Question about Hoover H130E Front Load Washer
Into the spin dry cycle a loud hammering noise appears. Immediately goes away when powered off and drum speed drops. Can you please advise. Regards Geoff
  • Hoover Master
  • 43,501 Answers
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Posted on Oct 05, 2010
My washer/dryer combo Frigidaire washer dosn't spin water out of clothes completely after spin cycles the clothes is still very wet. On the 1st spin cycle drum dosn't spin just makes noise,the 2nd and...
Good Afternoon Friend,
I understand your Frigidaire laundry center, model# FGX831CS, is not spinning water out of your clothes completely. I see that on the first spin cycle the drum is not spinning and is just making noise, and on the second spin cycle the drum spins to the left very slowly and loudly. First check to see if your washer is overloaded. Try taking some clothes out and spinning them again. Secondly, make sure that the load is not out of balance. Try rearranging the clothes to allow for proper spinning. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 19, 2014 | Frigidaire FGX831CS Top Load Stacked...
On spin cycle very LOUD noise and some smoke immediately after shutdown. Drum rotates off center of outer drum, and rubbs at only one point in the rotation.
Try Repairclinic.com for drawings. Find the big capacitor, and look at it. If it blew, it would show. You would think a spring broke, the broken one would show. Maybe a shock absorber ruptured?
Nov 27, 2013 | Maytag MAH6700AWW Neptune Front-Load...
Noise and movement when spinning
Could be more than 1 problem by sounds of this. !st may be that heater is not working and so machine will not advance to rince. As for banging this could be caused by pump failing to take water away. Or on a more seriouse note could be drum or bearings. Normally if bearings have gone then it will sound like a plane going over. I think it is likely heater, or /and pumping failure.
Mar 15, 2010 | Washing Machines
Loud noise in final spin
Verify that the inner drum isn't broken. Sopin by hand it should trun smoothly and staight.
Aug 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Kenmore top load washer making loud noise in spin
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Apr 02, 2009 | Kenmore 22422 Top Load Washer
Something stuck in drum, spinning cycle loud hammering/clacking sound
hi there,
sounds like you may have something caught between the tumbler and the cabinet. since the drum has holes in it, can you have a look if you can see anything that's come of clothing, like a bra wire. it's usually something bigger.
Sep 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Ultimate Care Model LSR8233EQO - Loud noise during final rinse/spin
Sounds like the clutch, mi9ne works fine but is noisey when spinning, repair guy said it was the clutch.
Feb 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Loud noise when on spin cycle
hi the engineer probeply rejected agitator dogs problem sounds like he is right for the diagnosis on the bearings although it is very wired forthis problem on a new machine its probeply a defect bearing http://www.applianceaid.com/direct.html#agitating http://www.repairclinic.com/0047_11.asp good luck
Apr 26, 2006 | LG WD-1280FHD Front Load Washer
Hoover H130E Front Load Washer Logo
419 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
