I have an Atwood 8940-111 DCLP furnace that will not run, i have checked all fuses, wiring and that i am getting 12v power to it, the fan will not even fire up.
5 Suggested Answers
  • 68 Answers
SOURCE: ATWOOD MOBILE FURNACE RUNS WHEN IT WANTS/
Check your furnace for power. will be 4 wires. power ground and 2 thermostat wires. Check for power at the time delay relay, if you have power there check for power going in the fan motor, if power in motor wire, motor is bad. If no power in motor wire and power going to circuit board take the 2 thermostat wire apart and wrap the 2 together comimg from the thermostat. Fan will stat in about 30 seconds. If it does you need a control kit in the ac. But sounds to me like you have a furnace problem.
Posted on Mar 19, 2009
  • 16 Answers
SOURCE: Goodman forced air gas furnace not firing
if your power vent moter is not running you should not have have glowing ignitor.Frist the vent moter must close an air prove switch in series with the idnitor .seems you have a stuck air prove switch.Its the one with a hose attached
Posted on Apr 07, 2009
heatman101
  • 43501 Answers
SOURCE: We have an Atwood 8525
Here is a tip that will help you try to figure out why your furnace is notworking.
BasicFurnace or Heating System Troubleshooting
heatman101
Posted on Apr 13, 2011
jmgldsmth
  • 2005 Answers
Atwood Excalibur 8500-III furnace parts can be found at:American RV ph.# 626-513-4777
an off balance or, wobbly fan can cause the screeching as can a combustion fan that has become loose on the motor shaft
there is a small notch in one of the fan blades a long 1/8" allen wrench goes into this and fits into an allen screw that locks the fan onto the motor shaft
there is a small hole just to the side of the combustion fan shroud this can be used to enter the allen screw on the fan's collar
if your furnace ignites then goes out
check your sail switch: it must be pressed and held down by the fan air before ignition can occur or, for the burner to continue to burn
the high limit switch should remain closed if it doesn't show continiuity with an ohm meter replace it.
Posted on Dec 15, 2014
I have an atwood furnace the fan runs constantly and the red light on the circuit board is solid red
Turn off power to unit and see if it resets . Check fan control , and check summer switch is not on .
Mar 18, 2018 | Heating & Cooling
Atwood 38591 Excalibur xt 1522 LP two stage furnace. Operates on high fan only
Hi Dave. I'm Roger. Its normal for a furnace to shut down completely when the set point on the thermostat is reached. The first and second stages are used when the temp. gets close to set point. The heat output drops to its low stage at around 3 degrees before set point. Check your owners manual for specifics on the fan though.
Mar 14, 2014 | Atwood 38591 Excalibur XT Furnace 1522 15K...
Atwood furnace rv
try to jump the r and w where the t- stat wires are maybe bad t-stat
Jul 04, 2013 | Heating & Cooling
Have atwood furnace and coleman mach thermostat and it would not shut off. I unplugged power to rv and had to hit battery disconnect so that it would stop.waited few minutes...turned on...heat would not...
It may be your thermostat, but try this first to see if time delay relay may be sticking. When it won't shut off, turn propane off, and go outside and unscrew the 2 screws that hold your cover on, and lower the cover down. Look straight ahead, attached to the housing of the fan up near top you'll see a square relay (time delay relay) with 4 male spade connectors, and wires attached to each. It's usually held on with 2 Philips screws. Give it a little rap with the handle of a screwdriver or similar a couple of times, and see if fan stops running. While your there as well, pull the wiring connector off the ignition board, and put back on a couple of times, to clean the connections. Now try it again, and let me know what happens.
Apr 23, 2010 | Coleman Mach III Air Conditioner
Atwood GCH10A-4E won't heat in electric mode. 12v power to circuit board no 12v power to relay. Is new circuit board only solution?
CHECK THE FUSES AND CIRCUIT BREAKERS IN THE CONVERTER BOX. MAKE SURE THE 110V SWITCH BEHIND THE WATER HEATER IS TURNED ON. IF THERE IS POWER AND "ALL" THE 110V SWITCHES ARE ON, TIME TO OHM OUT THE HEATING ELEMENT, LOCATED UNDER THE BOX BEHIND THE WATER HEATER.
IN ORDER TO HAVE 12V AT THE CIRCUIT BOARD, 112V POWER HAS TO GO THRU THE RELAY. SOUNDS LIKE U HAVE A WIRING PROBLEM SOMWHERE, EITHER AT THE SWITCH OR AT THE WATER HEATER SOMEWHERE.
Dec 07, 2009 | RTO Atwood Water Heater - 6 Gal LP
Jan 14, 2009 | Dometic Heating & Cooling
Heating & Cooling Logo
646 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
