Question about Nokia 6230
Nokia 6230 keypad problem
Last night I started experiencing the following:
When I press the star (*) key it displays a 7, the 7,4,1 keys display correct.
This morning I experience:
When I press the star(*) key it displays a 4, the 7 key displays a 4, the 4,1 keys displays correctly.
Now from what I can deduce the only logical next step is that *,7,4 will in the afternoon start to only display 1 ;)
I removed the keypad and pressing the contacts (they are covered in a white material) I get the same result.
Now bare with me, every now and then I get a correct key response, but the result is minimal and the correct key response is very very intermittend.
Anyone have a solution?
  • the savage May 28, 2008
    I figured as much, I work near the coast and live 50 km from my job in a place much hotter.
    About 1 hour after posting this message, the phone stopped with its trouble and is functioning as it was designed to do.
    Another probable cause was my 1 year old son, he probably thought it would make a lovely chew toy.
  • 426 Answers
Sounds like the phone got wet or was left inVERY humid enviroment Clean ALL corrosion from the contact points and the back of the phone's logical key pad(where the electronics are) other wise get it replaced....
Posted on May 28, 2008
Red light display man and star
Ugay: on FixYa.com (older entries) they said,: Press the following buttons fast: #, interrupt, C, interrupt, C, 14, Start button. Another guy said: "change the main charger because based on my experienced it has an arching problem "
another said: "Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
press 14 and start key twice.
copier should restart normaly.
If not, then you have problems with the fuser
May 14, 2015 | Sharp Office Equipment & Supplies
When I press the central pad I get the message "now press*
This is to unlock the keypad ..press the central pad then press * to unlock the keypad.According to Nokia support the method used to activate a Nokia keypad unlock and lock mechanism while in stand-by mode is first to press the center scroll key, known as the 'navi key' followed by pushing the star key. This will either secure the keypad or render it usable depending on the previous state it was in.It is also possible to have it so after a certain period of time the keypad will automatically lock. To deactivate this feature follow the steps below:
1. First press the menu key2. Select the option 'settings'3. You will then need to select one of either Phone, Phone Settings or Device depending on the Nokia device owned.4. Choose Automatic Keyguard and select 'OFF'
If you still need my help, please provide more details about your Nokia problem (nokia model #, how the problem started, etc..)
Nov 13, 2011 | Nokia Cell Phones
How i repair the display of nokia 9500 at home
Switch-off your phone. 1. Press and hold 3
keys; Green dial key, *
Star key, no. 3 key on keypad and then press
the power on/off to
swtich on the phone. Remember, do not let go the 3
press and hold
keys until you see a formatting word screen show! 2.
After a few
minutes when the Full phone formatting completed, your phone
will
back to original system and factory settting.
Jun 16, 2010 | Nokia 9500 Communicator
This morning, all the buttons on the phone have stopped working except for 7, 8, 9. It was fine last night, and only this morning, I couldn't turn off the alarm on it and none of the other buttons are...
the power on/off to
press and hold
After a few
will
Apr 14, 2010 | Nokia 6234 Cellular Phone
Display ligh is not working
Full format solution for NOKIA
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Mar 10, 2010 | Nokia 6500 Slide Cellular Phone
No image display on cellphone
Just restore factory settings . Here is the way : Switch-off your phone.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory setting.
good luck . rate if useful please !
Jan 28, 2010 | Nokia 6610
Switches to "Quick Start" before I enter all information
The Maintenance Mode allows you to query and modify the basic settings of the Star Trac Pro
Stepper.
Engaging Maintenance Mode
Press and hold the0 , 2and OK keys together.
A beep will sound and the “MAINTENANCE MODE” will display momentarily in the information
window.
Release all keys. “SERIAL NO XXXXX” will display in the information window.
Modifying the Maintenance Mode
The following keys are used to modify Maintenance Settings:
Upper and Lower Data Information Window SCROLL keys: Display the next and
previous settings.
Increase and Decrease Level Keys: Adjust the value of the displayed
setting up and down respectively, in increments of 1 unit.
OK Key: Updates (saves) the value of the display setting in the Flash memory, and exits
Maintenance Mode.
The Keypad Test can be used to verify that all keys are functioning on the display assembly.
To engage the Keypad Test
Enter the Maintenance Mode (see Settings – Maintenance Mode).
Press until Keypad Test is displayed in the information window.
Press to enter the Keypad Test.
Press each key on the display. Each time you press a key, the information window will display
which key has been pressed.
To exit the keypad test, press .
If any of the keys do not respond, they may not be functioning and the display keypad must be
replaced.
Jan 23, 2010 | Startrac Fitness Products Sc4130 Star Trac...
When N72 mobile is switched on it doesnt start after the Nokia logo message and displays some different hacked screen
Oct 26, 2009 | Nokia N72 Cellular Phone
Nokia 3230 boot failure or cannot star-up
Do a Full phone formatting following steps below:
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your phone.
4. Press and hold 3 keys;
  1. Green dial key,
  2. * Star key,
  3. no. 3 key on keypad
and then press the power on/off to switch on the phone.
Do not let go the 3 'press and hold' keys until you see a the word 'formatting' is displayed on the screen
Aug 05, 2008 | Nokia 3230
N keypad sound, enhancement logo showing
The key sound problem:
Attempt the following:
1) Hit Menu
2) Go to Settings
3) Go to Profiles
4) Select General
5) Select Personalise
6) Scroll down to Keypad tones and if set to OFF select it, then using the centre button press right THREE times, then press the centre button to select.
7) Press Back
8) Go to Activate and Select.
NOTE: Follow this procedure for every profile you wish to use keypad tones for.
For the headset logo problem: (this is a temporary fix, you might need to have your phone checked or wait for another solution)
1) Hit Menu
2) Go to Settings
3) Go to Enhancement Settings
4) Select Headset
5) Select Default profile
6) Select Silent
NOTE: If this does not remove the logo, then you should follow the (instructions) above.
Regards
May 11, 2008 | Nokia 6230
Nokia 6230 Logo
365 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
