Question about Samsung SCX-5530FN All-In-One Laser Printer
Incoming faxes gets lost - Samsung SCX-5530FN All-In-One Laser Printer
  • 10 more comments
  • attagianno Oct 06, 2010
    Just to add that faxes result in the list reported but definitely not sent to the email box, although indicated so.
    Fax rings, the fax answeres, appeares to receive but nothing arrives to the maibox.
    Thanks
    Thanks Tim,
    I confirm is a Samsung SCX-5530FN and it used to receive them to a email.
    Thanks
    atta
    Yes I confirm your assumption and model. I wasnt sure if you had recieved my answer on that.
    atta
    Display also was indicating sending to email.
    Is a small network of 3 pc's. Nothing changed on printer setup. Still prints fax on paper and it also prints as before from the same pc.
    Is a normal network plug similar to the telephone, so no router or switch I suppose.
    thks
    atta
    Forgive my 'stupid' question. If I give a webmail address, independent of a mail server ?
    I suppose mail server is needed anyway to send the email. Sorry..
    is already restarted everything more times. I add also that initially the problem seemed to be resolved but then came back stable.
    Yes I know, is the same technician who was working on it these days. I should ask info to him about the mail server.
    Thanks
    atta
    Helpful and in time. I have to investigate to find the exact cause, but Tim was defenitely helpful in troubleshooting the issue.
    President:
  • 2,777 Answers
Can you please explain a little bit more, what do you mean by "they get lost"? Does it ring, answer the fax, appear to receive, and nothing ever really gets received?
Thanks
Tim
Posted on Oct 06, 2010
  • 6 more comments
  • Tim Grayson
    Tim Grayson Oct 06, 2010
    Ok you say nothing arrives to the mailbox... I am assuming it used to arrive at the mailbox just fine? Is this a Samsung SCX-5530FN? Does the display of the fax indicate it is storing the faxes in the printer? Please confirm, it used to receive them to a mailbox (email?) just fine, and the model number of the unit.
    Thanks
    Tim
  • Tim Grayson
    Ok something has happened to the network setup on the fax machine... either that or the fax mechanism in general has completely failed. Are you on a large network there or is it just a few computers connected together? Who set up the machine originally? It is very complex to go back through the network setup on the device.
    My guess is that if nothing has changed to your knowledge on the setup of the fax that it is actually starting to fail internally. Does it still print through the network just fine?
    Thanks
    Tim
  • Tim Grayson
    I did :) Did you see my other comment?
    Thanks
    Tim
  • Tim Grayson
    Ah ok thats some good information. That means something has happened to the network setup or connection on the printer then, it sounds like the fax mechanism is indeed fine. Do you have any idea if this printer is plugged into a switch... directly into a router... or how it's connected to the network?
    Thanks
    Tim
  • Tim Grayson
    Ok well that means something is either going on with the network connection itself on the printer, or the mail server that handles the mail coming from the printer. Try resetting your network equipment, unplug it for a good 30 seconds and replug it in. Give it a try then...
    If it still doesn't work you will want to contact whoever does your mail server hosting and see if the server is having problems or something. It appears this printer is working correctly, the mail just isn't getting to it's destination.
    Tim
  • Tim Grayson
    No problem, no stupid questions there, sorry for assuming you knew. Yes there is still some mail server in the process, it has to use something to send it to your webmail address. It is probably your internet providers mail server...
    Did you try resetting the network equipment, making sure it still has a solid connection to the printer?
    Tim
  • Tim Grayson
    Hmmm, so it was resolved, but then the issue returned? And you have reset the router and switches on your network? I would definitely say you should call / contact whoever is hosting the mail server. Do you know who set up this machine originally? They should know who runs the mail server that it's using.
    Thanks
    Tim
  • Tim Grayson
    No problem, the issue definitely lies somewhere in the routing of the actual mail, that could be the network or the actual mail server. The good news is that it sounds like the machine is functioning fine though, so at least the solution isn't going to be expensive to fix, just a little time consuming as he figures out what is causing it.
