Question about Harman Kardon HK695 Computer Speakers
Fuse casing on subwoffer
I bought a used HK695 computer speaker system but when I got it home it didn't work. On close inspection I came to find that the outer caseing that holds the fuse in is missing (the area between the power cord and the power switch marked To 75A 250V) Do you guys have any ideas on how I can safely jerryrig a casing so that the fuse will stay inserted and connect to the power supply?
Thanks!
Don
  • Anonymous Jan 02, 2009
    my speakers are not working. i think the 0.75A 250v fuse blew out. looking for places to purchase a new one...
  • 42 Answers
I would recommend you to let the hardware vendor from whom you bought the speaker know this as they will replace the complete set.just give them a call and let them know
Posted on May 28, 2008
What is the fuse size ( I know voltages but not proper ampage) for thr Harman/Kardon hk 695? Thank you
Greetings - You need a Radio Shack 270-1062 3/4 amp slow blow fuse or equivalent. Any .75-1 amp fuse of the same size should work fine.
Regards and Good Luck.
Thanks for using Fix Ya.
Mikeywaf
May 01, 2011 | Harman Kardon HK695 Computer Speakers
Are there Windows 7 (64-bit) drivers for a Harman Kardon HK695 speaker system? The speakers were originally purchased for a Windows XP desktop computer in 2002; and, I want to put them on a newer year...
They are speakers and therefore do not require a drive, well, I have never seen speakers that require one anyways. Your sound card is what needs drives but as long as you have the right connection (3.5mm jack) to plug into your speaker port the speakers should just work. If you need a specific program for advanced controls of the speakers then I would recommend going to the manufacturers website for downloads.
Feb 03, 2011 | Harman Kardon HK695 Computer Speakers
Where can I download the driver for my HK695 audio sys.
Download this software and it should give you information on where to get the driver you are requesting. Initially ur speakers are using an integrated sound card which is found on the motherboard and you need to know what kind of sound card it is to download the driver to make your speakers work.
http://cr.am/framed.php?url=http%3A%2F%2Fwww.softpedia.com%2FprogDownload%2FEVEREST-Home-Edition-Download-16369.html&ref=driverguide
Aug 01, 2010 | Harman Kardon HK695 Computer Speakers
Speakers do not work at all. Green light does not go on. I checked all the connections and electrical wire. ??????????
Have you made recent changes to the comp? What computer is it, what's the O.S.? Sounds like maybe the driver is gone. Go to the device manager in the control panel and check for a yellow question mark or exclamation mark, if you find one, right click and click update driver, then follow the directions on the screen.
Luck
Jul 07, 2010 | Harman Kardon HK695 Computer Speakers
I just installed a Denon 1610 A/V. I used my speakers from a older Sony 5.1 channel home theater system (DAV-S300). I got all the speakers to work except for the subwoffer. In order to hook-up the SW, I...
If you go to Manual setup/ select speaker setup/ select bass setting/ does it show LFE? If it does it is sending to main speakers only and you'll need to change to LFE+Main.
Oct 20, 2009 | JBL SCS135 System
Harman-Kardon HK695-01 Speakers Connection Quesion
According to the manual
http://tv.manualsonline.com/mdownloads/14ae515f-03bc-a2d4-8940-672bfa19f017.pdf
leave the black connector unconnected.
Hope that helps.
Oct 02, 2009 | Harman Kardon HK695 Computer Speakers
I want to use my HK695 speakers on my new Mac Pro desktop
http://www.harmankardon.com/product_support/SupportDetails.aspx?Region=USA&Country=US&Language=ENG&cat=&prod=HK695&sjump=ps&ky=295752998DFB844994AFB5150B637833&#active
copy and paste
There is everything you'll need, troubleshooting, manuals, and drivers...HK695
Please leave rating.
May 03, 2009 | Harman Kardon HK695 Computer Speakers
Logitech X-540 connecting to dell dimension 3000 ???
Your problem is you have a 3 channel sound card on your dell and you bought 5 channel speaker system. You can plug the green to green and get 2.1 sound but you will have to by a 5.1 pci sound like in the link below to get the full use of your 5.1 system.
http://www.mikescomputershop.com/asus-xonar-d2pm-sound-card-p-2357.html
Sep 08, 2008 | Logitech X-540 Computer Speakers
Harman Kardon HK695 computer speakers
In addition to all the screws mentioned in the bottom of the speaker, the HK695 has an internal brace that runs the length of the case and provides a support bracket for the speaker. To separate the halves of the sub woofer, carefully use a paperclip or something similar to hook the screen over the speaker and pull it off. Once the speaker is exposed, remove the four screws, pull out the speaker and disconnect the speaker wires. Remove the speaker. At this point, the halves will separate enough for you to disconnect the two multi-connector electrical cables that run from the circuit board in the base to the circuit board in the top. Once that is done the case will come apart.
Apr 26, 2008 | Harman Kardon HK695 Computer Speakers
Harman Kardon HK695 Computer Speakers Logo
106 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Brian Sullivan
Brian Sullivan
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
