Question about Sony Xplod CD Player w/MP3 Playback CDX-GT50W
Buttons don't work but still plays cd
I have had my sony gt500 for about more than a year. today when i pressed the "source" button it didnt want to turn on. i pressed all the buttons for a response but none. i put a cd in and it started playing but i couldnt adjust the volume and every button still didnt work. I cleaned the connection from the faceplate to the main deck but nothing helped. any ideas what i should do?
  • pandaboi May 29, 2008
    i have tried that but it doesnt work. the only button that works is the off button wen it worked once nd after that it didnt work just showed the display.
  • 10,594 Answers
deattche the front panel and reattche it ;) hope it will work fine up to next year. :D
Posted on May 28, 2008
  • Shahid Electronics
    Shahid Electronics May 29, 2008
    well, I think, connector pins of front panel might be tilted or lil-damaged. give a close look there and clean that connector.
How to burn a Cd
The Sony MHC-BX2 can record from a CD to a cassette tape. This model doesn't have a CD burner. The manual for the MHC-BX2 is available from Sony support: http://esupport.sony.com/US/p/model-home.pl?mdl=MHCBX2&template_id=1&region_id=1&tab=manuals#/manualsTab . See page 12 of the PDF.
If your unit is a different model, please post a comment with that model number. I wish that I had better news for you.
(on those shelf systems that can burn a CD, place a blank CD-R or CD-RW (if supported) in the disc tray. Use the function button to set the recording source (Phono with the Croseley units). Place the tape to record in the tape deck and press play reach a point a bit before the desired point to start the recording. (Some also will record from the radio, turntable, or other device. Again start the source playing.) Then press CD Record. Press Stop when you want the recording to stop or when one side of the tape/LP is finished. (Some have a Split Track button if you want to identify every track. Press this during the silent period between songs.) Otherwise, you will get one track per side with tapes/LPs.)
Jul 10, 2012 | Sony Audio Players & Recorders
NEED operators manual for ITRR-501 retro 5 in 1. lost mamual. NEED TO KNOW how to record to CD Disc. Also will it record fro records to disc and record cassett to disk. PLEASE SEND me a manual. OR a zerox...
The unit will record to CD from the turntable, cassette or the AUX port. Place a blank CD-R or CD-RW in the CD tray. (Note: CD-RW discs may not play on other CD players.) Press the Phono, Tape or Aux button to select your audio source for recording. (For Aux, you will need to connect the source device to the AUX port in the back of the ITRR-501.) Wait for the CD disc to load and check for any indicator lights (you should see the "NO TOC" and "CD" or "CD-RW" lights lit). Select your Track increment (or Auto Manual for unattended track formation).Press Record button and the up arrow to adjust the recording level.
If you are recording from an LP, put the tone arm down on the record. For all sources, press Play. Press Stop to end recording or Pause to temporarily break the recording. Press the Track Increment button to advance the track number if you are doing so.
To finalize your CD-R to make it readable on all players: after stopping the recording, press the Finalize button.
The manuals for Innovative Technology products are available here: http://www.ithomeproducts.com/support . The products are listed in alphabetical order. The direct link to the ITRR-501 manual in English is http://www.ithomeproducts.com/sites/default/files/pdf/ITRR-501.pdf .
I hope this helps.
Sep 19, 2011 | Innovative Technology ITRR501 Audio Shelf...
I have a AIWA X204 CD in my car.I don,t know what I did, but the player doesn't answer to any comand. i push every one of button, but he don;t start to play.The screen it's light up,, and...
I think that's Demo mode.
I got stuck there too.
This is what worked for me:
  1. Power the radio off (hold the power button in top left corner in for several seconds)
  2. Remove face plate
  3. Hold in reset 10 seconds
  4. Press push-menu dial/button 3 or 4 times
  5. Insert cd and hit source to switch to tuner before cd starts
Not all of these steps may be necessary.
I suspect having the power off before the reset button was the important part.
Jul 26, 2011 | Aiwa CDC-X204 CD Player
I want to play my ipod on my sony cdx-gt500 how i can do it?
You are able to use your portable music device by following these instructions; plug in the portable music device and press the source key until you see AUX, then you will be able to listen to your music.
Mar 20, 2011 | Sony CDX-GT500 CD Player
My cdx-gt500 keeps losing it's memory how do i stop it
make sure the yellow wire is connected to a constant power source.
Oct 24, 2010 | Sony CDX-GT500 CD Player
How to record a cassette from cd on a sony xplod boombox cfd-g505
Insert a tape.
Select the program source you want to listen/record (CD).
Insert a cd, press stop.
Press record on the tape player.
Press play on the CD player.
The volume control or any audio emphasis buttons will not affect the record level.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CFDG505
Mar 17, 2010 | Sony CFDG505BLACK Xplod CD Radio Cassette...
I need to know how to get it on radio and change channels
hi there
if there is a source button press it till radio display is in screen if you press the source button it will switch from CD - tape - am/FM
to select the channels after this is done press left or right
hope i was able to help
Feb 16, 2009 | Pioneer KEH-P2030 Cassette Player
Sony NW-E105 doesnt turn on!
Yes, I also suffered from the some problem. Have any solution
Oct 09, 2007 | Sony Network Walkman NW-E105
Sony Xplod CD Player w/MP3 Playback CDX-GT50W Logo
346 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