    If possible please come back to the question here and click the Accept
    This Solution button, otherwise I don't get credit for the help
    provided.
    Thank you so much,
    Tim
Failed pick up fax in memory
It means it lost the information the fax machine tried to save when an incomming fax came in. You would need to call Panasonic if you still have a warrenty and get it serviced or locate the repair maunal to replace the motherboard inside the unit.
Mar 05, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
Brother MFC-240 will not receive faxes...
I cant get my MFC-290 to receive incoming faxes
Sep 21, 2009 | Brother Multi-Function Center MFC-240C...
My HP J6480 All-in-One will fax out but I can't get it to receive incoming faxes. I have cleared the fax log, but it still won't receive incoming faxes
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab11
Jul 14, 2009 | HP Officejet 5610 All-In-One InkJet...
Retrieval of fax from memory
No. And even if you could, it would simply list the # the fax was received from, and the # of pages. The actual fax is not retained.
May 14, 2009 | Office Equipment & Supplies
How to fax forward?
You can set your product to forward incoming faxes to another fax number. When the fax arrives at
your product, it is stored in memory. Then your product dials the fax number you have specified
and sends the fax. If it cannot forward a fax because of an error (for example, the number is busy)
and repeated attempts to redial are unsuccessful, your product will print the fax.
If the product runs out of memory while receiving a fax, it will terminate the incoming fax and only
forward the pages and partial pages already stored in memory.
When using this feature, the product must be the one receiving faxes (not the computer) and the
answer mode must be set to Automatic (see Changing how the product answers incoming faxes).
To use fax forwarding
Press menu/enter.
2 Use the < or > button to select Fax Setup and press menu/enter.
3 Use the < or > button to select Fax Recv. Setup and press menu/enter.
4 Use the < or > button to select Forward Fax and press menu/enter.
5 Press > to select On or Off and press menu/enter.
6 If you choose to turn fax forwarding on, use the alphanumeric buttons to enter the fax number
where you want the fax to go, and press menu/enter to save your selection.
Apr 15, 2009 | HP LaserJet 3330 All-In-One Printer
Panafax UF-880 - volume of phone ringer
1- incoming volume press the down arrow till you want the desired level
2-outgoing volume. press monitor you will hear a dial tone. press down arrow till desired level and press monitor again your done
Dec 04, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
Receiving a fax
The answer mode determines whether your HP All-in-One answers incoming calls or not.
If you set the HP All-in-One to answer faxes automatically, the HP All-in-One will answer all incoming calls and receive faxes. Set the Auto Answer setting to On.If you set the HP All-in-One to answer faxes manually, you must be available to respond in person to the incoming fax call or your HP All-in-One will not receive faxes. Set the Auto Answer setting to Off. For more information on receiving faxes manually, see Receive a fax manually. If you do not know which answer mode to use, see Choose the recommended answer mode for your setup.
To set the answer mode 1 Press Setup. 2 Press 4, and then press 2. This selects Basic Fax Setup and then selects Auto Answer.
3 Press right arrow to select On or Off. 4 Press OK to accept the setting.
Mar 14, 2008 | HP Officejet 5610 All-In-One InkJet...
Epson Aculaser CX11NF won't receive faxes
Change your incoming mode from "autoswitching" to "TAM" (TAM is short for telephone answering machine" Press the "Setup" button on the control panel Use down arrow twice to select "FAX SETTINGS" Press the right arrow once The FAX SETTINGS menu appears Press the down arrow twice to select RECEPTION SETTINGS Press the right arrow once Press the down arrow unit INCOMING MODE appears in display Press the right arrow once Press the down arrow until TAM appears in display Press the right arrow once. That should do it for you If I got lost somewhere, it is in your Operator's manual - look in the index for TAM Hope it helped Ed
May 22, 2007 | Epson ACULASER CX11NF All-In-One Printer
Samsung SCX-5530FN All-In-One Laser Printer Logo
77 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
