Question about Dewalt & Variable Scroll Saw
The brake on my dw713 dewalt saw doesnt work - Dewalt & Variable Scroll Saw
5 Suggested Answers
  • 225 Answers
SOURCE: My 10"Dewalt drop saws brake no longer works. I've
when you changed brushes did you clean the armeture,should be bright an shiney,if yes then go to basics check imput power to on off switch,if yes check on n off switch is working right.check wireing while there(for broken wire ,loose wire)if all checks out ok i would look at armeture and windings.
Posted on Jun 27, 2009
rowdy45176
  • 2176 Answers
SOURCE: DEWALT DW705 MITER SAW BRAKE DOES NOT WORK
Could be worn brushes, dirty commutator or a combination of both. Unplug the tool and remove one brush at a time noting the condition and length. Use a flashlight look into brush tube and also not condition of commutator. I would blow is out with compressed air and you can try turning the brushes 180 deg and retry. That is usually the problem
  • 288 Answers
SOURCE: I have a dewalt 706 miter saw and the blade brake
this is a replaceable part and they do wear out
Posted on Nov 27, 2009
  • 98 Answers
SOURCE: dewalt 7790 radial arm saw with lectrostop.
sounds like a electro magnetic brake, needs adjusting or replacing.
Posted on Mar 04, 2010
Hello. I have an older Dewalt sliding power miter model 1707, type 1. The switch burned up and is now listed as obsolete. What are my options beside buying a new saw?
there are switches on the market that will fit
E-bay has an endless array of switches that you can adapt to the job
don,t touch the brake switch as that may just save your fingers in the future
Dec 13, 2017 | Dewalt Saws
Product just arrived, saw is stuck in cutting position
There is usually a safety or transit lock or pin which is engaged to lock the saw down for safety and for a more convenient way or transporting it.
The ones on my saws are a simple ball-headed pin sited close to the hinge of the saw which can be easily withdrawn once enough downward pressure has been applied to the saw to overcome the return spring pressure.
Mar 15, 2015 | Dewalt DW713 NA 10" Compound Miter Saw
How to take off the pin that hold the ajustment lever on a DW 713 Dewalt Miter saw ?
I would use a hammer and a smaller diameter punch than the pin. Take a few wacks and see what happens. If it is rusted soak it with something like liquid wrench over night.
Oct 07, 2014 | Dewalt DW713 NA 10" Compound Miter Saw
When I switch saw off the blade keeps running for a minute until it finally stops think it's the brake?
Obviously the brake is not working..
On most saws the brake is an integral part of the motor and to get it working you will have to replace the whole motor..
If you chose not to replace the motor ... the motor will still work just fine, but you will need to be extra careful using it...
heatman101
Jan 14, 2011 | Dewalt Saws
Can't find my owners manual. How do I change the blade. Bolt hits on a guard that covers the arbor. On a DW713 combination saw.
Removing the Blade
1. Unplug the saw.
2. Raise the arm to the upper position and raise the lower guard as far as possible.
3. Loosen, but do not remove guard bracket screw until the bracket can be raised far
enough to access the blade screw. Lower guard will remain raised due to the position
of the guard bracket screw.
4. Depress the spindle lock button (Fig. 3) while carefully rotating the saw blade by hand
until the lock engages
5. Keeping the button depressed, use the other hand and
the wrench provided to loosen the blade screw. (Turn
clockwise, left-hand threads.)
6. Remove the blade screw, outer blade clamp, and
blade. The inner blade clamp may be left on the
spindle.
Installing a Blade
1. Unplug the saw.
2. With the arm raised, the lower guard held open and the
guard bracket, place the blade on the spindle against
the inner blade clamp with the teeth at the bottom of
the blade pointing toward the back of the saw.
3. Assemble the outer blade clamp onto the spindle.
4. Install the blade screw and, engaging the spindle lock,
tighten the screw firmly with wrench provided. (Turn
counterclockwise, left-hand threads.)
5. Return the guard bracket to its original position and
firmly tighten the guard bracket screw to hold bracket
in place.
WARNING:
• The guard bracket must be returned
to its original position and the
screw tightened before activating
the saw.
• Failure to do so may allow the guard
to contact the spinning saw blade
resulting in damage to the saw and
severe personal injury
you can download a manual at: http://www.dewalt.com/tools/machinery-miter-saws-dw713.aspx
Jul 20, 2010 | Garden
Dewalt 7790 radial arm saw with lectrostop. the saw dont brake
Mar 02, 2010 | Dewalt Saws
Jun 27, 2009 | Dewalt DW703 10" Compound Miter Saw
Dewalt & Variable Scroll Saw  Logo
65 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
Craig Butler
Craig Butler
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
