Question about Lexmark X2500 All-In-One Printer
My all in 1 printer
I have installed my printer but when i try to use it a error report comes up why
  • 1 more comment
  • anna1973 May 28, 2008
    please help
  • mitch5293 Jun 05, 2008
    you need to install windows vista update kb940199---then uninstall lexmark driver,2--reinstall lexmark driver. should be working now.rember you cant receive or send fax on dial-up if you are already connected to internet(your modem can only do one thing at a time).you must be disconnected from internet before you can send or recieve a fax.also windows vista service pack 2 or higher is not compatible with lexmark 2500 at this time.lexmark is working on this problem.if you have downloaded service pack 2 or higher contact your computer manufacturer they will help you restore your computer back to it original state at the time of purchase,but you must specify that.
  • Michael Barnett May 11, 2010
    when you installed the printer, did you hook it up first, and then install the software?  Is it USB?
    Thanks,
I can not find were to put the cartridges on my 2500 pinter
Posted on May 29, 2008
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 171 Answers
First remove the software and again reinstall the software ,before reinstalling remove the usb cable from printer , when they prompt for connection for printer then connect the usb cable
    President:
  • 2,351 Answers
Hi anna1973, please list the error you are receiving. What operating system are you using?
Mike
2 Suggested Answers
  • 2326 Answers
SOURCE: error when trying to print
Can you please tell me the brand and model of your printer?
What errors do you see when trying to print?
Posted on May 06, 2008
Ls-c8100dn+ will only print error report
you might check if the installed drivers are compatible with your operating system and printer
Jan 10, 2012 | Kyocera Mita Office Equipment & Supplies
I Have a Ricoh Aficio 270 , There is a problem . A SC 544 Code Error is reported. How can I solve this Problem.
try to re install the program of your printer or try to install your printer in other pc.. if it work in other pc try to repormat your pc and re install the the program of your printer..
May 09, 2011 | Office Equipment & Supplies
L7780 I recieve a general error report when I try and scan to my memory stick
>> if u getting a general error report
>> try replacing both the printheads ..!!
>> else make a reset on the printer
[remove the power cable when printer is on, press # + 6 same time plug in the power cable, and wait till a msg comes on screen saying NVM reset..]
May 20, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Trying To Print From Internet Explorer
This error only comes when the thing or program you are using is not competent with your computer. In your case, it seems that the Driver of the Printer is out-dated or seriously corrupted. Try re-installing or try to find updates on the manufacture's website.
Thank you Sir, Have a nice day.
Sep 24, 2009 | Dell 924 All-in-One InkJet Printer
IN INTEL DG31 PRINTER PROBLEM
try to unplug the printer from the wall then plug it back in see if that helps
Nov 19, 2008 | Intel DG31PR Motherboard
Installation error reports
Go to this link to download a driver for your printer. Let me know if the drivers from that link work.
Nov 05, 2008 | HP Deskjet 3845 InkJet Printer
KODAK EASYSHARE 5300 ALL IN ONE ERROR REPORTS
To solve your this Issue, you need to clean install
the program, but to do that you need to call Kodak Technical
Support to guide you through the process... ^_^
Oct 24, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Does anyone know what a 102H error means on a Minolta Magicolor 2490MF please ?
The error code is a message from the computer to let you know there has been a problem reaching to an adapter or device. It indicates Port 102h register test error. It means you should try reconnecting the printer, and ensure you have the printer properly installed so that it does show up as the correct printer when you select the Start, and Printers. (Or when you go into Control Panel and then select Printers, to see the installed printers in your computer.)
If the printer is on, is completely properly connected, is properly installed and appears in the list of your installed printers, in your computer Control Panel, then possibly you have some problem with the actual whirring, paper-handling printer device. You may try shutting down your computer, after you save any unsaved work that you were doing, and close applications, and can properly completely shut off the computer by selecting Shut down, from the Start Menu. Also please disconnect any cameras and any USB hubs for this test, but keep the printer connected. No need to turn off the printer; leave the printer on. Power on the computer and recheck the status of the printer, to see if it appears in the list of your installed printers, in your computer Control Panel, and see if the printer appears to be available or ready to print. If the printer does not appear, check its connection again, move the printer USB cable to another USB connection on your PC if it was already connected, and recheck. If you still do not see your printer appear there, it seems you will need to try another USB cable or another parallel printer cable, and proceed to install the printer. See if the printer has any flashing indicator - lighted LEDs, and notice the colors, and any error message. Report any questions you have about getting the printer installed please. Report any questions or problems you have with understanding what the manual instructs you to do to resolve the reported error. Maybe the printer has just gone bad, died, become kaput.
Aug 01, 2008 | Minolta Office Equipment & Supplies
Error when trying to print
May 06, 2008 | Office Equipment & Supplies
Error Report
An error message referring to BRSVC01A.EXE appears after installing the printer driver on Windows® XP SP2 or Windows Server 2003.
You will need to update the program of the installed driver.
Click Here for update from brothersoft:
thanks
iqbal
Mar 27, 2008 | Computers & Internet
Lexmark X2500 All-In-One Printer Logo
65 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
