Question about Linksys Wireless-G WRT54G Router
Cuts in and out looses internet connection - Linksys Wireless-G WRT54G Router
  • 2,260 Answers
Try to upgrade the firmware of the router.
Is there any computer connected to the router with the cable.
If not then you will need to connect the computer to the router.
Download the firmware of the router from the manufacturer's website.
enter the model number. select proper version number and download the firmware of the router.
Once you download the firmware, you will need to open the router set up and upgrade the firmware of the router.
After upgrading the firmware, it is recommended that you reset and reconfigure the router.
Click Here for more information about router and networking
Posted on Oct 05, 2010
DC15 Brushbar Problem. Intermittant operation of brushbar. Cuts out depending on angle of vacuum. Also cuts out on lifting from floor. Normal suction at all points and no blockage. Brushbar not...
DC15 Brushbar Problem. Intermittant operation of brushbar. Cuts out depending on angle of vacuum. Also cuts out on lifting from floor. Normal suction at all points and no blockage. Brushbar not jammed. Seems like a loose connection somewhere but where ? and what
Jun 29, 2011 | Dyson DC15 All Floors - The Ball Bagless...
Receive and send lights keep flashing and no connection can be obtained
Reset the modem by removing the power for at least 45 seconds,try to get online.
If you have a router, reset that also. Modem first, then router,in sequence.
Check the cable going to the modem for any cuts or connector is loose.
If it still won't work ,replace the cable.
Lastly, call your Internet provider.
Nov 27, 2010 | Arris SURFboard SB5101 Cable Modem
Why does my internet connection always cut off?
There are severals reasons why your internet connection cut off.
1. Faulty DSL modem - check your modem -> overheating?
2. Check Cable or telephone line connection defective.
3. ISP connection inconsistent -> check with your ISP provider.
4. PC infected with Malwares, spywares, virus & others dangerous objects -> scan and clean PC.
Do the above troubleshooting.
Oct 08, 2010 | Microsoft Computers & Internet
Asl light blilnks and i get error message saying low or no connectivity
This error occurs when your ISP 's(Internet Service Provider) server is partly down or either way. Or it might occur when the DSL wire got any loose connection or cut. Try checking the DSL cable and if still the problem exists, complaint your ISP to check on their side. Thank You.
Jun 30, 2010 | Computers & Internet
Every 5 minutes my comtrend CT-5071T keeps loosing
I think the router has to be reprogrammed but first we chall check for other related errors.First of all assuming that your PC is in perfect state and had been checked to be trouble free you can open up the router. Look out for any dry soldering or dirt within. clean and solder them using a low wattage iron very carefully not to jump any solder joints. Clean the terminals of the router and reconnect. Check also on the poweer connection for any loose connections of the DC or main.When the set cuts off check if there is any power disruption of the source. If you have not checked your PC please check for virus ,using a good antivirus scan,erase all temperory files, cookies, history, or restore to an earlier set point. please give me a feedback if this helps you out. Good day
Jul 06, 2010 | Computers & Internet
Electrical short or loose connection
did this problem start after the new alternator or is this the reason you replaced the alternator? sounds like a loose wire on the alternator or the battery post. make sure the battery terminals are clean from corrosion. if there is a hot spot on the wires or connectors that is a good sign that is a loose connection.
Apr 25, 2010 | 1997 Chrysler Sebring
I have a front load machine that when you cut it on and it cuts off without finishing the cycle. Not everytime just a few times a week. When it sits cut off for a few hours then it will start working...
Suggestion: Remove the plug from the wall & open up the machine. Check to see if all the connections are plugged in well; especially the one harness leading to the motor. Before that check your washer plug for loose connections; also check your wall socket with another electric gadget - could be a loose connection somewhere.
Feb 10, 2010 | Whirlpool Washing Machines
Internet connectivity is constantly cutting out. I have to DIAGNOSE CONNECTION PROBLEM get connected again every 20 - 30 mins.
Please do confirm wireless or wired connection. If wireless ,reset wireless modem,install new wireless software (third party) or make sure wireless adapter in good position.
If wired run winsock fix, make sure ur lan cable socket is not loose, or try differnt cable,check windows update or antivirus.
Jan 31, 2010 | Acer Aspire One AOA110-1113 Netbook
Motorola SBG900 looses internet connection
if its working proprly with xp computer then i am 100% sure that this modem does not support vist...
Try to contact manufacturer ......or look for user manual...
one more thing try to update your Ethernet driver......may solve it...
happy to help
Aug 18, 2017 | Arris SURFboard SBG900 (49402201900) Modem
Problem with cable internet connection
you must have the wireless adapter and the lan adapter set to turn off when you are on battery power to reserve the battery, click on the battery icon in the taskbar and check the power settings or use empower Acer Epower management and turn them both on.
Sep 24, 2008 | Acer Aspire 5570-2758 Notebook
Linksys Wireless-G WRT54G Router Logo
59 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
