Question about Brother MFC-5890CN All-In-One InkJet Printer
How to put A3 paper in brother mfc 5890 printer
bolinlamar
  • 157 Answers
SOURCE: brother mfc-440cn printer printing crooked
There is the possibility that the scanner assembly has jumped a tooth on the drive belt on one side so the scanner is just slightly crooked. To correct this the scanner assembly would have to be taken apart enough to correctly line the assembly back up. I wouldn't recommend that you try this yourself unless you have some experience at this sort of thing. Contact Brother for an authorized repair center near you for assistance.
Posted on Sep 04, 2009
  • 3 Answers
SOURCE: My MFC 5890 cn Brothers printer paper keeps getting jamed and won
What kind of paper are you using?
Normal paper or Photo Glossy paper?
If you use Photo Glossy Paper, you have to put at least two sheets of paper. If you read the photo glossy paper instructions that came in the package you will see it.
The package brings one sheet more than mentioned because of this specification.
Posted on Sep 17, 2009
  • 88 Answers
SOURCE: connected brother mfc 5890 to
?iknow a lot of people don't always install extended aballities because they ake up so much space but they are needed in these cases
Posted on Jan 22, 2010
pineworks
  • 4041 Answers
SOURCE: problem paper jam printer brother no mfc-490cw
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
SOURCE: Brother MFC-5890CN When I print on
hello I want print longer than A3, do you know any solve?
Posted on Jan 03, 2011
WHAT WAS THE STEPS TO FIX UNABLE TO CLEAN 50 MESSAGE ON MY BROTHER MFC 5890-CN
Open the scanner lid and close it again. this way you get a "reset" of error code and he continues to wok again.
Jul 07, 2014 | Brother MFC-5890cn Color Flatbed...
I have a MFC-6490CW and when i scan A3 it cuts off the sides of the page when i scan to file
Hi
Please select the auto select paper size option, if this don't fix your problem then go the paper option and manually select the A3 paper size and scan.
Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
Hello. I have a Brother MFC-6490CW A3 printer, and this morning I was printing and the paper jammed, I removed what I could manually however there is still some paper jammed that I can remove. The...
Hi Good day!!!
The paper jam you had probably lifted the long, thin, plastic encoder strip in the pathway out of its slot, giving the false indication of a paper jam. In order to put it back in its place, please carry out the following steps:
1) Lift the cover and remove the two plastic panels covering wires. Mark down the position of cables, then remove them, and remove the now-freed top scanner
section entirely.
2) Remove the screws from the top plastic shell. There's two in the back and four in the front. There's also two plastic tabs in the front that must be bent aside before you can remove the top shell.
3) Gently put the encoder strip back in its plastic guide, and check if you are able to get your printer to work all right thereafter.
If you are not comfortable carrying out the steps, I would strongly suggest you to have it repaired by your local Brother service center, without causing further complications.
Don't forget to vote thanks!!!
Nov 02, 2010 | Brother MFC 6490CW InkJet Printer
MY 5890 start printing a page and all of a sudden it spits the page out half printed or not completely printed. It only does it when i print not scanning or copying.
Please download the driver from the Brother's website and install the driver.The website address is :http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&prod=mfc5890cn_all&c=us&lang=en
Aug 05, 2010 | Brother MFC-5890cn Color Flatbed...
Brother MFC-8840D printer w/false paper jam indication.
With my Brother 8840D I have had paper jams that when cleared would not delete from the display nor would the machine operate until I unplugged the machine for around eight hours. I guess it is a sort of reset or reboot.
Jun 06, 2010 | Brother MFC 8840D All-In-One Laser Printer
Brother MFC 7340
If it is A4, it is too much paper and it is too heavy, it can damage the lift gear. Put half of quantity.
Feb 01, 2010 | Brother MFC-7340 All-In-One Laser Printer
Brother MFC-5890CN Printer
It sounds like your print heads may need cleaning. However, here is the link from Brother support for your MFC-5890CN on how to improve print quality:
Brother MFC 5890 Print Quality
Jan 14, 2010 | Brother MFC-5890CN All-In-One InkJet...
Mar 23, 2009 | Brother MFC-5890cn Color Flatbed...
Paper Loading
Do you mean MFC 210?
Simply put paper into the papertray which can be found infront of the printer (beneath the display). You can pull the paper tray out to configure the paper size. In case you still have trouble, download the handbook and the quick set-up instruction of your mfc from the brother homepage of your country as a pdf file. It explains some important issues of paper size and the handling.
Oct 17, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-5890CN All-In-One InkJet Printer Logo
397 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
