Question about GE Refrigerators
We own a GE 2 door refrigerator Model GSH22SGRESS, the ice maker on the outside just went out and no longer produces ice is there something we can do ourselves to repair or do we need a tech to take a look? Thank you Magdalena
SOURCE: ge profile refrigerator ice maker
I have what appears to be a similar problem -- but have not yet found a solution. The door or valve on the ice dispensing chute is not closing or sealing properly. The warm air from the kitchen is drawn into the freezer (ice maker). The warm air condenses and freezes causing the ice cubes in the ice bin to freeze together, preventing their discharge from the bin. Also, the warm air and condensation freezes and builds up frost and ice in the discharge chute. When you try to discharge ice cubes, they get stuck in the chute and will not discharge.
Temporarily, you can open the freezer door, access the ice bin and loosen the cubes which are frozen together. You can also remove any cubes from the discharge chute. If there is frost and ice in the discharge chute, use a hair dryer to melt the frost and ice, putting a container under the dispenser in the door to catch the run-off water.
I've done all of the above and I'm still not getting a proper seal and air is still getting into the ice maker bin and dispensing chute. Looks like a service-call is next.
Posted on Oct 06, 2008
SOURCE: Refrigerator Ice maker not working
i need an answer to this same question
Posted on Oct 19, 2008
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Posted on Nov 09, 2008
  • 56 Answers
SOURCE: Hello, I have a GE
You can possibly burn out the solenoid valve. There is an off position on the ice maker itself and possibly a switch to turn the power off to the IM.
Posted on Dec 08, 2008
  • 219 Answers
SOURCE: Refrigerator not making alot of ice cubes
a bad valve will make them stick togather and sometimes hollow but the ge is well known for the back board being bad
Posted on Mar 19, 2009
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded ยท How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    Ice Maker won't produce ice through the door
    You either have a bad interface board ( touch board ) or a bad main control board . You would have to go into the test procedure from the touch board to determine which is bad . The more I think about it though , I tend to lean towards the main control board . Once you get into the test mode , 0 and 4 would test communication between the 2 boards .
    Jul 18, 2009 | GE Profile Arctica Stainless Steel Top...
    The ice maker on our GE refrigerator does not make ice
    1 -Ice maker arm must be down(on position)2-Make sure the water supply line is connected to the fridge3Check if the ice maker is plugged in4The freezer must be working fine for the ice maker to produce ice. After the ice maker stars and calls for water and doesn't get any , the water valve is bad.And if everything above is ok the ice maker needs to be replaced.
    Apr 26, 2009 | GE Refrigerators
    GE model GSH25JFTACC ice maker not working
    When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
    First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
    Mar 24, 2009 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
    I have a GE Profile refrigerator the does not produce ice cubes
    the fill tube that runs water into icemaker has most likely frozen up use a hair dryer and heat the tube up until the ice melts out then it should start up agian. you may have to remove the icemaker to gain full access to the fill tube. good luck peyton
    Jan 24, 2009 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
    Ice maker stopped working
    Just a question... Is the motor that flips the ice down into its tube moving? or spining? your motor in the ice maker may have went out. might have to replace it.... hope this helps....
    Jun 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    Kenmore Side By Side Refrigrator ICe Make Not working
    Is the icemaker producing ice and it's just not coming through the door? Or is the icemaker not even producing ice???
    Mar 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    Icemaker will not was dispense ice
    My icemaker stopped producing ice. We turned off the water line to it when we went on vacation for a week. We turned the water back on when we got home and since that time it won't produce ice. We can still get water from the door dispenser though.
    Nov 02, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
    Refrigerators Logo
    87 people viewed this question
    Top Refrigerators Experts
    Sal DeAngelo
    dweatherby
