Question about HP Televison & Video
I have a hp pavilion lc3200n and the OPC light blinking and it will not turn on. Any ideas
  • 1738 Answers
SOURCE: opc/cannot turn it on.
Try unpluging for about fifteen minutes.
Posted on Nov 21, 2009
  • 7 Answers
SOURCE: opc light blinks then shuts off the TV
I've read online that upgrading to the latest firmware sometimes resolves this issue. That's kind of shooting in the dark though - I personally would not feel completely confident that a FW flash would actually resolve the issue (as it could still be lurking beneath somewhere, waiting to surface again). If you have no warranty, then the FW flash is not a bad option. It's relatively easy and virtually impossible to screw up!
If you're still under warranty, then I imagine you've figured out by now that you'll need to contact Sharp to fix this issue. Mine was luckily under the extended (15-month) factory warranty when this first happened to me. I was 13+ months out from date of purchase. Sharp support confirmed a tech needed to come out for an all-day appointment to troubleshoot the TV. Thank goodness for the extra 3 month warranty I got when signing up for the Aquos Advantage club! Otherwise, my $3400 investment might have cost me at least $700-$800 to fix - only a year out from purchase!
Posted on Dec 27, 2009
  • 41 Answers
SOURCE: Blinking power and opc leds on front of unit
From the information you have provided failed capacitors in the power supply is likely causing the problem. The safety circuitry shuts the TV set down when it detects a problem. This model of TV has over 2,000 parts which include millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Integrated circuits and transistors can go bad. This can cause other components to become defective, which can have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment. The repair should cost about $250 if carried into a TV repair shop. A small TV repair shop will often charge less than a large repair facility.
Posted on Feb 25, 2010
  • 41 Answers
SOURCE: Sharp LC-37SB24U will not turn on
  • 8457 Answers
SOURCE: TV won't show picture the
The main tv Tuner signal board have problems or it is dying or might be dead already.But sometimes this tv will still work and can be used,i have the same tv have the same problems it work for me all the times.By doing this process.Everytimes Power and OPC lights blinks.Just push the remote power switch again for tv to repower the tv power and OPC lights again,have go thought this process pushing power remote switch again have to do this like 3 or 4 times sometimes before the tv to work.Tries websites like Shopjimmy.com or Ebay.com to buy a whole new refurbish main tv Tuner signal board for the replacement.
Posted on Jul 30, 2011
Hp pavilion lc3200n 32" won't power up
Try to replace power cable but if doesnt work,maybe the power supply is defective or the power switch.
Jan 22, 2017 | HP Computers & Internet
Power and OPC light blinking. TV doesn't turn on.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 06, 2016 | Sharp AQUOS LC-52E77UN 52" 1080p 120Hz LCD...
Power and opc lights flashing will not turn on tried vol/channel up reboot did not work
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 17, 2015 | Sharp Aquos Televison & Video
Is my tv main board bad
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jun 20, 2015 | Sharp LC Televison & Video
My sharp lc-52se94u tv wont turn has blinging blue light and opc light on
May 01, 2015 | Sharp Aquos Televison & Video
Opc sharp aquous no picture is coming up and opc light is blinking.is this why its not working? none of the controls are working no menu is showing up. trying to fix it. is there any way to reset it?
Sep 13, 2014 | Televison & Video
So when i turn on my sharp hd it turns off then the opc light comes on! Then the power light and opc light keep flashing!! Alls i want 4 it to work? Plz help
The television has gone into a coma. It is going to need to be serviced or replaced. The blinking code is a pattern. If you look at the power light and the opc light separately and independently, you can acquire the blinking pattern. Cover opc and look at power only. Note how many times it is blinking before it pauses. It might just blink steadily. Next cover power and look at opc alone. Note how many times it blinks before it pauses.
Depending on which model you have it might work if you leave the television unplugged overnight. The next day plug the television back in and wait for the blinking to start. Hold down the power button on the side of the television until the light stops blinking and turns red (usually right away). Let go. Press and release the power button once more and the light should turn orangish and then green. The television should turn on.
You can call Sharp and have a case file created and try and INIT with the customer service representative.
Mar 07, 2011 | Sharp Televison & Video
Thethe tv will not come on and power and theopc is flashing.
Ok This is how to troubleshoot the TV, there are lights on the front and you are mainly concerned with two of these lights (the power light and the OPC light). I) If non of the lights come on then this is a AC Power failure (There is a loose connection or you need to check the Power/Inverter unit or the Main unit) II) If the power light is blinking at a rate of one blink per min and the OPC light is off (then there is a CCFL backlight problem) III) If the power light is blinking at a rate of two times per min and the OPC light blinks at a rate of one time per min (13V/UR10V failure you need to check the Power/inverter board or the main board). IV) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of two times per min (3.3V Main Failure check power/inverter board or Main board). V) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of three times per min (UR6V failure check power/inverter board or Main board). VI) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of Five times per min (Panel 5V failure check LCD control unit or control panel).
Sep 07, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
OPC/DL light flashing Same problem of black screen and green lights flashing at power and OPC Help....
WHEN FLAT SCREEN SHARP LCD IS ON .. BLIKNING ON BOTTOM OF SCREEN SAYS OPC
Dec 08, 2008 | Televison & Video
Televison & Video Logo
113 people viewed this question
Top HP Televison & Video Experts
Tony
Computer Links
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
