened up or replaced with a new terminal.. jay the pool pump motor repair guy in longwood Florida
Feb 03, 2012 | Nespresso Citiz C110
No coffee comes out, only water despite capsule inserted. Capsule doesn't pierce at the front.
Hi Sandrine, i have the same problem with my Citiz paris limited edition. Did you find a solution to that?
May 28, 2011 | Nespresso Citiz D110
Hi got a krups citiz nespresso machine it keeps on falshing and don't heat up
many times if you call the company they are all to happy to help you out. Or email them of course. I just phoned the company that I bought speakers from and said my cat ate the wires and they are giving me a new set for free!
May 17, 2011 | Krups Coffee Makers & Espresso Machines
My Nespresso citiz lungo button will only give expresso amount of water
Ok, what you have done is programmed your machine. If you hold down the button for 3 secs you get 3 secs of coffee, so turn on your machine wait for it to warm up then without using a capsule press and hold the button until you get 110mls for a lungo and this will be stored in the memory. If this doesn't work there is a on/off switch on the right handside turn it on with your finger down on the lungo button for 5 secs and then release the button and this will take it back to factory settings.
Jan 13, 2011 | Nespresso Citiz D110
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
