Question about LG 42LC2D 42 in. LCD HDTV
My lg tv will not turn on i cant even get it 2 the stand by lights.?
POSSIBLE STARTER BOARD HEAT UP WITH HAIRDRYER TH ASSIST THE SOLDER FLUX FLO
Posted on Oct 06, 2010
I have a 2-1/2 year old LG 60LB7100 TV. When I turn the TV on I get the Lg logo and sound but then I loose picture.
The back light driver can be incorporated in either the power supply board or the main board (model specific). Contact these guys and they will make sure you get the correct part. TV Parts Universal TV Stands DLP Chips ShopJimmy
Jul 28, 2017 | LG Televison & Video
Model LG 42 PX3RVA ZC Hi I have a lg plasma, bought in 2005 new. I know it's old.. But was working well until a couple of weeks ago. Picture would flicker initially when turned on, then as tv "warmed...
With no stand by light, you are not getting power.Unplug TV and check fuse on power supply. You will need a meter to look for shorted components and possibly leaky/bulged capacitors that are killing your power supply. flickering could be part of the bad power supply or possibly a problem with YSustain area of your TV
Feb 15, 2014 | LG Televison & Video
TV switches off automatically.
if you take the cover off, then take a look at the capacitors.
check if any have bump ..
Jan 13, 2014 | LG Televison & Video
What should i do is my LG 42LC2RR's stand by light keeps blinking but it does turn on
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 04, 2012 | LG 42LC2RR 42 in. HD-Ready LCD TV
Wont power on
some tv's always have standby light on, even iff you turn off by tv button. solution 1: with light on, press a number on remote. solution 2: with light on press stand-by button on remote. solution 3: with light on push the 'on' button on the tv set. solution 4: unplug tv set, wait a few seconds then plug back in, if no light then turn on tv using button on the set, and then channel number.
Jun 25, 2012 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
My tv turned itself off and not even the stand by light was on. i unplugged it and changed the lamp. when i plugged it back in the stand by light came on but the tv doesnt. under the stand by light is a...
when you turn TV on, watch to see if the Lamp Fan is running,if it stops when Lamp trys to light then set will not come on.which then means Lamp Fan is defective.
Nov 24, 2010 | LG RU-52SZ51D 52" Rear Projection...
Lg tv turns off after a few seconds, the screen lights up but doesnt even say no source....
hi i have a lg 42lc46 and it wont turn on from stand by it just goes blank and the red light disappears can yiu help
cheers
mike
Apr 06, 2010 | LG 42LC2D 42 in. LCD HDTV
37'' LG lcd tv, no power
I just want to clear things here.
The stand by light will remain on whenever the tv set is turned on by a button on the side of the tv.
Then use your remote to turn on the tv, but wait as it can take 10secs before you get a picture.
Nov 04, 2009 | LG 37LC7D 37 in. LCD HDTV
The screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
If you broke one of the base stand screw you will need to do as follow:
Remove the remaining screws of the stand and try to remove the stand, if you cant you will need to remove the back cover of the TV and then you will be able to remove the stand, remove the broken screw and put it all back.
It is pretty easy but if you feel you cant do it let me know and I can give you a detailed step by step guide.
May 26, 2009 | LG 42LG30 42 in. LCD HDTV
TV screen turned on for only 10-15 secs then self turn off, followed soon after by the tv power another 10-15 seconds later. if i try this a few times screen wont light up at all.Is it the TV Lamp?
1) Can be dust do a good clean
2)Check for the fuse and change it if needed.
3) Capacitor needs to be changed, you'll have to findout which one.
Hope it helps, good luck
May 19, 2009 | LG RU-52SZ51D 52" Rear Projection...
LG 42LC2D 42 in. LCD HDTV Logo
57 people viewed this question
