Question about LG Washing Machines
I am so unhappy about the mold problem in the door gasket of my LG Tromm washer. I keep the door ope to ventilate, I dry it out, STILL mold and slime! I periodically bleach the washer to disinfect...still the mold will not come off. You can scrubb visible areas, but what about the internal parts? I feel as if the environmental people who insisted that we all buy front-loaders were really stupid! How can this be good for my clothes, my family or the environment? Are there any fixes for this problem???
  • 205 Answers
Hello- Well, you are not alone in your frustration and the only real solution, unfortunately, is to replace the gasket. As far as the internal parts I have rarely seen mold growing on those parts (in any front load washer), most of the the internal parts are hard plastic and stainless steel and these do not seem to allow the mold to grow even though they are wet a lot of the time. The internal hoses as well do not seem to have this problem. Though it gives little solace or immediate remedy I do think the manufacturers are going to have to come up with a rubber formulation that is not such a friendly environment for the mold. Considering the number of these gaskets, door boots, I have replaced over the years there must be some real issue with the engineering of this rubber or else they would have found a solution years ago. You could try contacting LG and asking them to replace it for free or at least send you the part for free. It usually takes a Tech about an hour to replace. Best regards.
Posted on Oct 05, 2010
Why is the door gasket on the Tromm washer has mold on it ?
Clean with a washer cleaner solution you can buy from supermarkets.
Jan 12, 2014 | LG WM2277H Front Load Washer
Washer problems door gasket mold
Clean with cleaning solution you can buy from supermarkets.
Jan 12, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
How do i get the mold out?
A lot of times liquid detergent and liquid fabric softener will cause this. Dry the door seal after use and leave the door open. Don' t use bleach if you're on a septic system. There are products that are septic safe to clean the mold. Powdered detergent and not closing it up after using should help a lot
Mar 01, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Rubber gasket removal LG Tromm front loader
We found there is three small holes on the seal right inside the door, check to see if they are clogged with soap scum and clean them out. Run a cycle of hot water and bleach. Then, after each use, leave the door open and let it air dry and this has seem to work.
Jul 06, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Mold in rubber ring front loader Fridgidare washer
Common problem. Clean the moulding as best you can, even scour with steel wool. Leave the door open so the machine will be dry when not in use or/and wipe the rubber after each use. You can try to cover up the odour by wiping with a rag moistened with vanilla essence. Otherwise fit a new rubber and keep it dry in future.
Jul 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Odor coming from inside washer
There is a tub beyond the tub you see. Run a load of water with chlorine bleach. This will kill the mold & mildew spores that are causing the odors. ****Do NOT add clothing to this washload****
If possible, keep the door open when not in use. This will allow the inside to dry and mold & mildew cannot grow.
Jul 02, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washer stinks - smells like mold or mildew
You have to kill the mold. To do that mix one cup of clorox liquid bleach into one quart of water and wipe all aroung the rubber. Let it dry and do it again. That will solve your problem
Apr 29, 2009 | LG WM2688HWM TROMM SteamWasher
LG Tromm
Place a good level on the top of the machine where it is flat. Check front to back and side to side. Level machine exactly. Now put a load in and when it spins feel the feet for any that are not solid on the floor. Adjust the foot down until the machine stops shaking.
Apr 08, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG TROMM - awful smell while washer is running
Use the aafesh tablets as instructed, this will clear hoses that have developed some mold, also inspect drain at the wall, these get moldy and as machine runs, smell comes out of there as well.
Jan 20, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
143 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
