Question about Panasonic NN-S262SF Microwave Oven
Panasonic NN-S262SF stops cooking after 3 seconds
I can set any cooking time and it runs for 3 seconds and stops as if the time had run out. It doesn't even say Enjoy (a bit of honesty there). Otherwise the fan, lights and messages work fine -- cooking is the only thing it doesn't do. Hate to throw it away (and mount a new one) if I could find the part to change. Thanks!
  • panicsonic Jun 12, 2008
    Very similar problem. Microwave stops after 2 seconds. Power is getting to panel but not to light over stove or inside oven. Fan grating is stuck in open position. This is an over the stove unit. Is it the magnatron? the inverter? something else?
  • Anonymous Jan 08, 2009
Inverter problem the transistor 1M30D is shorted
Posted on Jan 07, 2009
I just had mine fixed and it was the Magnatron.
Posted on Jun 28, 2008
My panasonic microwave NN-S954WF will run a few seconds and then stop. What should I check?
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 7 seconds, it has a problem with the inverter.
If it stops at 2-3 seconds, see if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt http://031d26d.namesecurehost.com/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Nov 16, 2011 | Panasonic NN-S954WF Microwave Oven
I have a Panasonic microwave convection that runs for 2 or 3 seconds, then cuts off. It doesn't matter what setting or length of time you program into it, it will run a couple of seconds and shut down. Is...
See if this describes what's happening:
If so, see http://207.234.249.73/mwd/safety.txt , http://207.234.249.73/mwd/disassembly.txt and http://207.234.249.73/mwd/doorsw.txt
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Sep 08, 2010 | Panasonic NN-C994S Convection/Microwave...
Panasonic NN-S254BF microwave oven runs for 2-3 seconds and then shuts off'
May 31, 2010 | Panasonic NN-S254BF Microwave Oven
My 4yr old NN-S262SF OTR runs for 2secs and stops whenever start
Hello
Microwaves use alot of power and should be on their own 20amp circuit. Get an electrician to put the microwave on its own circuit.
John
Nov 25, 2009 | Panasonic NN-S262SF Microwave Oven
Comes on for 5 Secs
Hi I am Vortash sounds to me as if the Magnetron is burning out and the heat sensor switch is turning the unit off as the mag gets hot ? .. you can get a cheap replacement of ebay but to be honnest microwaves are so cheap now you will probably get an oven for what you would pay for a new magnetron .. Regards Vortash
May 20, 2009 | Panasonic NN-S262SF Microwave Oven
Shuts off but everything else works
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
Nov 08, 2008 | Panasonic NN-S542 Microwave Oven
It stoped
Nov 01, 2008 | Panasonic NN-S542 Microwave Oven
Panasonic Model NN T964SF inverter microwave runs for less than 5 seconds and shuts off. Power control function does not work either. Pressing power control a number overrides cook time with power...
In most cases, this is a problem with the inverter or a bad magnetron.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 02, 2008 | Microwave Ovens
Panasonic NN-S262SF Microwave Oven Logo
612 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
