Question about RCA 25450 4-Line Extended Range Multi Handset Phone
My phone is not ringing and there is a aymbol on the screen and I have no idea what it means
Hi i want to block number to call me ,my phone is nokia 1280
You can not block that number.Your mobile will not support for that.
* You can do one thing.You can add that number to the screened list.
* If you add means your mobile will not ring if that person calls you.
* Their you will see the miss call information.
* If they send you message means it will be stored in the screened message.
* If you want to add that number means you should follow this steps.
* If you have miss call from that number means select that number there you will be having option select that option.
* There scroll over to add to scrn.list select that one.
* Then it will ask do you want to add this number to screened list.
* Select it.
* From now you wont get ring if that person call you.
* Message will be stored in screened message.Select message scroll over to screened message.In that you will find the message.
Thanks for your question.
Jun 27, 2011 | Nokia 1280 Cell Phone
Panasonic kx dt 333 When the phone rings the red light doesn't flash to denote which line it's coming in on. Any idea how to resolve this?
Which means what? You have a solid red light on the line or you don't have the line at all. A TDA system rings by a process called ICD groups. You can have a phone in an ICD (600 by default) and tell it the number of rings to delay, not ring, or immediate ring, but that means that the line button will flash as the call is coming in. If you don't assign it to a group, it's really stupid and won't do anything but light solid red.
If you have access to installer programming, you assign the extension to the main ICD. If you don't you have to call your Panasonic installer or dealer.
Carl
May 11, 2011 | Panasonic KXDT333 Phone
I have an iphone 4 which was brought in UK . i have an problem with it now it is not getting inside it shows the apple aymbol and getting stuck . i pressed the reset option through . wat should i do now...
Sorry to read about your problem, I hope this helps you out.
you will have to use itunes and restore your phone
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | Apple iPhone Smartphone
My phone won't ring aloud. It is recieving the
software fault, read here so you know what will cure it http://forums.se-nse.net/topic/39748-tutorial-flashing-a2-phones-with-a2uploader/
Mar 31, 2010 | Sony Ericsson W890i Cellular Phone
Phone screen blank and when on charger circle ring w/3 colors
That means that your phone has corrupt firmware. Please get the firmware reinstalled from Samsung Service Center. That would remove the virus too which may be the cause of corrupt firmware. And after that install an anti virus software too.
Feb 20, 2010 | Samsung Propel A767 Cell Phone
How to repair white screen of n70
it depends if its a screen problem or a virus problem.
Those are one of the things that can make a phone screen to be white.
Put on the phone and use another line to call your phone. If it rings, then it means its a screen problem. But if it does not ring, then its a virus problem.
In the case of screen problem, loose the phone first and check it the screen is well fixed. If well fixed, then it means you have to buy another screen.
But in the case of virus, this means you have to flash the phone.
Best regards.
Feb 19, 2010 | Nokia N70 Cellular Phone
My phone screen is totally whitee. what should i doo. p.s. its not water damage
try calling ur number using a different phone, when u hear it ring answer it & check the audio on the earpiece & mic. It means that the LCD is bad & needs a replacement. But if you cannot hear it ring, it means that the software had crashed & would be resolved by a software reflash/reprogram. Contact local repair shop or the phone manufacturer
Dec 15, 2009 | LG VX5500 Cell Phone
X bow stalls
3 rings would be the ol' Red Ring of Death, while 4 rings means the AV cables are not detected.
Jun 19, 2009 | Microsoft Xbox 360 Console
NEC Dterm 80 calls won't go to voice mail
for us i just found this out.
1.Fwd B/NA
2.1 - 1:set-0:cancel
4.200
5.speaker
after 4 rings it goes to voicemail
this works for us.
i hope it works for others too.
turn this feature off
1.hit fwd b/na
2.0:cancel
3.exit
4.exit
should see the normal display then.
Jul 17, 2008 | NEC Dterm DTP 16D-1 Corded Phone
RCA 25450 4-Line Extended Range Multi Handset Phone Logo
145 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
