Question about LG Heat cool Window Air Conditioner
LWHD1200HR - LG 12000 BTU Heat / Cool Window Air Conditioner
Question about plug and wiring. I have a 250 20 amp dedicated for this unit. I am just confused as two the receptacle I purchased for it has two positives (red&black) and a green coated screw (ground) but no neutral. Maybe you can give me some insight. Thank you in advance.
I have a lg lwhd 1200hr window ac the heating system dont work . it blow cold air out not heat. can you help me
Posted on Jan 21, 2009
That is 2 hots and a ground, you do not need a neutral on a 220 appliance
Posted on Jul 21, 2008
What wire goes where when wiring a window air conditioner
Posted on Jun 09, 2008
Turns on and then turns immediately off. Does not blow any air.
Check if it gots a fuse or safety plug, maybe even a different outlet. Besides that I don't know maybe the filter needs cleaned? I'm not expert.
Feb 02, 2016 | LG LS-L1210HL 12000 BTU Heat and Cool Mini...
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    It is 106 degrees outside, I have a a/c unit which is cooling at 75 degrees in a 1180 square foot townhouse apartment, this seems like the unit is doing all it can with the excessive heat, is it
    Unfortunately, 7000 Btu's will not cool 1180 sq ft. At best, it's rated for 400 sq ft, as it's only rated as a "Room Air Conditioner". To cool 1180 square feet, you'll need at least 30,000 Btu's (like in Central Air Conditioning) or 4 more window units spread out throughout the condo. It takes more Btu's to cool, than it does to heat.
    I really sorry. I wish I had better news for you. Thanks for choosing FixYa.
    Aug 02, 2011 | LG Heat cool Window Air Conditioner
    HI there, I have a Goldstar WG1205R 12000 BTU window air conditioner that has no filter, blows slightly cool air and the fan power is very weak for 12000 BTU's How can I improve the performance of...
    Sounds like you have a 220 volt air conditioner plugged into a 120 volt outlet.This will cause the conditions you are describing.
    Put a filter on it please.
    Jul 10, 2011 | Goldstar Heating & Cooling
    How do I change out the fan motor on my LG LWHD1200HR AC/Heat unit., as it needs to be replaced, Im a technician on major appliances, but have never replaced a fan motor on a window air conditioner. any...
    Unplug the unit and remove it from the window. Place it on a secure surface for working on it. Take off the cabinet. Remove the fan blades and disconnect the wires at their terminations. unbolt the motor and bring it, along with the make, model number and serial number, to the nearest United Refrigeration or W.W. Graingers. Have the counterman match it up for you. Reverse the above procedures, remembering to replace the capacitor.
    Jul 18, 2010 | LG Heat cool Window Air Conditioner
    Frigidaire fac127p1a 12000 btu compressor
    The compressor is probably going out on either a pressure related or heat related overload. Both are a result of low refrigerant. There may be a low pressure safety swich that protects the compressor. Otherwise it may be an internal thermal overload that is tripping. It resets itself and comes back on. The thermal overload heats up and shuts off the compressor to protect it from too much heat which is gernerated by not enough refrigerant in the system to keep the compressor cool. It may be cheaper to replace the unit than have someone try and fix it. It is pretty time consuming and you cannot try it yourself unless you have an EPA Certificate to buy the refrigerant. Check with your local appliance repair man to see if he will tackle it.
    Jun 04, 2010 | Frigidaire 12,000 BTU Compact II Room Air...
    My LG 7000 BTU Heat / Cool Window Air Conditioner does not cool and the fan speed F1 will not work. Fan runs on F2. The heat works fine. Any suggestions?
    You have a control board issue. You can get a new control board by Google searching the make and the model of the unit. There are several sites that sell them
    May 24, 2010 | LG Heat cool Window Air Conditioner
    Lg 12000 btu air conditioner inverter is not working and the led 6 times.thanks
    This alarm state is a CH 06 alarm.
    Indication for the Indoor unit pipe temperature sensor (thermister) not plugged in or out of calibration.
    This alarm will also occur when the unit gas charge is to low and the indoor unit temperature reached a temperature of -5°C for longer that 30 sec. It will switch the machine off.
    Mar 21, 2010 | LG Electronic Window Air Conditioner
    I just installed a ductless mini split 12000. when I put power to it the outside unit compresser runs no fan the led read out just blinks very fast the remote does't do any thing
    One thing you need to check is Polarity. the 2 wires red and white, need to be on the same terminals inside as they do outside. this is very important.
    Oct 28, 2009 | LG LS-L1210HL 12000 BTU Heat and Cool Mini...
    LG Heat cool Window Air Conditioner Logo
    1,660 people viewed this question
    Top LG Heating & Cooling Experts
    Donni Steen
    Tim Whalen
    Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
