SOURCE: 190cc 3in1 briggs and stratton mower wont start...
Take the carburator apart and clean it. Also, clean needle and seat. Please let me know if this helps.
SOURCE: white smoke and oil spewing out of troy built
Check your oil level. If it is way over full, smell it to see if it smells like gasoline. If it does, you have a carburetor leaking gas into the engine crankcase. If you recently had the mower over on its side for blade changing or inspection, you have gotten oil up on top of the piston and it should burn off in a few minutes of running. Check your air filter to see if it is soaked with oil, replace it if it is.
SOURCE: LOOKING FOR A MANUAL FOR A 21" CUT SELF PROPELLED
try putting your serial number and model number here. http://www.troybilt.ca/troybilt/troybilt_manual_search.asp
SOURCE: My 22" cut toro lawnmower with its 190cc Briggs
You may want to check valve clearance, sounds borderline. You should have 11/1000s on the exhaust valve.The exhaust is usually the culprit, since it runs hotter.
SOURCE: My Toro lawn mower runs
The following website has a lot of information about Toros:
http://www.ehow.com/toro-lawnmower/
You've done most of the things, except you didn't mention ceaning the air filter, but perhaps you incuded that cleaning the carb. You could have a cracked gas hose,
This page might be of help to you also:
http://www.ehow.com/way_5890404_toro-lawnmower-gets-hot.html
Good luck, and hope this helps you out.
