Question about Smeg Kitchen Ranges
Pushed several buttons on the oven and now have a flashing "A" and no action. Unfortunately, when we bought this house with the beautiful new electric Smeg oven and gas cooktop, the seller had not kept any of the manuals - nor had he used the new oven! Kindly help. Caroline
  • hoisington May 29, 2008
    Just got somebody from Smeg on the phone. Turns out that all you have to do is to push two buttons at once - the ones that look like a pot cooking and the same image with an X through it. You push them both at once and hold for a few seconds and the A disappears and it all works again.
    The guy I spoke to is also going to send me a manual via e-mail.
    Thanks for taking the time to answer anyway & hope this is useful to you too.
  • 868 Answers
The manual is not going to help you ,it would only make you feel your not selecting things properly.So,here it is,REPLACE THE CONTROL BOARD  some times called the CLOCK or CONTROL ELECTRIC.
Posted on May 28, 2008
  • Archie Ferrarini
    Archie Ferrarini May 29, 2008
    Nice way to test a tech.It sure would be nice if we could hold a couple of buttons down and get manufacturers to stop and go back  to the basics,who really needs all these options ? 85% of my customers don't even want to know how they work.
               Glad you got the right info.
  • dmccombe
    dmccombe Oct 23, 2012
    who can I get to replace the control board, clock or control electric in Auckland. My whole display is not working as well as the oven.
Gibson oven door is locked after attempting to do self-cleaning.
Unplug it. Plug it back in, then press n hold start. Make sure lock handle is all the way locked. You may have to push on the door at same time while locking n unlocking. If that doesn't work, shoot it. Ha
Sep 24, 2012 | Ovens
Gorenje EI44A1-T34 or EI44A2-T44 Dear Sirs,we have the oven for quite a while,but never used the oven part of this induction oven. And therefor didn't bother too much with the blinking light showing...
I hope you have found already solution for this... Anyway this may help others: press buttons 1 and 2 together and release. Then use jog wheel to adjust time. Wait 5 seconds and you're done. Gorenje manual sucks, no info about oven controls. I managed even to set on oven child lock (key symbol), only way to take it off was to remove fuses from electric board of our house!
Jun 24, 2011 | Ovens
We have a Samsung MT1044WB/BB/CB. It is a Toast & Bake Microwave Oven. We have never used any function except the microwave oven over the 8-10 years since we bought it new. We have not used it in...
The computer died. Not much you can do with it. After ten years it doesn't owe you anything.
Of course you could bypass the whole timer with a toggle switch if you were MacGyver.
Apr 10, 2017 | Samsung MT1044 1000 Watts Convection /...
When the "bake" button is
hello,the control is locked. i belive if you hold the time button for 5 seconds it will unlock. hope this helps please rate me thank you...
Jun 07, 2011 | Ovens
TV WILL NOT COME ON. "Timer" light flashes green
jbailey714,
Unfortunately I have some very bad news for you. This particular chassis is notorious for developing bad capacitors on the DM and power boards. At this time there are no spares. If you can handle a soldering iron and have lots of patience I have a tip at http://www.fixya.com/support/r7065906-mitsubishi_turn_flashing_power_timer which explains the problem and where to get the parts.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 13, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Hi i have inherited a Smeg range cooker when I
Unfortunately, I don't have a solution for you. That's because I have exactly the same problem. Did you ever discover how to fix this problem?
Jul 14, 2010 | Ovens
My NewBrand FLIP MINO HD2 once switched on and after having pushed red button ( recording ) is now blocked ! No responding to any command or doing any action ( no recording, no display, red light rechargin...
return it for a refund! i bought one, it did the same as yours. i returned it and bought the 2nd one. It did the same as the first one (and the same as yours.)
It is a piece of junk. Supposedly the previous Flips were good, unfortunately, I didn't have the previous models so my experiences only are bad.
May 08, 2010 | Pure Digital Flip Mino Digital Camera
Flash/sparks occrred (no metal in oven)
You know I just had a similar problem on my old unit. There was a spark and my bowl had no metal rims. I figger your ground connection has corroded at the rivets. So if you can drill a 1/8 inch hole in there and install a #8 sheet mtal screw or two to bond it togeter again.
May 04, 2009 | Microwave Ovens
Chef regency oven with "HELP" flashing on panel. Have no manual
Usually means that the time needs to be set. Press Clock Set then use the up and down button to set correct time, Then press Manual button.
Apr 16, 2009 | Ovens
GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
Oct 22, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
175 people viewed this question
Top Smeg Kitchen Ranges Experts
Richard Ballard
Richard Ballard
Level 1 Expert
Joseph Mueller
Joseph Mueller
ashburton
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
