Question about Spark Plugs BR4HS Plug 10/BX #3322
What is the spark plug gap 2002 harley fat boy
2 Suggested Answers
  • 2692 Answers
SOURCE: SPARK PLUG GAP NGK BPR5E PLUG
Fix Ya?
Posted on Jan 12, 2009
Why are my Harley Fat Boy rpm's unstable with Caltex petrol at sea level?
Hi, Eric and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking check for spark leakage in the dark
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP or CMP, MAP, ETS, ATS, TPS, O2 sensor.
9. Dirty air filter.
10. Intake air leak.
11. Water, dirt, or rust in the fuel system, carburetor and/or filter.
12. Old dead or bad fuel.
13. Fuel tank vent system plugged or carburetor vent line closed off.
14. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
15. Carburetor controls misadjusted.
16. Damaged carburetor.
17. Incorrect valve timing.
18. Weak or broken valve springs.
19. Damaged intake or exhaust valve.
20. Check for engine trouble codes
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have nice a day.
2015 2017 Harley Davidson Fat Boy Fat Boy Lo Fat Boy
Harley Davidson Manuals Mark Workshop
http://partsfinder.onlinemicrofiche.com/stcharlesharleydavidson/showmodel.asp?make=hdmc
https://serviceinfo.harley-davidson.com/sip/vehicle/lookupForm
How 6ya Works 6ya A must have !!! Totally "FREE"
Dec 29, 2016 | Harley Davidson FLSTF - FLSTFI Fat Boy...
Do i have to use harley spark plug for 1999 hd fatboy
Hi Anonymous, the simple answer is no, just make sure the non Harley spark plug that you use has the correct heat range, thread type and length, radio resistant, and correct gap. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 02, 2014 | 2003 Harley Davidson FLSTF Fat boy
It misses at low rpm
Hi Anonymous, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals,
ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust vale.
For a prime suspect please visit website below and good luck:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Jun 14, 2013 | 2002 Harley Davidson FLSTF - FLSTFI Fat...
02 fat boy backfiring and won't idle
Hi Chuck_brock, and the usual suspects are:
Aug 10, 2012 | 2002 Harley Davidson FLSTF - FLSTFI Fat...
2000 hd fat boy no spark to spark plugs
HAVE THE COIL CHECKED, IF NOT LOOK FOR THE GAP OF THE BREAKER POINTS.
Jul 31, 2012 | Harley Davidson FLSTF Fat boy Motorcycles
99 harley davidson fat boy spark plug gap
Hi Anonymous, HD 6R12 spark plugs are gapped at .040" Have nice day.
May 21, 2012 | 2000 Harley Davidson FLSTC Heritage...
What spark plugs for harley 2004 fatboy do you use
Hi Anonymous, the HD 6R12 spark plug is gapped at .040" Have nice day.
May 11, 2012 | 2004 Harley Davidson FLSTF - FLSTFI Fat...
Harley Davidson 2003 FLSTF Fat boy spark plug number
May 09, 2012 | 2003 Harley Davidson FLSTF Fat boy
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
216 people viewed this question
Top Ngk Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
