Question about Weber Baby Q Grill
Will not get hot enough to sear and takes a long time to cook
  • 43,501 Answers
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on Oct 05, 2010
How to cook pork chops
Yum, I love Pork Chops and Taters. I use a skillet and a little olive oil. Heat the pan til oil is pretty hot, you want to sear the pork chops when they hit the pan for about 2 minutes on each side. Then reduce heat to a simmer, add about a 1/4 inch of liquid to the pan. (I use water) Simmer until cooked. Do not overcook as they can become very dry quickly. That's why I add the water and turn the burner to low.
Also, I make this at least once a month;
Cut chops into 3 to 4" strips
Peel a few potatoes, diced (white preferred)
Put olive oil in skillet (get hot)
Add potatoes, searing the outside
Add pork strips, sear for 2 minutes on each side or to desired brownness.
Reduce heat to simmer
Add water to cover the bottom of the pan
Cover
Let them cook slowly while you watch your favorite show or mix up a salad!
These are so tender and juicy!
Enjoy!
Aug 05, 2017 | Grilling
Leg of pork 1.780 kilos how log do I cook it for
There's no magic number. It depends on what sort of result you want, the heat of your grill, the temperature of your meat, even your altitude. I would do a reverse sear, which means building a two-zone fire (or lighting only half of your gas burners), then using a meat thermometer probe and cooking it on the cool side of the grill until the middle of the roast reaches about 10 degrees (F) below where you want it. Then switch to the hot side of the grill and finish the outside (avoid lengthy flare ups). Let it rest, lightly tented with foil, for at least 20 minutes to give the juices time to redistribute and residual cooking to take place. Personally, I prefer my pork around 140 degrees (F), juicy and slightly pink.
Jun 11, 2017 | Grilling
At what temperature do you cook bone in and boneless prime rib and how long per pound
13 - 15 minutes per pound @ 300 - 325 degrees F, pull when meat is 125 F - 130 F (internal temp.) for rare to medium-rare. Err on the low side. Allow to rest; the meat will continue to cook while resting. For example, if you cook it to be medium-rare (130ish F), then pull it out of the oven, and let it rest, it will end up being medium to medium-well (140 - 145 F) once cut. So be aware.
Bone-in, bone-out it doesn't really matter, because the bone is not in the center of the meat. It's best to let the prime warm at room temp for a period of time, before cooking. An hour or so from the refrigerator (not frozen).
Some people like to place the prime into a hot (425 F) oven or grill/smoker for 10 -15 minutes, then turn down to roasting temp. This is done to sear the outside, which will give it a crispy/seared outside. This doesn't "lock in" flavor, juices or anything else, it is more of a visual and texture thing. If you do this, the cooking time will be reduced, because the oven/grill will have to come down in temp over a period of time while the meat is cooking. I don't recommend doing this with prime rib. It ends up being overcooked and tough, due to the fast then slow roasting of the meat.
What you want to keep in mind is: roast the meat low and slow. Check the internal temp, with a meat thermometer, early to avoid overcooking. Don't forget the internal temp of the meat will rise after taking it out of the oven. Let it rest for 10 - 15 minutes before slicing the meat.
Mar 26, 2016 | Grilling
Meat weighs 2llb 20oz how long should i cook it for we like it medium rare ?
The best thing you can do is to buy a BBQ digital thermometer that you place in the meat during cooking. They have a heavy duty wire with a temperature probe on the end. Sear the meat directly over the coals (or hot side of a gas grill), then move the meat to a cool side and then insert the temperature probe and close the grill lid. Cook until it reaches desired temp, for me 125 degrees is perfect. The total cooking time is hard to judge as it depends on your grill cooking temp, but the digital thermometer takes all of the guesswork out of the equation as to when the meat is done.
Apr 06, 2015 | Grilling
How long do I boil hot dog weiners
All hot dogs are already cooked and can be eaten cold so therefore the cooking time can be from minimum of 5 minutes after water comes to a simmer , If you are working a business and have the dirty water dogs sitting in Hot water you can literally have them in the water all day but remember the longer that they sit in the hot water the grayer looking they become so keep in mind that if you are selling them at a stand you want to keep rotating them from the hotter water to the to the cooler water but if you sell enough or if your just cooking a few for yourself or company a 7 or 8 minute boil will be sufficient ! Hope this helps sincerely glenn
Feb 18, 2015 | Dogs
Where to replace burners for my zanussi gas stove ZCG831W
without new parts I would suggest buying a new stove. SORRY
Jan 08, 2015 | Zanussi Kitchen Ranges
How do I cook ribeye steak
on the grill! get yourself nice dryrub at your local food store and throw it the grill. i dont let my temp get higher then 300 i cook them low and slow!
Dec 08, 2014 | Grilling
Oven not hot enough
the thermometer is most likely the problem, the calibratation is probably off. If you have access to a accurate digital thermometer it is relatively simple to do. If you do have one just take and set the knob to 250 degrees and when the oven gets to 255 it should go off and come back on at 245 degrees. If it's a digital there shopuld be a potentiometer that you have to adjust. good luck
Dec 26, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Temp isnt right
thanks for the question the problem is with the igniter i have had the same problem many times just not getting hot enough i changed the igniter and it was fine thanks the appliance doc
Mar 08, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Weber Baby Q Grill Logo
536 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
