Question about Alpine Type-R SWR-1222D Car Subwoofer
Bump I have alpine mrp m1000 connected to two alpine type r 12s and a 100 farrad cap. For some reason it will bump, however it will cut out. The amp, cd player, and capacitor all stay on, but it just wont bump.
  • swny Jul 25, 2008
    the subs will turn on for like 30 seconds and then cut out. ive check all my wires and connections and all are fine. the protect isnt coming on for the amp. turn on the radio and they work for 30 seconds cuts out. turn off radio and turn it right back on and the subs work for another 30 seconds.
    Problem Solver:
  • 4 Answers
Hi i have had the same problem and it turned out to be a earth that firstly wasnt earthed properly and secondly it was not a big enough gauge wire.
I hope this helps
jeremy
Posted on Mar 13, 2009
If your using high level inputs try switching to low level inputs. it could be a short circut.
Posted on Nov 28, 2008
    President:
  • 3,130 Answers
What do you mean it will bump, then cuts out?, Then you say it just wont't bump? Does it cut out after you go over a bump in the road, does the speaker bottom out and cuts out? Please you need to be a little bit clearer with the fault. and the symptoms.
Posted on May 29, 2008
What is the best amp for one 15" alpine type r?
sub spec 250watts per coil you should be just fine I have 2 typr 15s on orion hcca 2500 1 and it kicks a$$ thats 1000 watts over the rated limits of the subs only shut the amp down once these subs can take a lot more power than they say just use your common sence with the volume and gain levels
Jan 31, 2012 | Alpine Type-R SWR-1242D Car Subwoofer
Ok i have a alpine mrp m1000 which is getting good power and ground and amp turns on no problem but there is no signal transfer from rca inputs to speaker outputs and no continuity between left and right...
OK, a few things to check. First, check the gains. This is the little knob next to the RCA input. You will probably need a tiny screw driver to adjust this. If this is not the case, then you may have bad RCA cables or the head unit is not sending the signal. Double check wiring at the back of the headunit to see if they are connected well. Hope this helps
Aug 17, 2011 | Car Audio & Video
Type rs not hitting
sometimes RCA cables to the amp can go bad give them a look-see they may need to be replaced. I doubt you have a problem with the speakers themselves. you may also check the ground wire to the amp, make sure it has a tight metal to metal connection
Oct 06, 2009 | Alpine SWR-1022D Car Subwoofer
Subs cut out at low volume no matter the settings
I'm not a complete audio expert but it sounds like somethings over heating or you have a blown out put bridge.
Jun 20, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Dont know what i need to install this stuff
Hello bighollywood,
To install the head unit without cutting or tapping into the vehicle wiring, you'll need a "wiring harness". The Metra 70-1782 here seems to be the one for your '96 Prizm.
For the sub(s), you'll need an amp and a wiring kit. My recommendation would be the Alpine MRP-M1000. It's currently on sale at Crutchfield for $347. Shipping is included and you'll also get an "installation guide" to help with the wiring. The M1000 requires 4gauge power and ground.
Hope this helps.
May 17, 2009 | Earthquake Sound TREMOR XR12 Car Subwoofer
My amp shuts off with my 12in w6's when i turn up the volume
oh no you need a more powerfull amp i recommend selling the one you have and upgrade to a bigger amp ive had the same problem or if not unbridge your amp so it dosent work the amp to much
Mar 16, 2009 | Jl Audio 12W6 Car Subwoofer
SWR-1242D wired at 4ohms
Hi!
Having to much power for a subwoofer is a veeeery good thing, it will provide a lot of control and quality sound to your sub.
But this sub is a dual voice coil at 2 x 4ohm so if you want to hook it up at 4 ohm u need a 2 channel amplifier running mono mode.
i dont recomend that you hook up in 4 ohm, its better to take some time adjusting the levels on the amp and the headunit.
This system has the potential to create a realy good bass sound if u tune it the right way.
Feb 10, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
Alpine Type-R SWR-1222D Car Subwoofer Logo
213 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jeff Turcotte
Jeff Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
