Question about Craftsman Grinders
Need wiring diagram for Craftsman bench grinder model 397-19581
joboo1
  • 257 Answers
SOURCE: older sears bench grinder wont run 1/3 hp model 397 19581
Hi again, OK, Well since I don't have a wiring diagram and the colors don't help. I am also going to assume it is 110VAC. The larger wires are probably the run or primary, it you remember which ones were connected it will help with polarizing. ( getting it to run in the right direction as well as the start and primary working together). You can use the two terminal switch but you should use a three wire cord. Use the switch to break the neutral and ground the case. The connections should be as follows: Connection 1, would have one of the primaries and one of the starts to neutral. Connection 2, the other start to the relay. Connection 3, the coil side of the relay to the remaining primary. ( if the relay has two connections on one end and one on the other it would be the single) Connection 4, the 3rd position on the relay to hot. That is how a split phase is wired. You may find a simple wiring diagram on the net if you type split phase motor wiring diagram. Good Luck to you, this should Fixya!
Posted on Mar 04, 2009
  • 718 Answers
SOURCE: switch and capacitor crapped out on 1/2 hp Sears bench grinder
Replacement should be simple. Just do a one for one hookup with the new part, after you unplug it first.
For a diagram go to;
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=397.1949&productCategoryId=0721000&brandId=0247&modelName=CRAFTSMAN-1%2F2-H.P.-GRINDER&diagramPageId=00001&documentId=00023041&pop=flush
Posted on Mar 28, 2009
Can you get a replacement? If not, we could probably figure out some suitable substitute.
Charlie
Posted on May 31, 2009
rowdy45176
  • 2176 Answers
SOURCE: need manual for craftsman bench grinder model #
Mike, just found your request and went to Sears and the manual is no longer available either to download or buy. Also more than half the parts are no longer available for the grinder.
Posted on Jul 18, 2009
Looking for a on/off switch for a craftsman 8" bench grinder
Sears Craftsman is usually easy as Sears Parts Direct has diagrams and part numbers.
However your switch number 31919063033 is no longer available. I would suggest checking out online places like Digikey or Newark for a switch that will work for you. As long as the Voltage, amperage and number of poles and will fit in the space provided you should be OK.
Link to Sears Parts Direct.
Searching Model For Search Your Way 31919063 2
Link to Newark
Switches Relays 60 674 Products Found
Link to Digikey
Electronic Components
Aug 19, 2014 | Craftsman Grinders
How do I remove the wire brush form a model 9410 grinder?
An ajustable wrench for the 'wire brush end' nut,and a visegrip type plier for the opposing wheel end. Wrap the jaws of the visegrip pliers with tape to protect the spindle opposite the wir wheel. Loosen the nut on the wire wheel end,counterclockwise.REMEMBER: lefty loosey-righty tighty.
Jul 22, 2010 | Craftsman 6" Bench Grinder with Lamp
Model 397.19471 need switch but can not find. please help? 8 inch bench grinder
Call the Sears Craftsman help line they will have the parts you need
Apr 02, 2010 | Craftsman 10" Bench Grinder
I need a replacement switch for a craftsman 1/2 HP bench grinder model#397.19441. I have no owners manual or parts list. This grinder is several years old.
this switch is no longer available from Sears, so I suggest making a wiring drawing and taking the switch to a local electrical supply house and try matching it up with a replacement. It seems to be a simple on/off type switch and I would think that you should have no problem. Let me know if you do and give me the information on the switch and I will try some other sites I know.
Dec 28, 2009 | Craftsman Grinders
Craftsman manual for Model 21126 6" grinder
What do you need a manual for? It's a grinder, grind something!!
Sep 09, 2009 | Craftsman 6" Bench Grinder with Lamp
Need manual for craftsman bench grinder model # 257.191300. misplaced other one. hope you can help. mike
Mike
Not sure what was happening when the previous reply was created, but the owners manual is part number 211260001 $7.99 at SearsPartsDirect.com
That said, I'm staring at my own copy of the the owners manual and I can't really see why you would want to pay for one. The only really useful information is the parts diagram which is online at SearsPartsDirect.com. The rest is generic grinder information (support workpiece, select proper wheel, etc.) and CYA (always wear gloves and eye protection, don't remopve safety guards, don't use damaged wheels, don't stick your finger in the light socket, don't cross the steet in the middle of the block, etc.)
Jun 07, 2009 | Craftsman 6" Bench Grinder with Lamp
Grinders Logo
390 people viewed this question
Top Craftsman Grinders Experts
Lawrence Oravetz
Vernon Taylor
ray gallant
Are you a Craftsman Grinder Expert? Answer questions, earn points and help others
