Question about Smeg 24 in. DWI612 Built-in Dishwasher
My dishwasher want run any cicles
Half way through cicle it started leaking,it looked blocked inside so cleaned it all out but now it will not allow me to start a new cicle it stays on two lights sound as if its trying to drain but will not take in any extra water then just stops on two lights.please help me and thankyou very much for your time.Jill
  • 426 Answers
Check the out flow tube and see if its blocked..... if its not see if the food grinder in the bottom is blocked
Posted on May 28, 2008
Whirpool dwf 407 restart cicle
I need more info but it sounds like the main contact or board relay is stuck or short together sound the unit is always powered.
Apr 01, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
Coffee holder cup blocked
The same just happened to me, thus, looking for a replacement filterholder.
Jun 12, 2013 | Ariete Cafe Retro Espresso Machine
Makes noise during wash cicles and dishes are not cleaned
Hi Kenneth Cho - I will suggest verifying that there is enough water pressure coming into the unit. Is the unit making a grinding noise? If it is, then the dishwasher seems to have a defective drain motor. When was the last time the filter was cleaned? Do you noticed if the spray arm will rotate freely or if it is damaged? If so, you might have to remove and replace the spray arm assemblies. If any proves to be ineffective, it could possibly have a communication problem coming from the main control board, I would suggest contacting a professional technician to diagnose the unit accurately.
Nov 24, 2012 | Frigidaire FGHD2433KF Builtin Dishwasher
When washer is discharging its water it comes out the air vent, the inside of washer is dirty. What can I do to fix the problem. Thank you ...
You need to take back of dish washer off unhook the drain hose and clean that hose good with soap and water or companies recommandations for cleaning hose and as for inside being dirty use a disinfectant clean the inside out and then after hoses are put back on and back is back on run dishwasher with no dishes and no soap for one cicle to rinse and test unit.
Oct 09, 2010 | Kenmore Dishwashers
2600 HP HAS NOT BEEN USED FOR SOME MONTHS. HOW TO CHECK INK SUPPLY?
1st use printer clean cicle or computer clean cicle ( on printer driver in utils menu)
normaly the ink only stays fresh for a few weeks without use, above 30ºC only a few days, printer dont know exactly how mutch ink available, only used and estimate ink level, evan dry ink cardrige. Better use a new ones and force replacement cicle.
Dec 22, 2009 | HP DeskJet 2600 InkJet Printer
The machine do not complet the cicle.in the regular cicle, the machine finnish washing but do nt let out the water and the cicle stop at this point
have a look and see if outlet pipe is kinked not allowing water to drain, failing this you may have a blockage in the pump system
Dec 17, 2009 | Washing Machines
My dishwasher is leaking from the conors and sides
I replaced these black corner gaskets and it still leaked.....GOOD LUCK!
Nov 03, 2008 | GE Nautilus 24" Built-in Dishwasher
Flashing lights
You have a heat problem, using a test meter check the heater element, then check the thermostat if niether of these you have a PCB fault Regards Engineer
Mar 15, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Smeg 24 in. DWI612 Built-in Dishwasher Logo
293 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
