Question about Sony Micro Vault Classic 4GB USB 2.0 Flash Drive
Operating system : XP SP3 Flash Drive : Sony Microvault USM 1GL 16GB Windows Message : The usb device not recognized
SOURCE: Sony microvault 2 gb
my laptop does not read the usb stick, when i insert it, a pop up says usb device not recognized, and has malfunctioned. I am having this problem after using this usb device in a car stereo system. please advise i need to recover my data from the device. please help me in this issue.
Posted on Jan 02, 2009
dealt_soul
  • 296 Answers
SOURCE: USB 2.0 slot on Sony Vaio PCV-RX860 does not work
Reinstall drivers for the usb ports. Eather on the company site or from your recovery disk that came with the system.
Posted on Feb 15, 2009
  • 10 Answers
SOURCE: get error message "operating system not found"
Run diagnostics on the harddrive. if possible reseat the Hard drive, i.e take it out and put it back again. and then try installing the OS. remember you have to boot from the laptop to install OS. Hope you are doing it correctly
Posted on Apr 09, 2009
  • 199 Answers
SOURCE: Sony 4gb flash drive was removed improperly, now it says USB Device not reconized
85 % chances may be damaged.check to another system.
Posted on May 14, 2009
Mrteaze
  • 101 Answers
SOURCE: My sony 2.0 gig microvault flash drive is ''not recognized''
probably lost all info but can save drive if its like a cruzer ... first with drive inserted go to computer and see what drive it is ie: D:, E: etc. open CMD... on XP go to run type CMD ... in Vista type CMD in the search by start and open command prompt. Type drive letter followed by : (example F:) then press enter now it should look like this F:\>_ now type "DIR" enter and you will see any files on that drive, to copy and try to save files type "copy F:\filename C:\newfolder" now this is just an example so make sure you create a folder to copy to prior to this copy function after you copy all files you need then you can delete files that are preventing it from working in my case I deleted all files and started over. To delete files ... At the prompt type "DEL F:\filename" do this with each file, if you need to know functions in command, at the prompt type "help" when you finish you should be able to format the drive and put your files back on .... good luck
Posted on Sep 29, 2009
I bought a 16GB DenDyne multi-function USB Digital Assistant and my computer is not loading it. It knows the device is there but shows no memory and am unable to copy files on it. I have Windows XP...
Try to format your USB Drive if that is not formatted yet. On your my computer you will see the USB drive right click on it then click reformat after reformat the computer will now recognize the available size of your device. Because if that the first time you to plug in a computer, the computer will not recognize if your USB is NFTS format or a FAT32 format.
Jul 22, 2011 | CenDyne 16GB USB 2.0 Flash Drive (Black)...
When I connect my pandrive to computer. A massage is shown that the device is not recognized by computer. Window XP 2003 is installed Please send me solution for this problem.
hi
Using the flash drive as the example, you would:
  1. Plug in your flash drive, then go to Control Panel, System, Device Manager.
  2. YOu should find the flash drive listed under USB Devices.
  3. Without taking the flash drive out of your computer, use the Device Manager function to "Remove" the drive from Windows.
  4. When that is finished, take the flash drive out of your computer.
  5. Reboot.
  6. Now, plug in the flash drive and Windows should recognize it again.
  7. If you originally had to load drivers from a manufacturer's CD for the flash drive, you'll have to load them again. You might have to do that if you're runing Win98 or WinMe or Win2000.
Aug 07, 2010 | Computers & Internet
My sony 4gb USM 4GN is not being formatted. It is write protected automatically. help!
Hi friend first you install yours device then logoff yours system then logon again and click on start--->run --> write command cmd then click on ok,Now write commands step by step
1) cd\ press enter
2) c:/>format drive letter (eg d: f: e: etc) press enter
3) read message carefully and then press y
now yours flash drive formatted
Jul 27, 2010 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
All External storage devices "USB Device Not Recognized"
Dear Sir,madam
You have to do some steps about fixing this problem :
1: Go to Device manager by right click on my computer then manage and then device manager.
2: Go to universal serial bus controller and export it.
3: in each USB root hub right click and then properties.
4: In properties screen select power management tab and unmark on " allow the computer to turn off this device to save power ".
5: After finishing this steps in each USB root hun restart your computer and then done
Jul 24, 2010 | Microsoft Windows XP Home Edition
My DameElec 2GB is not working on my XP Computer
try installing the flash drive once through add new hardware wizard from control panel. it might fix the problem for you. also plug the device directly into the usb slot present in the backside of the computer.
Jul 17, 2010 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
I have sony micro vault 2 GB pen drive but win xp sp3. but i plug pen drive the message is flash ''usb Device not recognized'' so how can solve this problem. how can work my pendrive properly.
Goto my computer and right click, left click on properties and find device manager.
Scroll down until you find universal serial bus controllers click on the + sign, right click on 'Enhanced Host Controller', right click and choose update driver, use the internet option to download updated driver, this should hopefully resolve your USB problem.
If it does not update and the usb drivers and they seem fine, then the problem could be with the flash drive, try the drive in another computer to check that it is working.
Apr 02, 2010 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
Not able to open doc.vem documents
Did you compress them with SONY MicroVault?
If so, try this program to decompress them.
http://www.sony.net/Products/Media/Microvault/files/USM_DE_P/Decompression_v101.exe
Oct 30, 2009 | Sony 256MB Classic Violet Micro Vault USB...
Not formatting
I had the same problem with my 1GB SONY MicroVault Clip flash drive. Hardware and the drive shows up on Vista, but it refuses to open or format it.
1) IT MANAGED TO REFORMAT NICELY ON WINDOWS XP!!!! So try this, or
2) When the Micro Vault does not operate well, please download the format software from a "download" button and re-format the Micro Vault. http://www.sony.net/Products/Media/Microvault/products/usm-l/dl.html
hope this helps guys!! :D
Apr 23, 2009 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
Hi pendrive is not working
hv u formated them
what is front and back ??
Jun 30, 2008 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
Apr 10, 2008 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
Sony Micro Vault Classic 4GB USB 2.0 Flash Drive Logo
60 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
