Question about Canon LaserClass 9000L Plain Paper Fax
It is now on a phone line and needs to be programed to receive only its number and answer with 2 short rings and not answer on a phone call.
  • 1 more comment
  • mcg_mgt Oct 05, 2010
    When someone calls on the phone nuimber (7240794-5491) the phone rings in the normal way. When you answer the phone you can hear the fax trying to dial in the background.
    The phone company told me the fax machine has to be programed to anser only when the fax
    number (724-406-0179) has been called.
  • mcg_mgt Oct 06, 2010
    Talked to phone co again. They said that when a fax machine is on the same line as a phone
    with each having their own numbers that the fax has to be programed to answer on a distinctive They also said they do NOT believe a 9000L can be programed to do so.
    If the phone co had told me the fax had to be programed this problem would not have happened. All they said was just plug the fax into the modem and it will work. Finally, this morning I was told about the programing and the 9000L could not be. This has been going on since Monday of last week. Thanks for your input. Bob McGowan
    President:
  • 2,777 Answers
Woah, run that one by me again? Is this a Canon LaserClass 9000L? It needs to be programmed to receive only it's number? What do you mean by that? What else is it receiving currently? There is no way for it to discern a phone call, but it can definitely be set to answer after 2 rings.
Thanks, please give me some more info here and I can help Tim
Posted on Oct 06, 2010
  • Tim Grayson
    Tim Grayson Oct 06, 2010
    Reading comments now, will update in less than 10 minutes here.
    Tim
  • Tim Grayson
    Ok yes, it is a distinctive ring function and your machine can't do that. The easiest way to solve this by far is to just get a separate phone line that is the fax and plug that into the machine. Then use that number ONLY for faxes, do not put any voice handsets on it at all... Then you don't have to worry about them crossing lines...
    Thanks
    Tim
  • 2,272 Answers
Please explain your problem in more detail. are you asking how to set it to fax mode or are you asking for disabling phonecall.??? kindly explain all details of problem so we can help.
Posted on Oct 05, 2010
Why can't I answer a call on line 2?
Confirm the extension # you are working with and that the line 2 key is line 2. do this by pressing feature *0 and the pressing the intercom key, observe the display and then press line 2 key and view display. then go back in the programming and view line 2 apear&ring, change it until it is apear&ring, then release and check for working again. If this dont work check to see if line 2 is programmed as a private line.
Jun 17, 2015 | NorStar T7316E Corded Phone
IT WILL RING BUT GOES TO ANSWERING MACHINE DOES NOT RECEIVE FAX
>first run fax test, press set up go to tools menu then select run fax test,all entries should be pass
>then check your connections, do you have one line or number for your fax and phone?or a separate line or another number for fax and another number for phone?
>let me assume you only have one number for fax and phone..
>check connections, this should be downstream connection, the fax machine using the black phone cord provided by hp should be connected directly to the phone jack using line 1 at the back of the fax and the answering machine or the telephone should be connected to ext 2 or line 2 at the back of the fax...there should be no other devices phone or answering machine connected directly to the phone jack.
>next set rings to answer on the fax machine higher than the answering machine...if your rings to answer on answering machine is 4 rings, set the fax to 6 rings...if it is a voice call the answering machine will pick it up at 4 rings then if it detects that it it a fax tone then it will transfer the call to fax.
>also check if auto answer is on in your fax
>you can check auto answer and rings to answer by pressing set up or menu button on your machine look for it in basic fax settings or advance settings
>also check if your voice prompt for your answering machine is not too short there should be like at least 5 seconds after cutting your message to allow the machine to transfer the call to the fax if it is a fax tone.
Sep 14, 2009 | HP 1040 Plain Paper Inkjet Fax
Stations don't ring even though day ring and night ring enabled.
Sounds like the ring assignmet programming has defaulted.( all lines ring at station 4 only)
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
repeat for each line
Jul 20, 2009 | Samsung Prostar 816 Phone
Cannot answer phone when it rings
when you lift the handset from the cradle try pressing the line number button on the handset or answer button on the handset.
May 29, 2009 | Vtech Cordless 6041 Phone
Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Feb 11, 2009 | NorStar M7324 Telephone
How do i enter the distinctive ring sound for the fax?
click on menu/setup button
then advanced fax setup-ok
answer ring pattern-ok
chose from single, double, double and triple, none-ok
Feb 06, 2009 | Samsung SCX 4521F All-In-One Laser Printer
I need to retrieve my home phone messages from cell phone
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Dec 01, 2008 | Uniden Cordless Phone
HP officeJet 4215
Here is a link to the user guide.. This should provide info on how to program the fax to answer o n the second ring. I don't know however how you have 2 numbers assigned to one line?
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=351106&lc=en&cc=us&dlc=en&lang=en&cc=us
Nov 03, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Receiver dosen't pick up line that is ringing
go to programming section 5
You want Automatic Line Selection
Press feature00
left intercom button press twice (system program)
press right intercom once (central tel program)
enter # of extension to be programmed (intercom #)
press **
press line buttons in desired order line1 line 2 etc and
end with left intercom then press**
enter feature 00 to exit programming
Dave
Aug 26, 2008 | Avaya Corded Phone avaparp18d
Have to be near fax machine to recieve fax
The Rings to Answer feature might not be set to answer after the
appropriate number of rings for your office setup.
If you have a voice mail service at the same phone number you use
for fax calls, you must receive faxes manually, not automatically. For
information on how to receive faxes manually, see receive a fax
manually from a phone
on page 48.
If you have a PC modem on the same phone line with your
HP Officejet, check to make sure that the modem’s software is not
set to receive faxes automatically. Modems with this auto fax
receive feature turned on will take over the phone line to receive all
incoming faxes, which will prevent the HP Officejet from receiving
fax calls.
If you have an answering machine on the same phone line with
your HP Officejet, you might have one of the following problems:
Your outgoing message might be too long or too loud to allow
the HP Officejet to detect fax tones, and the calling fax machine
might disconnect.
Your answering machine might not have enough quiet time after
your outgoing message to allow the HP Officejet to detect fax
tones. This problem is more common with digital answering
machines.
The following actions might help solve these problems:
a. Disconnect the answering machine and then try receiving a fax.
If faxing is successful without it, the answering machine might
be causing the problem.
b. Reconnect the answering machine and re-record your outgoing
message. Make sure the message is as short as possible (no
more than 10 seconds long), and that you speak softly and
slowly when recording it. Try again to receive a fax.
If you have a special ring pattern for your fax phone number (using
a distinctive ring service through your telephone company), make
sure that the Answer Ring Pattern feature on your HP Officejet is set
to match. For example, if the phone company has assigned your
fax number a double ring pattern, make sure Double Rings is
selected as the Answer Ring Pattern setting. For information on
changing this setting, see change the answer ring pattern
(distinctive ringing)
on page 63.
Note that some ring patterns cannot be recognized by the
HP Officejet, such as those with alternating short and long ringing
patterns. If you are having problems with a ring pattern of this type,
ask your phone company to assign a non-alternating ring pattern.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 20, 2008 | HP Officejet 4215v All-in-One Printer
Canon LaserClass 9000L Plain Paper Fax Logo
115 people viewed this question
old marine
old marine
