Question about Kohler Toilet - One Piece with Ingenium Flushing System - San Raphael by
The rubber stopper does not line up properly causing leaking to bowel i hove to take cover off and move it a touch over after we flush my model is 703 one piece the handle does not come up after you flush
    Sergeant:
  • 268 Answers
Contact Kohlet online or there 1 800 number. They have all the parts but they also charge a lot.
Me I would turn on cut-off valve then go to Home Depot or Lowes and explain problem and tell model 703 and they can look it up and order your parts. They may even be cheaper then from Kohler.
Posted on Oct 07, 2010
How do you stop a power flush toilet from constantly running?
You'll have to see if the water is leaking past the flush stopper or into the overflow tube. The tube is the little pipe where water drains if the tank is filled too high. The flush stopper is a rubber flapper mounted on the bottom of the overflow tube. If water is running into the tube, then the flush valve may be stuck, so shake it up and down (gently) and hopefully it will be freed. If water is not running into the tube, then reach down and try to seat the flapper stopper to see if something was lodged there to keep it from seating all the way. Would be a simple fix either way.
Dec 08, 2014 | Home
How to connect the pipe to a toilet bowel without leaks
if you have tried the one that comes with the toilet and this does not work...go to lowes and get a braided toilet supply that has rubber seats in both sides...these work great...good luck...
Jul 08, 2014 | Home
Gurgling in the bath tub when toilet is flushed
follow this steps and fix it. God bless you
lear a clogged (not stopped) sink or bathtub with a plunger:
  1. If you have a dishwasher, pinch off the rubber dishwasher drain hose that leads to the garbage disposer using a clamp or locking pliers. If clearing a bathtub, remove the drain stopper and cover the overflow opening with a wet rag.
  2. Remove the sink basket or tub stopper and clean any debris from the drain opening.
  3. Fill the sink or tub with sufficient water to cover the plunger cup, usually about 2 inches. If you are working on a double sink, seal the other sink with a stopper so the plunger can create a vacuum.
  4. Set the plunger on the drain opening and repeatedly pump it up and down, then pull away sharply to dislodge debris. Repeat if necessary.
  5. Turn on warm or hot water to flush loosened debris from the drain.
  6. If the clog remains, use an auger (see below) or an expansion nozzle (see below) to clear the drain.
Clear a clog using an auger:
  1. Remove the stopper or strainer. If unable to do so, disassemble the drain trap (see below) and feed the auger directly through the pipe. Make sure you have a pail and rags nearby in case of a water spill.
  2. Release the setscrew on the auger and begin feeding the cable into the open drain.
  3. Once the auger tip hits the clog, set the screw and crank the auger clockwise to break up the clog.
  4. Continue breaking up the clog and moving it down the drain line with the auger. Once there is no more resistance to forward motion of the auger, stop and carefully remove the auger.
  5. If the clog can't be moved, continue twisting the auger to possibly snag and retract the clog.
  6. Once the clog is cleared, flush the drain with boiling water.
Nov 04, 2013 | Plumbing
Water level in bowl is too low so it's a problem keeping it clean. How can I raise the water level?
All toilet bowls have a preset water level determined buy the design of the internal s-trap and can not be change. However if the water level in the tank is not as high as it should be this will affect the water put into the bowel as the bowel in refilled by the flush valve and if it is set to stop before it get filled to the proper setting the bowl water level may be low.
A quick test is to see if the water level in the tank is up to the line in the tank most all toilet tanks have a line either stenciled or marked with a indentation in the porcelain. Another way is to mark the level in the bowel with tape or a marker then pour water slowly into the bowel not fast enough to flush it wait to see if it stays higher then the mark you made or settles back to that level.
Feb 04, 2011 | Duravit 111335001 Geberit In Wall Carrier...
Internal leak
I am not familiar with this particular toilet, but most toilets that have a tank have this problem when the rubber flap stopper does not seal and allows water to trickle through.
this is the rubber stopper that lifts when you use the flush handle, the fix was to use the handle and allow all the water to flow out and use a soft rag and clean the area that the stopper seals to, and you will also want to clean the stopper of any gunk that may have accumulated on it.
Mar 12, 2010 | Neptune FB1623 Toscane Toilet
Toilet won't flush - water drains very slowly
YOU COULD HAVE A BLOCKAGE IN YOURE LINE OR IF YOU ARE LUCKY YOU JUST NEED TO ADJUST THE CHAIN THAT CONCTS THE Handle to RUBBER STOPPER IN THE BACK OF THE TOILET THIS WATER IS CLEAN AND YOU CAN PUT YOUR HAND IN THE BACK PART OF THE TOILET WITH NO WORRIES JUST TAKE OFF THE LID AND FLUSH IT OBSERVE THE RUBBER STOPPER IN THE BACK OF THE TOILET IS IT COMING ALL THE WAY OUT
Jan 19, 2010 | Toto Aquia II Dual Flush Toilet
When flushed the tank refills and the float goes up.... after about 5 mintues of quiet, there is a "shhhhh" refill sound..and bubles inthe water from the main pump. how do I fix this? 6 LPT and 1.6 gpf
Adjust the water level in the tank to the water level line in the tank. If the water is spilling into the open tube in the center of the tank, that will cause the water to run.
If water is not seeping into the tube, then maybe water is leaking through the rubber stopper and into the tank. You will have to replace that rubber stopper
Oct 23, 2009 | Eljer Toilet Onepiece Canterbury ...
Cheviot Wall hung toilet flush valve replacment gasket
try a plumbing supply co. they may help you
Jul 02, 2009 | Home
Kohler Toilet - One Piece with Ingenium Flushing System - San Raphael by Logo
352 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
